Nothing Phone (1) Rear Glass Replacement
  1. Nothing Phone (1) Rear Glass Replacement, Heat the rear glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Bereite einen iOpener* vor und platziere ihn für einige Minuten am rückseitigen Glas, um den Kleber darunter zu lösen.
    *Ein Haarfön, eine Heissluftpistole und ähnliches könnte auch zum erwärmen verwendet werden. Dies aber BITTE mit Vorsicht, Akkus mögen zu starke Hitze nicht z.B.
    byte park - crwdns2934203:0crwdne2934203:0
    eine frage wo kann mn ne glassrückseite kaufen zum replacen
    aoaoaoa aoaoaoa - crwdns2934203:0crwdne2934203:0
  2. Nothing Phone (1) Rear Glass Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    .Einen Sauger unten am hinteren Glas anbringen, so nah wie möglich am Rand. i:Falls das Glas schon gesplittert ist, lässt sich der Sauger nicht verwenden. Man kann es mit einem starken Klebeband versuchen, oder man klebt den Sauger mit SuperKleber fest.
    .Das rückseitige Glas minimal anheben, um einen kleinen Spalt zwischen der Rückseite und dem Rahmen zu erzeugen. i:Bei Problemen nochmals mit iOpener oder Wärmegeräten versuchen, den Kleber etwas zu lösen.
    .Einen Plektrum bzw ein geeignetes Werkzeug in den geschaffenen Spalt einführen.
    .'Schneiden' Sie mit dem Werkzeug durch den Kleber zur rechten unteren Ecke.
    .Das Werkzeug nicht entfernen, um Wiederverkleben zu verhindern.
    Findet das jemand ganz ok übersetzt, oder sogar gut? mfg
    ¿Dónde puedo conseguir el cristal trasero ya que se me rompió?
    Alan Rodriguez - crwdns2934203:0crwdne2934203:0
    Where can I buy the actual parts from ? I'm talking about the nothing phone (1) thank you for taking the time to read
    Hady21t - crwdns2934203:0crwdne2934203:0
  3. Nothing Phone (1) Rear Glass Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Hello help please! I'm in France and I'm desperate to find the back glass for my Nothing Phoane 1help me with a link outside india where i can find? India does not ship to France
    costache marius - crwdns2934203:0crwdne2934203:0
  4. Nothing Phone (1) Rear Glass Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Nothing Phone (1) Rear Glass Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Nothing Phone (1) Rear Glass Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Nothing Phone (1) Rear Glass Replacement, Remove the rear glass: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nothing Phone (1) Rear Glass Replacement, Remove the rear glass: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Dust Blower
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Bonjour,
    La vitre arrière est introuvable.
    C'est scandaleux..
    Stéphane 34 - crwdns2934203:0crwdne2934203:0
    Bonjour @stephane34,
    Nous n’avons malheureusement pas de pièces pour le Nothing Phone. J'ai transmis la demande à notre département d'achat.
    Bonne continuation de vos recherches !
    Claire Miesch -
    Nothing phone 1 real glass kidar milega
    Nothing 1 - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
234,650 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,697crwdne2935297:0
crwdns2947412:023crwdne2947412:0
Where an you purchase replacement back glass?
Kay Khan - crwdns2934203:0crwdne2934203:0
If you guys has bought back panel kindly let me know please..
U1 Kishore -
Where can I buy the back glass panel ?
MOHSEN JASHNI - crwdns2934203:0crwdne2934203:0
Hello,
I have looked online and don't find a place to order a replacement back glass. @schnabel, where did you get the glass from?
Linus Ljungblom - crwdns2934203:0crwdne2934203:0
Is someone find the back glass?
Zakhar Klimakov - crwdns2934203:0crwdne2934203:0
If you find the panel let me know sir please
U1 Kishore -
I'm also unable to find the back glass anywhere. If someone finds it please let the rest od us know
Daniel Pršala - crwdns2934203:0crwdne2934203:0
cant really find them replacement parts online whats up
Dev Ra - crwdns2934203:0crwdne2934203:0
Where can you buy the replacement glass?
Willometer - crwdns2934203:0crwdne2934203:0
did u guys find it that where to buy the back glass?
马筱牧 - crwdns2934203:0crwdne2934203:0
A quoi sert ce tuto s'il n'y a pas au moins un lien ou une adresse pour acheter la pièce à changer ?
Antoni Chauvet - crwdns2934203:0crwdne2934203:0
Bonjour @antonichauvet,
Claire Miesch -
Bjr, je reviens ici parce que chaque fois qu'il y a un nouveau commentaire je reçois un email. Y a quand même un truc qui me vient à l'esprit en y réfléchissant : pour faire ce tuto, il vous a bien fallu recevoir cette fameuse pièce (vitre arrière) . Du coup comment vous vous y êtes pris vu qu'elle est introuvable ? Si vous ne pouvez pas la fournir, vu le nombre de personnes déserpérées de la trouver, pouvez-vous au moins nous donner un lien vers la personne qui vous l'a fourni ? Cordialement
Antoni Chauvet -
Any information on the glass on the back?
Felipe Mora - crwdns2934203:0crwdne2934203:0
Is someone find the back glass for nothing phone 1 tks
soufiane ba - crwdns2934203:0crwdne2934203:0
How too buys this product i want buys for sri lankan ?
Yasiru Madusanka - crwdns2934203:0crwdne2934203:0
completely useless since you cant buy the back glass anywhere
Dug Moogle - crwdns2934203:0crwdne2934203:0
Where I found I want and I am live in Pakistan
zubair shehzad - crwdns2934203:0crwdne2934203:0
Bonjour tout le monde, j'ai enfin trouvé l'article sur vopmart.com
Faut compter 30€ avec le port mais au moins, on n'aura pas à se séparer du téléphone et l'envoyer au sav.
how to can bay back panel please
Rakib - crwdns2934203:0crwdne2934203:0
Since everyone is asking for the back glass panel, i am located in the netherlands, i can ship worldwide, shipping costs depends on where you are. If you are interested or need help in any way, feel free to contact me on, Kaplan_gozu@msn.com
Selcuk - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 127
crwdns2936753:030crwdne2936753:0 507
crwdns2942667:0crwdne2942667:0 22,872
