Ninja Mega Kitchen System BL770 Circuit Board Replacement
  1. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Mega Kitchen System BL770 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Mega Kitchen System BL770 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
    Mein yeh circuit board kharidna chahta hoon kha se milega
    Pravjot Singh -
    Misma pregunta, donde compro esta placa?
    Antonio Paredes Vilchez - crwdns2934203:0crwdne2934203:0
    It's not a fix if you don't provide part numbers. Also stinks that you drew circles around the switches and covered up the solder point. I think the switches are 4 pin, but can't tell for sure...
    dale - crwdns2934203:0crwdne2934203:0
    Hi , where can I buy circuit board for my ninja bc770…
    Part# BL770-2(K01-BC-04-02)
    My name is Marino and have same issue
    Any help is appreciated.
    Thank you
    marino - crwdns2934203:0crwdne2934203:0
  5. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cautiously desolder all the wires connecting the circuit board to the unit.
    • Carefully slide the circuit board free of the wires are place the new board in.
    • Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
    Hi,
    I would like to know the specification of the metal oxyde varistor MOS as I need to change it.
    Thank you
    James - crwdns2934203:0crwdne2934203:0
    Hi.. where can I buy a new one circuit board?
    Marco Celoni - crwdns2934203:0crwdne2934203:0
    Donde comprar la tarjeta de circuito
    joan mena - crwdns2934203:0crwdne2934203:0
    What is the name of yellow rectangular part on the circuit board . It is next to the round yellow part
    Lalbeharry Ramdayal - crwdns2934203:0crwdne2934203:0
Tommee Walker
crwdns2935283:008/22/17crwdne2935283:0
850 crwdns2915208:0crwdne2915208:0
Arkansas State University, Team S1-G4, Chamberlain Fall 2017 crwdns2935289:0Arkansas State University, Team S1-G4, Chamberlain Fall 2017crwdne2935289:0
ARSU-CHAMBERLAIN-F17S1G4
crwdns2947412:016crwdne2947412:0
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Jose Gonzalez - crwdns2934203:0crwdne2934203:0
Does somebody know where can I buy this circuit board ??
castro_73 - crwdns2934203:0crwdne2934203:0
Anyone know the chip on this circuit board?? Proprietary I assume??
Nathan Walter - crwdns2934203:0crwdne2934203:0
Great info but i’m looking to purchase a replacement circuit board for my ninja blender and can not find one. Any ideas?
Rich - crwdns2934203:0crwdne2934203:0
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
kolin camacho - crwdns2934203:0crwdne2934203:0
Hi, where did you buy this circuit board?
palmamail - crwdns2934203:0crwdne2934203:0
Hi, where do I find this circuit board please?
Daniel - crwdns2934203:0crwdne2934203:0
Hi Tom:
My BL770 turns the button on and off as soon as any button is pressed.  To turn it on again, it must be disconnected.  What could be the damage?  Thank you.
Jaime David - crwdns2934203:0crwdne2934203:0
Hi anyone know the reference of the varistor MOS on circuit board as I need to replace it.
Thanks !
Hey, were you able to replace that varistor?
Amr -
Where can I buy the circuit board for the bl770 blender?
Idelf Roa - crwdns2934203:0crwdne2934203:0
Hello . Did you find the pcb anywhere?
orlando cortes -
Are you have pcb nijnja blender BL685.How much price??..
The Red Cool - crwdns2934203:0crwdne2934203:0
Bonjour. Est-il possible d'avoir le circuit board du ninja blender BL770-30 ????
Si oui où ?? Je suis vraiment dans le besoin.
Merci de m'apporter votre aide.
Nelson Bi - crwdns2934203:0crwdne2934203:0
saludos , cual es el codigo datos del integrado central
Franklin Reyes - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 161
crwdns2942667:0crwdne2942667:0 6,145
