Moto G6 Plus Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the screen assembly on your Moto G6 Plus, including the midframe which is glued to the display.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Make sure your replacement part includes both the display and the midframe—this guide does not cover separating the display from the midframe.
This procedure involves removing the battery, which should not be reused as it may be damaged during removal. Make sure to reassemble the phone with a new battery.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
Press the tool into the hole to eject the tray.
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
VERY IMPORTANT!
If you don’t buy the original replacement battery, make sure that its size is not wider than 43mm.
The replacement battery that I had was wider and I found it out only at the last step, when I realized that it didn’t fit in… :-(
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Heat the right edge of the back of the phone to soften the adhesive underneath.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Heat the top edge of the back of the phone to soften the rear glass adhesive.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Heat the left edge of the back of the phone to soften the adhesive underneath.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Remove the rear glass.
Use a Phillips driver to remove ten screws securing the upper plastic cover.
Seven 3.2 mm-long screws
Three 2.7 mm-long screws
Insert the flat end of a spudger into the notch on the right edge of the upper plastic cover.
Pry up with the spudger to lift the edge of the upper cover and release the clips holding the cover down.
Remove the upper plastic cover.
The tab, actually, remained glued to the plastic cover, but it worked anyway. We just had to keep them together in step 14
Unfortunately my selfie camera would not fit in the new display. They must have changed the design somewhere along the line.
I would advice to try the fit of upper cover on the new screen before proceeding further.
My uppercover would not fit on the new display.
Since the return postage of the screen was more than the phone was worth I carefully sanded the upper cover with a diamond nail file until it fitted in the new display. I had to remove about 0.4mm
Actually the new screen was 160mm long , the original screen was 162mm.
The phone is working now but it required a lot of care full diamond filing of the case back. And the sim tray sticks out 2mm.
Use the flat end of a spudger to pry up the battery connector and disconnect it.
Very carefully peel up all the black stickers covering the battery.
If possible, keep the tape intact so it can be reused during reassembly.
The largest adhesive film is almost impossible to be kept intact because the outer film de-laminates from the adhesive layer (it is even visible in the second picture here).
The third sticker was not there, in my phone.
Prepare an iOpener and apply it directly to the battery for at least two minutes. Reheat and reapply the iOpener as needed.
Alternatively, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
It would be good, here, to specify that there are 3 strips of adhesive (see second picture of step 17).
I would recommend to only insert opening picks or spudger where the adhesive strips are (in the centre and , in order to avoid scratching the two black strips, as I see also happened here)
Use an opening pick to steadily pry the battery up, starting from the right edge of the battery.
Lift the battery out of the phone case.
Use a Phillips #000 driver to remove six 3.2 mm-long screws securing the lower plastic cover.
Use the point of a spudger to pry the digitizer connecter straight up and out of its socket on the motherboard.
Use the point of a spudger to pry the LCD connector straight up and out of its socket on the motherboard.
Use the point of a spudger to flip up the small locking flap on the ZIF connector on the motherboard.
Gently pull the ribbon cable out of its socket.
Use the point of a spudger to disconnect the front-facing sensor cable.
Gently peel away the large black sticker covering the middle of the motherboard.
Use a Phillips #000 driver to remove two 2.7 mm-long screws securing the motherboard.
Carefully lift the top of the motherboard, keeping it clear of any cables and connectors.
Slide the motherboard toward the top of the phone to remove it from the midframe.
I had trouble getting the self camera to fit. The cable kept unplugging. Any hints?
Not you do not have to remove the battery to take the motherboard out.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to lift the red microphone gasket out of its recess in the midframe.
Gently slide an opening pick under the front-facing sensor cable to slice through the adhesive holding it to the midframe.
Use the opening pick to carefully pry the front-facing sensor array away from the midframe.
Remove the front-facing camera array.
Use the flat end of a spudger to pry up one corner of the earpiece speaker.
Continue lifting the speaker until it is completely separated from its adhesive.
Remove the earpiece speaker.
Use the point of a spudger to pry the vibrator motor and its connector up from the adhesive securing them to the midframe.
Remove the vibrator motor.
Insert an opening pick between the power and volume button circuit board and the midframe.
Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the midframe.
Use tweezers to carefully pull the volume and power button circuit board out of its slot. If it's difficult to remove, make sure you've sliced through all its adhesive.
Use tweezers to lift the two black retaining brackets on either end of the volume and power buttons straight up and remove them from the phone.
Use the point of a spudger to push against the back of the volume button cover, on the upper end of the cover, so that the upper end of the cover slides out of the phone.
Use tweezers to gently remove the volume button cover, pulling up from the upper end.
Use the point of a spudger to push against the back of the power button cover, on the lower end of the cover, so that the lower end of the cover slides out of the phone.
Use tweezers to gently remove the power button cover, pulling down from the lower end.
Only the screen assembly remains.
crwdns2935229:09crwdne2935229:0
Hello, thanks for this great tutorial!⏎
I'm trying to repair a G6 Plus in really bad condition: the rear case has been completely teared apart, and the black stickers that cover the battery as well. All of these are missing, and I was wandering what's the purpose of the upper sticker's tab (step 14)?
I try to find a replacement sticker in many many websites but I cannot find it, so I hope this is not serious. For the moment the replacement screen is acting weirdly (there's light but nothing displays on it), I try to understand if it could be related to this.
Thanks for your answer!
