Midframe Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Midframe Removal, Prepare your controller for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midframe Removal, Prepare your controller for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
    • Due to the controller’s odd shape, it can be helpful to stabilize it as you work. To prevent damage, consider laying it on a soft surface like a cloth or towel.
  2. Midframe Removal, Remove the faceplate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Remove the faceplate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Remove the faceplate: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Magnets secure the faceplace to the midframe.
    • Lift the top edge of the faceplate to release the magnets securing it.
    • Remove the faceplate.
  3. Midframe Removal, Remove the battery cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midframe Removal, Remove the battery cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Weak magnets and two clips along the bottom edge secure the battery cover to the controller.
    • Slide the battery cover away from the controller to remove it.
  4. Midframe Removal, Remove the batteries: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Remove the batteries: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Remove the batteries: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your batteries are starting to corrode, clean the contacts and replace the batteries.
    • Use your fingers to remove the batteries.
    • During reassembly, insert the batteries so their positive (+) and negative () ends match up with the markings on the battery contacts.
  5. Midframe Removal, Heat the battery sticker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midframe Removal, Heat the battery sticker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The sticker in the battery recess hides a back cover screw.
    • If you don't care about damaging the sticker, you can puncture through the center and skip the next step.
    • Use a hair dryer to heat the sticker and soften the adhesive securing it.
    • The sticker can be peeled without heating, but you risk tearing it.
  6. Midframe Removal, Peel up the battery sticker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Peel up the battery sticker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Peel up the battery sticker: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push up a corner of the sticker until you can grab it with a pair of blunt nose tweezers.
    • Use your tweezers to peel up the sticker until the back cover screw is accessible.
  7. Midframe Removal, Unfasten the midframe: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Unfasten the midframe: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Unfasten the midframe: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $36.95
    • Use a T8 Torx screwdriver to remove five 9.3 mm‑long screws securing the midframe:
    • One back cover screw
    • Four screws on top of the midframe
    • Use a T6 Torx screwdriver to remove the two 9.3 mm‑long screws securing the midframe.
  8. Midframe Removal, Unclip the midframe: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Unclip the midframe: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Unclip the midframe: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plastic clips secure the bottom edge of the midframe.
    • Insert the flat end of a spudger between the bottom edge of the midframe and back cover.
    • Pry the midframe up with the spudger to release the clips.
    • Continue prying along the bottom edge to release the remaining clips.
    • Don't try to remove the midframe from the back cover yet—a delicate ribbon cable connects them.
  9. Midframe Removal, Prop up the midframe: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Prop up the midframe: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Prop up the midframe: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put a box or a stack of books to the right of the controller so you can prop up the midframe while disconnecting its ribbon cable.
    • Secure the back cover with one hand, and use your other hand to grip the midframe's left edge.
    • Lift the midframe and rotate it over the right edge of the back cover, so the midframe's right edge is on your workspace.
    • Prop the midframe up, being careful not to strain the ribbon cable.
  10. Midframe Removal, Reassembly information: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Reassembly information: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Reassembly information: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly:
    • Guide the battery connectors on the midframe through their slot in the back cover.
    • Make sure the contacts slide into their grooves in the battery recess. If they aren't in the correct spot, the controller won't receive power.
  11. Midframe Removal, Disconnect the midframe: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal, Disconnect the midframe: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal, Disconnect the midframe: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A very small rubber grommet secures the midframe's ribbon cable to a post on the right side of the back cover.
    • Use blunt nose tweezers to remove the grommet—don't lose it!
  12. Midframe Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midframe Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a clean fingernail to lift the hinged locking flap on the midframe cable ZIF connector.
  13. Midframe Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midframe Removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midframe Removal: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt nose tweezers to grip the black pull tab on the midframe cable.
    • Lift the midframe cable off its post and pull it straight out of its socket.
  14. Midframe Removal, Remove the midframe: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the midframe.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
117.606 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.148crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 34
