This guide demonstrates how to remove the black plastic cover inside the Moto G6 in order to replace it or for further disassembly.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Heat the right edge of the back of the phone to soften the adhesive underneath.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Heat the top edge of the back of the phone to soften the rear glass adhesive.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Heat the left edge of the back of the phone to soften the adhesive underneath.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Remove the rear glass.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
Remove the plastic cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G6 Answers Community for help.
Danke für diese Anleitung. Bei mir war im schwarzen Klebeband ein Art Antenne. In Schritt 11 also nicht unbedingt das ganze Klebeband entfernen - der dünne schwarze Streifen, der um den Akku geht ist mit dem Mainboard verbunden und darf nicht abreißen.
