Use this guide to open your Apple Watch Series 6 for repairs.
You’ll need replacement adhesive to reattach the display when reassembling the device.
Before starting repairs, take your watch off the charger and power it down.
crwdns2935267:0crwdne2935267:0Safety Glasses$3.19
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
I found the supplied razor blade too thick to get in the gap between the screen and the case. I used half a Dorco razor blade to do the job, and some isopropyl alcohol once it started to lift.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
I was unable to do this. and I ended up breaking the glass in the process. So this was not a great experience
Only thing that fit that gap for me was a razor blade. Used one of those plastic scraper frames to secure it. Everything went according to this guide.
With a titanium case there is no give to get the blade within the gap. This step probably works fine with an aluminum case as it has more give. Even purchased new knives to make it work but only ended up scratching the case. Will now need to take to Apple Store and live with scratches...
Instead of a knife I used an ultrathin 0.1 mm spudger pry blade (Amazon) to get under the display and actually cut the seal around the whole display.
Insert an opening pick in the gap your created.
Slide the opening pick along the short edge of the watch to cut the adhesive.
Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
Slide an opening pick under the opposite display edge of the watch crown.
Twist the opening pick to loosen the display off the watch case.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upward position.
When I opened my watch I saw two layers of adhesive or are they gaskets? I broke one accidentally but not sure if I should keep the undamaged one in there? Or should both side be totally bare and the adhesive itself is also the seal?
Also I think I damaged my battery when prying it up since it won’t hold a charge now. I bought a replacement battery and will try that but is there anything else it could be?
Be very careful here... My display cable broke before achieving the angle they show in the last pick above. You may well want to order new cables along with the battery and gaskets. The are only $19.95
To reassemble your Apple Watch Series 6, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
crwdns2935229:05crwdne2935229:0
Where are the instructions for installing the new adhesive? Also, it's not listed in the tools/parts list.
Here's the guide for resealing the watch
How to Reseal an Apple Watch
If you change the battery of the 44 mm Model, make sure you got the Y000 bit for the tiny screw. I have a pretty comprehensive bit set from iFixit, but that one was not included.
AD161 - crwdns2934203:0crwdne2934203:0
