Nintendo Switch Lite Fan Replacement
Craig Lloyd
crwdns2944107:0crwdnd2944107:0Craig Lloydcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 5, 2025crwdne2944111:0
crwdns2931287:030crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Follow this guide to replace a faulty or damaged fan in the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: This procedure requires removing the shield plate and heat sink. The thermal paste will need to be cleaned off of both components—as well as the CPU—and reapplied before reinstalling the shield plate and heat sink.
crwdns2944105:0crwdne2944105:0
  1. Nintendo Switch Lite Fan Replacement, Remove the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    All my screws got stripped any ideas on how to remove?
    Almost A Mammal - crwdns2934203:0crwdne2934203:0
    A Y0 screwdriver seemed to work better for me.
    Tommy Morrill - crwdns2934203:0crwdne2934203:0
    What type of screw driver do I use to un screw the screws and which way
    Luca Capito - crwdns2934203:0crwdne2934203:0
    Y 0.6 was all I had but it seemed to fit perfectly
    Trevor - crwdns2934203:0crwdne2934203:0
    Like really snug? I've gotten away with using Drivers either bigger or smaller but I hate doing it. But if 0.6 is the exact size I need, then I'll get that. I don't wanna strip my client's Switch Lite's screws.
    Vincent Valodze -
  2. Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    I accidentally stripped the back screw and now I can't open it. I removed all the other screws. What should I do?
    tiggytiger555 - crwdns2934203:0crwdne2934203:0
  3. Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Fan Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Twist to release the clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    The headphone jack prevents you from completely freeing or lifting the back panel straight up. Unclip your way around the back cover, then lift from the side with the US port and slide it off the heaphone jack.
    Zackery Ooms - crwdns2934203:0crwdne2934203:0
  8. Nintendo Switch Lite Fan Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Remove the back panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Fan Replacement, Remove the shield plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    There are four screws instead of three mentioned
    Khurram Chaudry - crwdns2934203:0crwdne2934203:0
    it doesnt mention 3 anywhere, and it labels all four
    Ezi - crwdns2934203:0crwdne2934203:0
    With how easy it seems to be to do serious damage with the next few steps, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    Nate - crwdns2934203:0crwdne2934203:0
    Well I actually removed the screw right next to the 4.5 screw. I did not realize it till my son showed me why the plate wouldn't release. Ha ha, it's funny now but yeah not a big deal. I could have bent it badly assuming I took all screws out though. For anyone reading this before going in. 👍
    Toastninja - crwdns2934203:0crwdne2934203:0
    the one in the middle rounded out .-.
    C6smic_Trxble - crwdns2934203:0crwdne2934203:0
  10. Nintendo Switch Lite Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    You may need to replace the thermal paste on the heat sink.
    ahoz28 - crwdns2934203:0crwdne2934203:0
    What type of Thermal Paste would you guys recommend? I clicked on the picture but nothing.
    Vincent Valodze - crwdns2934203:0crwdne2934203:0
    Personnaly i use some Mx-6 from Artic, really good quality/price, never have to complain.
    Nothing -
  11. Nintendo Switch Lite Fan Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    The clip broke off when trying to remove this cable. Audio only works through headphones and the display now won’t turn on after the clip broke. Does anyone know where I could get a clip or how I could fix it without it?
    Alexz Zepeda - crwdns2934203:0crwdne2934203:0
    Mi è successa la stessa cosa è non so come ripararla! Chissà se c’è un modo!
    Paolo De Falco -
  12. Nintendo Switch Lite Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    I turned the unit off beforehand, I used tweezers just like the instructions said (ifixit branded) , my device sparked and now it won’t turn back on
    User Service - crwdns2934203:0crwdne2934203:0
    The flap came off is it important or is there a way t fix it?
    Jose Cruz R Rangel Cordero - crwdns2934203:0crwdne2934203:0
    We're you able to get it working without the white flap? My screen is not working after putting it back together and i noticed this white flap was falling off
    Jimmy “Ghost” Trost -
    Did you get it working without the white flap? Everything on the switch works fine except for audio going through headphones and the display not turning on.
    Alexz Zepeda -
    do not use metal sharp pointed tweezers! you will rip your ribbon cable. Use the inside of a Bic type pen or something else dull and plastic to pull the cable away by putting the pen part where the first bend is.
    Christopher Bales (C.J.) - crwdns2934203:0crwdne2934203:0
    Anyone figure out how to fix this? my device shorted in this step.
    Acord - crwdns2934203:0crwdne2934203:0
    Maybe tape the Tweezers or smear some hot glue on them to insulate them to save you time and money.
    Maybe put all the Warnings at the start of the guide as well. We fix it geeks tend to get excited when fixing things 😁
  13. Nintendo Switch Lite Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Caution the connector may not be properly soldered onto the motherboard. For me it snapped off the pins and now have to find a place to get that fixed if even possible. may have bricked it.
    Craig Osman - crwdns2934203:0crwdne2934203:0
    Yup, broke the connector right off the motherboard. Thanks, ifixit -_-
    Justin Kerr - crwdns2934203:0crwdne2934203:0
    I backed out when I reached this point. I couldn't risk damaging it. Do u just need to pull it up? Did you mean that it might have been soldered shut below?
    Jannalyzer - crwdns2934203:0crwdne2934203:0
    You should just need to pull straight up, but make sure you’re pulling on the wires or the gray plug—do not pull on the black socket or it can snap off of the motherboard.
    Adam O'Camb -
    I pulled straight up from the south side on under 2 or three wires and held down the device as I pulled and the gray connector disconnected from the black connector on the Switch. Just be careful at this part.
    Jon - crwdns2934203:0crwdne2934203:0
    With how easy it seems to be to do serious damage at this point, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    just broke my connector... ifixit PLEASE put a warning on how fragile the solder on this connector is.
    Nate Mascis - crwdns2934203:0crwdne2934203:0
    Note for this step, you do not need to apply a lot of force. I used two tools here: small screwdriver to hold down the black base, and one side of fine-tipped tweezers to get under all 3 wires. Gently, push down on the tweezers to push the wires upwards, which should force the gray connector up and off the base. It did not take a lot of force. Take your time and it will be fine. Again, like others have said, do NOT pull or pry up the black base.
    Christopher Gillett - crwdns2934203:0crwdne2934203:0
    Go only under the wires with a plastic tool and gently apply pressure to each side of the 3 wires, you’ll kinda want to shimmy the grey connector out of the black one.
    Hylan Snow - crwdns2934203:0crwdne2934203:0
  14. Nintendo Switch Lite Fan Replacement, Remove the heat sink: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    When reassembling, the foam may fold down between the fan and heatsink, blocking airflow. Gently lift the foam back up on top of the fan. The adhesive film should hold the foam together.
    Kean Stump - crwdns2934203:0crwdne2934203:0
    Is removing the heat sink absolutely necessary?
    Clark Aulden - crwdns2934203:0crwdne2934203:0
    It’s not necessary, but it makes it much easier to remove and replace the game card reader, since the heat sink partially covers the connector.
    Craig Lloyd -
    Not really…….. I never remove it. It slides out quite easily once disconnected.
    Alan Sears - crwdns2934203:0crwdne2934203:0
    What do you do if these screws are stripped? They strip easily
    Whatever - crwdns2934203:0crwdne2934203:0
  15. Nintendo Switch Lite Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Grazie per avercelo segnalato! Ho apportato la modifica. iFixit è una wiki, quindi ogni utente può modificare le pagine: se trovi altri errori in futuro, sentiti libero di fare la modifica tu stesso!
    Sara Balestra -
  16. Nintendo Switch Lite Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    16.5 remove cartridge / headphones jack……….
    Calvin Martin - crwdns2934203:0crwdne2934203:0
    I've read that there are different ways to apply thermal paste, which should I use?
    Kai B - crwdns2934203:0crwdne2934203:0
    My kit did not come with thermal paste..
    Bryan Donovan - crwdns2934203:0crwdne2934203:0
  17. Nintendo Switch Lite Fan Replacement, Remove the fan: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement, Remove the fan: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  18. Nintendo Switch Lite Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  19. Nintendo Switch Lite Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 4.8 mm screws securing the fan.
  20. Nintendo Switch Lite Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Lite Fan Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fan.
    • Take care not to snag the fan cable on the motherboard as you remove the fan.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
crwdns2935229:08crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
40,155 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
I used this guide to put my new fan in and let me just say THANK YOU!!! All I could find was ones for regular Switches on YouTube and not the Lite. The only problem I had was I'm not sure which side of the cable on the fan should be facing up. I looked on your website and the fan listen on here has one side with a gold part at the end where you insert it into the connector. Is that the side that goes up?
Skylar Neville - crwdns2934203:0crwdne2934203:0
Many thanks for this guide it helped me so much it was pretty straight forward to do but attaching the fan ribbon/power cord and trying not to strip the tiny screws heads was probably the hardest bits really
FMG_MADLOO87 (MADLOO) - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 82
crwdns2936753:030crwdne2936753:0 464
crwdns2942667:0crwdne2942667:0 20,410
