Motorola Edge Display Panel Replacement
Jennifer Berg
crwdns2944107:0crwdnd2944107:0Jennifer Bergcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0May 15, 2023crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
Follow this guide to remove and replace the display assembly on a Motorola Edge.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You’ll need to remove the battery in order to replace the display. If the battery is deformed, dented, or damaged in any way, do not reinstall it. Reinstalling a damaged battery is a potential safety hazard.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. If you have that type of screen, follow this guide instead.
crwdns2944105:0crwdne2944105:0
  1. Motorola Edge Display Panel Replacement, Find the SIM tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the SIM tray located at the top of the phone.
  2. Motorola Edge Display Panel Replacement, Eject the SIM tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Eject the SIM tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
    • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
    • Press to eject the tray.
  3. Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card tray from the phone.
  4. Motorola Edge Display Panel Replacement, Heat the bottom edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
    I am having no luck removing the back cover on Moto edge. Can apply heat for more than 2 minutes?
    John Wright - crwdns2934203:0crwdne2934203:0
    You may! Heating beyond two minutes won't hurt your device; the iOpener doesn't get hot enough to do that. Apply the iOpener as long and as much as you need to loosen the adhesive.
    Alex Diaz-Kokaisl -
  5. Motorola Edge Display Panel Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the bottom adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  6. Motorola Edge Display Panel Replacement, Slice the bottom adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Slice the bottom adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Slice the bottom adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Motorola Edge Display Panel Replacement, Heat the right edge: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge Display Panel Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the corner adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick around the bottom-right corner of the phone.
  9. Motorola Edge Display Panel Replacement, Separate the right adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the right adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Separate the right adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  10. Motorola Edge Display Panel Replacement, Remove the back cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the back cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the back cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover, taking care not to damage the components inside the phone.
  11. Motorola Edge Display Panel Replacement, Remove the motherboard's screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  12. Motorola Edge Display Panel Replacement, Remove the motherboard cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the motherboard cover: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the motherboard cover: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  13. Motorola Edge Display Panel Replacement, Disconnect the battery cable's press connector: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the battery cable's press connector: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Motorola Edge Display Panel Replacement, Remove the daughterboard's t5 screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard's t5 screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  15. Motorola Edge Display Panel Replacement, Remove the daughterboard cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
    Where is the speaker location? That's title of this video. Tho I do appreciate the video showing how to open it up.
    Ms. M - crwdns2934203:0crwdne2934203:0
  16. Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  17. Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the daughterboard: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the daughterboard: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  18. Motorola Edge Display Panel Replacement, Remove the interconnect cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the interconnect cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
  19. Motorola Edge Display Panel Replacement, Remove the copper tape: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the copper tape: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the copper tape: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
    What is the function of the copper tape? Looks in the photo like it was ripped. Can this just be put back in place with no ill effect when reassembling?
    Naka J Ishii - crwdns2934203:0crwdne2934203:0
  20. Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
    • Remove the front camera.
  21. Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
    • Remove the wide angle camera.
  22. Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
    • Remove the main camera.
  23. Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
    • Remove the telephoto camera.
  24. Motorola Edge Display Panel Replacement, Disconnect the screen ribbon cable's press connector: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the screen ribbon cable's press connector: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
  25. Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
  26. Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
  27. Motorola Edge Display Panel Replacement, Remove the motherboard: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the motherboard: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the motherboard: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and remove the motherboard.
    • Make sure no cables get trapped under the motherboard during reassembly.
    On my phone, there is another screw on the bottom right holding the motherboard down.
    Ryan Faulk - crwdns2934203:0crwdne2934203:0
  28. Motorola Edge Display Panel Replacement, Disconnect the fingerprint sensor cable's press connector: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the fingerprint sensor cable's press connector: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the fingerprint sensor cable's press connector and disconnect it from the daughterboard.
  29. Motorola Edge Display Panel Replacement, Remove the daughterboard screw: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard screw: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the single 3.2 mm screw securing the daughterboard.
  30. Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the black coaxial cable and detach it from the daughterboard.
  31. Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the white coaxial cable and disconnect it from the daughterboard.
  32. Motorola Edge Display Panel Replacement, Remove the daughterboard: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the daughterboard: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and separate the daughterboard from the rest of the phone.
    • When removing and replacing the daughterboard, be careful not to damage any of the cables that attach to it.
  33. Motorola Edge Display Panel Replacement, Weaken the battery's adhesive: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  34. Motorola Edge Display Panel Replacement, Create a gap between the battery and the frame: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge Display Panel Replacement, Create a gap between the battery and the frame: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Be careful not to damage the screen's ribbon cable, which is located underneath the battery.
  35. Motorola Edge Display Panel Replacement, Switch to a plastic card: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Switch to a plastic card: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Switch to a plastic card: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • After making a gap between the battery and the frame, replace the opening pick with a plastic card.
    • A plastic card will help ensure that the battery is not bent or damaged while being removed.
  36. Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide a plastic card underneath the battery to cut through the adhesive.
  37. Motorola Edge Display Panel Replacement, Remove the battery: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the battery: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the battery: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
  38. Motorola Edge Display Panel Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate and remove the battery from the midframe.
    • If the battery is deformed, dented, or damaged in any way, don't reinstall it. Reinstalling a damaged battery is a potential safety hazard. Replace it with a new one.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the battery.
  39. Motorola Edge Display Panel Replacement, Remove the midframe: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the midframe: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge Display Panel Replacement, Remove the midframe: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone over and remove the midframe while gently threading the screen ribbon cable through the opening in the midframe.
    How do I remove the midframe? Mine is secured with adhesive.
    Quinn Richardson - crwdns2934203:0crwdne2934203:0
  40. Motorola Edge Display Panel Replacement, Replace the display panel: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All that remains is the display panel.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Jennifer Berg
crwdns2935283:003/21/22crwdne2935283:0
2.792 crwdns2915208:0crwdne2915208:0
Hallo, das ausbauen ist wirklich sehr gut dokumentiert und gut nachvollziehbar...Super.
Zum zusammenbauen wären vielleicht noch einige Infos hilfreich. Z.B. das Wiederverkleben.
Mit welchem Kleber und mit welchem Werkzeug kann ich die verklebten Elemente fixieren.
Frage: zu welchem Zweck brauche ich das beidseitig klebende Tesa-Band?
LG Peter
Peter Wollstadt - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 3,052
