Nikon D850 Rear Display Cable Replacement
  1. Nikon D850 Rear Display Cable Replacement, Prepare the camera and work area: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an ESD safe work area. Remove the lens, battery, memory cards, and grip. Install a body cap to prevent dust from entering the body.
    • This repair involves a lot of screws that are different lengths and thread types. A magnetic project mat is highly recommended for this repair. A screw in the wrong hole can strip, break off, or damage other camera internals.
  2. Nikon D850 Rear Display Cable Replacement, Remove the bottom center cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7 J00 screws on the center bottom cover. The cover comes off easily
    • The 4 rubber feet usually stick to the camera body. There is no adhesive holding them to either part. Remove them and replace them in the bottom cover.
  3. Nikon D850 Rear Display Cable Replacement, Remove the baseplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Remove the baseplate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 9 J00 screws on the center baseplate cover on the base of the camera.
    • There are 2 sneaky screws under the battery compartment cover.
  4. Nikon D850 Rear Display Cable Replacement, Separate the baseplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Separate the baseplate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the baseplate from the camera body.
    • It can be a bit tricky to get off. Using the battery door, pull gently up from the front (lens side) of the camera body and it should lift off with almost no force. An opening pick or plastic opening tool around the opposite side of the bottom plate can help wiggle it out. If you are pulling hard, something isn't right!
  5. Nikon D850 Rear Display Cable Replacement, Unscrew the rear cover Pt. 1: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Unscrew the rear cover Pt. 1: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Unscrew the rear cover Pt. 1: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 J00 screws holding the back case assembly to the camera body.
    • There is another sneaky screw under the right-side thumb grip. Use an opening pick or tweezers to get under the adhesive-secured grip to pull it slightly away from the body to access the screw. The adhesive should remain adhered to the grip, and it should go back in place without any marks
    • The memory card slot cover will come off, separate from the back.
  6. Nikon D850 Rear Display Cable Replacement, Unscrew the rear cover Pt. 2: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Unscrew the rear cover Pt. 2: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Photos, continued
    • The screw next to the HDMI out port is connected to the mainboard and is unique.
  7. Nikon D850 Rear Display Cable Replacement, Unfold and remove the rear cover. CAREFULLY: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Unfold and remove the rear cover. CAREFULLY: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The rear case/display and card slot cover will come out at the same time. The rear case unfolds down, so watch those cables!
    • These connectors have a flip-up release on the back of them. The rear of the connector can be flipped upwards with a pick or opening tool to allow the cables to disconnect with little to no force. Once the cables are removed, set aside and cover the camera body to prevent dust from getting in.
    • The cables don't have a lot of slack so taking an extra second to make sure nothing is hung up and pulling is worth it!
  8. Nikon D850 Rear Display Cable Replacement, Removing the rear display, First 2 screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the rear display, First 2 screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the screen up, so the display is facing the viewfinder. Remove the 2 J00 screws at the top of the display
    • The display surround is plastic. Use care reinstalling the screen screws. Just snug is plenty.
  9. Nikon D850 Rear Display Cable Replacement, Final 2 screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Final 2 screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the screen down towards the base of the camera and remove the bottom 2 J00 display screws.
    • Use care from this point on when moving the display, as it is now disconnected from its frame.
  10. Nikon D850 Rear Display Cable Replacement, Removing the display: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the display: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the display: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the display back parallel with the camera back, but away as far as possible. Support the back of the display so it doesn't fall apart before you're ready.
    • The goal with this step is to separate the adhesive holding the cable to the display to allow it to fold up towards the viewfinder. While it's still adhered, it will want to fold down slightly towards the bottom of the camera body.
    • Slightly separate the display assembly from the frame by pulling straight back. Do not force movement if tension is felt from the cable.
    • Once you have around 1cm of clearance between the display and frame, use 90%+ isopropyl alcohol and a thin, nonconductive pry tool to loosen the adhesive and separate the display cable marked in blue from the back bottom side of the display.
    • I found the area where the camera body cable attaches to the blue outlined area the easiest to get the solvent in and begin detaching the cable. Use caution as both the display cable and screen cable are quite fragile.
  11. Nikon D850 Rear Display Cable Replacement, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the cable is unglued from the back of the display module, the display can flip up towards the viewfinder and laid down face down on the back of the camera. Again, use care moving the display to avoid cable damage
    • Support the back of the ZIF connector (in blue), to avoid flexing the cable and flip the latch opposite the display cable side up to allow the cable to release. Once the latch is released, the cable should pull out of the connector with almost no effort.
    • I've left the cables connected in this photo to aid reassembly order. There is a plastic midframe (yellow arrows) attached to the display assembly with the cables passing through it. Once the display cable is removed, the midframe may fall out. Set the display and midframe assembly aside.
  12. Nikon D850 Rear Display Cable Replacement, Removing the cable retention from the rear housing: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the cable retention from the rear housing: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the cable retention from the rear housing: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the display removed from the rear body, remove the 4 screws on the cable retention mechanisms. The one on the flexible assembly is 2 pieces. The piece with the "ears" goes on the bottom with the ears out and up on reassembly.
    • The rear cover passthrough plate has a rubber gasket that slots into a hole under the plate. Make sure both the plate and gasket are oriented and located correctly on reassembly.
  13. Nikon D850 Rear Display Cable Replacement, Removing the display cable.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the display cable.: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Removing the display cable.: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The cable will pull out from the body through the back (screen side) of the display frame. Use plastic tweezers or a spudger from the inside to push out the rubber cable guide (green arrows) from the rear of the display frame.
    • Once the rubber cable guide is removed, gently guide the cable around the frame and out of the camera body. The cable has positioning ears on it (red arrows) that can catch and snag on the way out of the body, so use care!
  14. Nikon D850 Rear Display Cable Replacement, Installing the new display cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the back side of the display frame, route the cable from the display over the top bar, then through the hole on the bottom bar, and finally through the passthrough on the camera back cover. Do not install any of the cable retention brackets/grommets/covers at this point.
    • Use care when manipulating the new cable. The end with the circuitry and connector on it is extremely fragile. It does not take much of a bend to make a new cable inoperable.
  15. Nikon D850 Rear Display Cable Replacement, Reinstall the display assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the cable from the display coming from the top, and the midframe installed, route the cable as shown. Make sure the release lever on the connector is flipped up and insert the display cable. It should go in and seat with little effort.
    • While making sure the display cable remains seated fully in the connector, support the back of the display cable and press the connector latch down to secure the cable.
    • Once the connector is closed, reinstall the rear display, making sure not to crease or pull on any cables. Feed as much of the black part of the display cable through the back of the rear frame as possible. While holding the display together, flip it all the way up to reinstall the bottom screws, and all the way down to reinstall the bottom screws.
    • Once the display is installed, inspect the rear of the display and make sure the cable is still coming out straight, isn't kinked anywhere, and is routed properly through the holes and frame components.
  16. Nikon D850 Rear Display Cable Replacement, Reinstall the rear cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the release levers on these connectors are flipped up, then gently reinstall the new display cable and control cable to the main board, then push the levers down.
    • Install the card reader cover at the same time as the rear cover.
    • This is a good spot for a quick test. Insert the battery and power on the camera. Inspect the display at this point to make sure everything functions properly. Be sure to remove the battery before any further reassembly!
    • At this point reassembly of the camera body is the reverse of removal. Reinstall all rear cover and bottom cover screws but do not install any cable retention yet.
  17. Nikon D850 Rear Display Cable Replacement, Cable retention installation-Rear of Display: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the split grommet into the back of the display frame. A set of blunt tweezers or pointy plastic spudger helps get the grommet fully seated. Use care to avoid poking the cable.
    • Make sure the smaller "ears" of this cable are at the grommet passthrough, to ensure enough length for cable movement.
  18. Nikon D850 Rear Display Cable Replacement, Cable retention installation-frame: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Cable retention installation-frame: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the mid-frame cable guide with the display flipped toward the bottom of the camera. The cable should be able to slide freely through this guide.
    • Make sure the little ears on the display side of the guide are clipped into the frame before screwing the bottom plate on. These are tiny screws and do not take being overtightened well. Snug is perfect for these.
  19. Nikon D850 Rear Display Cable Replacement, Cable retention installation-Rear Cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Cable retention installation-Rear Cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D850 Rear Display Cable Replacement, Cable retention installation-Rear Cover: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The cable section that enters the camera body has ears that sit in these grooves. Push excess cable into the body, set the cable in these grooves, place the rubber piece over it and screw on the cover plate while preventing movement. This will position the cable appropriately in the frame to avoid kinks and excessive tension on the cable.
    • Really small screws here again, so snug is good enough for these guys!
    • Some aftermarket cables do not come with the longer ears on the cable, so the tension must be set manually. I found pushing as much cable into the body as I could and then letting out 1-2mm of cable before securing the cable works well if your cable is missing ears or they have become damaged.
  20. Nikon D850 Rear Display Cable Replacement, Test and verify all rear cover and screen functions work: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the body cap, install a lens, memory cards and other accessories. Power on the camera and verify the screen and all back panel buttons function normally. Make sure the display can articulate fully without any cable tension or snagging.
Steve D
crwdns2935283:004/07/20crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 77
