In the chance that your circuit board stops working, this step-by-step guide will show you how to replace it. For soldering help, follow the How to Solder and Desolder Connections guide.
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Carefully remove the second layer from the base. You will not need a screwdriver for this step.
Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
Carefully lift the base up from the rest of the blender.
Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Where can I buy a new board?
Mein yeh circuit board kharidna chahta hoon kha se milega
Same question here
Misma pregunta, donde compro esta placa?
It's not a fix if you don't provide part numbers. Also stinks that you drew circles around the switches and covered up the solder point. I think the switches are 4 pin, but can't tell for sure...
Hi , where can I buy circuit board for my ninja bc770…
Part# BL770-2(K01-BC-04-02)
My name is Marino and have same issue
Any help is appreciated.
Thank you
Cautiously desolder all the wires connecting the circuit board to the unit.
Carefully slide the circuit board free of the wires are place the new board in.
Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
Hi,
I would like to know the specification of the metal oxyde varistor MOS as I need to change it.
Thank you
Hi.. where can I buy a new one circuit board?
Donde comprar la tarjeta de circuito
What is the name of yellow rectangular part on the circuit board . It is next to the round yellow part
crwdns2947412:016crwdne2947412:0
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Does somebody know where can I buy this circuit board ??
Anyone know the chip on this circuit board?? Proprietary I assume??
Great info but i’m looking to purchase a replacement circuit board for my ninja blender and can not find one. Any ideas?
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
Hi, where did you buy this circuit board?
Hi, where do I find this circuit board please?
Hi Tom:
My BL770 turns the button on and off as soon as any button is pressed. To turn it on again, it must be disconnected. What could be the damage? Thank you.
Hi anyone know the reference of the varistor MOS on circuit board as I need to replace it.
Thanks !
Hey, were you able to replace that varistor?
Amr -
Where can I buy the circuit board for the bl770 blender?
Hello . Did you find the pcb anywhere?
Are you have pcb nijnja blender BL685.How much price??..
Bonjour. Est-il possible d'avoir le circuit board du ninja blender BL770-30 ????
Si oui où ?? Je suis vraiment dans le besoin.
Merci de m'apporter votre aide.
saludos , cual es el codigo datos del integrado central
Dónde compro la placa de circuito?
