This guide will walk you through the steps necessary to replace the power switch cover on your Game Boy Advance SP. The power switch of the Game Boy Advance SP is small and attaches to the motherboard itself. For this reason, the device features a much larger cover to help the user turn their device on and off. Follow this guide if your power switch cover is damaged or needs to be swapped out.
Slide the power switch to the OFF position and unplug any cables.
If you have a game cartridge in, remove it.
Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
Lift the edge of the cover near the screw and remove the cover.
Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
Four 6.3 mm‑long recessed screws
Two 4.6 mm‑long screws
Lift the bottom shell straight up and remove it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift the power switch cover away from the left side of the device using your fingers or tweezers.
crwdns2935229:017crwdne2935229:0
This doesn't explain anything about how to replace the switch
Maybe the guide was for replacing the power switch cover?
where to buy invidual y00,y0 or y1 bit?
