crwdns2959928:0crwdne2959928:0 ↓Follow this guide to replace the screen with your Nokia 2780 Flip.
Nokia screens are 2.7-inch TFT with a resolution of 240 x 320 pixels. If your Nokia is cracked or damaged, has a black screen but the phone will still power on, lines, dead pixels, or discoloration appears, or the screen flickers when opening/closing the phone, it could be time to replace the screen.
- If the screen is cracked or shattered, take appropriate safety precautions before beginning the repair. This Taping Over a Cracked Screen guide can help prevent injury from broken glass during removal.
- The screen is secured with adhesive, so applying heat before you attempt to remove the old one will make the process a lot easier. Take a look at our iOpener Instructions, How to Use a Heat Gun to Soften Adhesive, or How to Use a Hair Dryer to Soften Adhesive guide, depending on what you use for the repair. This will help you to avoid further damage to your phone and injury to yourself.
Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
Slide the opening tool or spudger around the edge of the phone to release the clips securing the bottom case.
Gently pry the bottom case from the phone to remove it.
Lift the battery up and out of the compartment.
Use a Torx T5 screwdriver to remove the six visible 1.4 mm screws that secure the internal rear housing.
Insert a plastic opening tool in the seam between the top case and midframe and slide it around the perimeter to release the clips holding them together.
Remove the midframe from the phone.
Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
Remove the plastic cover on top of the hinge.
Pull back the frame surrounding the motherboard from both sides and gently remove the motherboard.
Use a plastic spudger and opening picks to pry the back cover from the display.
Use a suction handle to remove the old screen.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
