Motor and Pump Assembly Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Motor and Pump Assembly Removal, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Motor and Pump Assembly Removal, Remove the upper shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal, Remove the upper shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Motor and Pump Assembly Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the upper shell straight up off of the machine to remove it.
  4. Motor and Pump Assembly Removal, Remove the right-side cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Motor and Pump Assembly Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Motor and Pump Assembly Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Motor and Pump Assembly Removal, Disconnect the ground wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Motor and Pump Assembly Removal, Disconnect the fuel line: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal, Disconnect the fuel line: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal, Disconnect the fuel line: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Motor and Pump Assembly Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Motor and Pump Assembly Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Motor and Pump Assembly Removal, Disconnect the motor and pump assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal, Disconnect the motor and pump assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Motor and Pump Assembly Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Motor and Pump Assembly Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Motor and Pump Assembly Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Motor and Pump Assembly Removal, Detach the capacitor: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Motor and Pump Assembly Removal: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Motor and Pump Assembly Removal, Remove the motor and pump assembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal, Remove the motor and pump assembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal, Remove the motor and pump assembly: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Motor and Pump Assembly Removal: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Motor and Pump Assembly Removal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the left-side cover.
  20. Motor and Pump Assembly Removal: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Motor and Pump Assembly Removal: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motor and Pump Assembly Removal: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
88,115 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 19
