Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement
  1. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Prepare your laptop for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Prepare your laptop for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Prepare your laptop for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Flip your laptop over: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Flip your laptop over: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Flip your laptop over: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the lower case screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the lower case screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Detach the lower case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Detach the lower case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Detach the lower case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the lower case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the lower case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the lower case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the Surface Connect port: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the Surface Connect port: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the Surface Connect port: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to flip up the metal buckle on the Surface Connect port connector.
  12. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to grip the Surface Connect port cable and pull it straight out of its socket.
    • During reassembly:
    • Reconnect the Surface Connect port cable.
    • Remove any adhesive liners and press the cable into place to secure it with the adhesive.
  13. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the Surface Connect port screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the Surface Connect port screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the two 3 mm‑long screws securing the Surface Connect port to the top left corner of the frame.
  14. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Separate the cable adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A strong strip of adhesive secures the Surface Connect port cable to the top of the fan. Heating the cable softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the Surface Connect port cable for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer or heat gun. But be careful, as extreme heat can damage the battery.
  15. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • Grip the Surface Connect cable close to the motherboard connector and peel the cable from the fan.
    • Don't secure the trackpad cable with adhesive yet—wait until you've reconnected it. Otherwise, the cable may not reach its socket if positioned incorrectly.
    • If the tape is still sticky, you don't need to replace it.
    • If the adhesive is no longer sticky, or if you're replacing the fan and it doesn't have adhesive, apply a new strip of thin, double-sided tape to the top edge of the fan.
  16. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the Surface Connect port: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the Surface Connect port: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the Surface Connect port: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the Surface Connect port.
    • Put the Surface Connect port into place so its cutouts go over their posts on the motherboard. Make sure the port is fully in its cutout—the outer edge should be flush with the frame.
    • Install the two screws that secure the port.
  17. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the fan: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the fan: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the fan: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift the hinged locking flap on the fan cable ZIF connector, located on the left edge of the motherboard.
    • Use tweezers to grip the fan cable's pull tab and slide the cable out of its socket.
  18. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the speaker cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Disconnect the speaker cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the point of a spudger under the speaker connector (just below the fan cable) and gently lift it straight up and out of the socket.
    • Don't lift on the cables themselves, or you may damage them.
    • During reassembly, hold the connector over its socket and press down gently with the flat end of a spudger until it clicks into place. If you're having trouble, don't try to force the connector into its socket—reposition it and try again.
  19. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to separate the tape from the bottom of the fan and move it out of the way of the speaker cable.
  20. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the speaker cable and gently guide it out of the clips along the edge of the fan.
  21. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the fan: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement, Remove the fan: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the three 4.1 mm‑long screws securing the fan.
  22. Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Laptop 7 (13.8-inch) Fan Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan straight up and remove it.
    • During reassembly, put the fan's three screw holes over their posts on the frame to orient the fan.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
130,442 crwdns2915208:0crwdne2915208:0
crwdns2935297:0884crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023,255crwdne2935297:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 657
