This guide will walk you through the steps necessary to replace the power switch cover on your Game Boy Advance SP. The power switch of the Game Boy Advance SP is small and attaches to the motherboard itself. For this reason, the device features a much larger cover to help the user turn their device on and off. Follow this guide if your power switch cover is damaged or needs to be swapped out.
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Lift the battery cover up and remove it from the device.
Use your fingers or a plastic opening tool to remove the battery from the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Lift the back cover off of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift the power switch cover away from the left side of the device using your fingers or tweezers.
crwdns2935229:017crwdne2935229:0
where to buy invidual single y00,y0 or y1 bit
Sorry if this is such a late response @lachainede96340, but the screw you're looking for is going to be a M2 x 0.4mm that's 4mm long with a JIS/Phillips drive and a pancake head.
I'm not sure what you'd call the head, but it's most likely a pancake head since it's not designed for a countersunk hole like a flat head, and is too thin to be a pan head. Hope this helps!
Désolé pour cette réponse si tardive @lachainede96340, mais la vis que tu cherches est une M2 × 0,4 mm de 4 mm de long, à empreinte JIS/Phillips et tête « pancake ». Je ne suis pas certain du terme exact pour cette tête, mais c’est très probablement une tête « pancake », car elle n’est pas conçue pour un trou fraisée comme une tête fraisée (flat head) et elle est trop plate pour être une tête bombée (pan head). J’espère que ça t’aidera!
Stephen Posner -
Sorry if this is such a late response @lachainede96340, but the screw you're looking for is going to be 4mm long with a JIS/Phillips drive, M2 thread, and a pancake/wafer head.
Amazon Link
The head is most likely a pancake or wafer type head since it's not designed for a countersunk hole like a flat head, and is too thin to be a pan head. Hope this helps!
Désolé pour cette réponse si tardive @lachainede96340, mais la vis que tu cherches fait 4 mm de long, possède une empreinte JIS/Phillips, un filetage M2 × 0,4 mm et une tête pancake/wafer.
Lien Amazon (je n’ai pas réussi à trouver un lien sur le site Amazon France, désolé)
La tête est très probablement de type pancake ou wafer, car elle n’est pas conçue pour un trou fraisée comme une tête fraisée (flat head) et elle est trop fine pour être une tête bombée (pan head).
Stephen Posner -
