Follow this guide to replace your Droid's broken earpiece speaker.
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Heat an iOpener and apply it to the top edge of the phone for a minute.
Angle an opening pick and firmly press so that it slips under the back cover.
Slide the opening pick along the top edge of the phone to break up the adhesive.
Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
Repeat the iOpener heating and slicing procedures for the remaining three sides.
Once you have cut through the adhesive, slowly peel the back cover away from the frame.
Remove the back cover.
Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Use the point of a spudger to pry up and disconnect the flash connector.
Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
Remove the following T3 screws securing the midframe:
Thirteen 3.1 mm black screws
Four 4.3 mm silver screws
Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Insert a pointed end of a pair of tweezers into a corner as far down as possible.
Pry very slightly to help loosen the earpiece speaker module.
Repeat the process in the remaining corners.
Continue to pry with the point of a pair of tweezers until the earpiece module feels loose.
Remove the earpiece module.
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
I replaced my earpiece speaker but the volume is still extremely low. My headphones jack output is also very low when I plug it into and external speaker. Before this happened, This all started after I accidentally got some water on my phone but not enough to drench it. My speaker first sounded distorted when making a phone call and now the volume is so low that I can just barely hear it. Definitely too low to converse with someone. Is the fault in my motherboard? I've cleaned up all the obvious grounding points in my phone. Not sure what else I can check. Thinking about completely disassembling, replacing the ear speaker again doing a hard reset and if all those fail replace the phone. Any thoughts?
