Follow this guide to remove or replace a faulty USB port assembly on a Microsoft Surface Book.
This procedure requires you to remove the back panel. Note: It’s not necessary to remove the SD card to get to the USB ports.
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Straighten out one section of a paper clip.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
You should feel slight resistance when pressing against the internal lever arm. If you don’t feel the resistance after about half an inch, back out and try again. Be careful not to push the paper clip too far, as it can scratch the screen bezel from the inside, leaving a visible mark.
This doesn't work on mine... there's a 90° metal support bracket that covers the entire corner (goes up to about the 8-9th hole on the side) and blocks any & all access to the screen release mechanism. After seeing this "solution" online so many times, I never understood how this worked for anyone else...
I could detach mine following these instructions. When inserting the paper clip you will feel a resistance like pushing a spring. In my case, pushing the paper clip in about 5 millimeters and holding it when I hear a "click" sound. Be sure to grab the tablet when you see it separating (or have at hand a plastic spudger or opening pick to avoid snapping into place again due to the very strong magnets present).
Bonjour,
J’ai suivit les indications telles qu’elles et cela fonctionne parfaitement !
Appuis de « haut vers le bas avec angle de 45deg) comme expliqué.
Merci pour l’astuce. Cela ma permis de me rendre compte que la batterie derrière l’écran n’était pas hs. Apparemment un problème de connexion « clavier-tablette ».
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Remove the display.
Flip the keyboard over so you can see the back panel.
In this photo, there is a clear crevice around the edge of the panel and the keyboard. On my Surface Book, there is no such crevice. The panel is flush up to the keyboard with a gap that looks to be maybe 0.2mm max. There is no way to fit a tool into the crevice to lift off the panel. Any tips?
Insert the plastic opening tool in the crevice between the panel and the keyboard.
Apply some pressure and lift up so that the back panel is pried away from the keyboard.
Continue to lift until the panel is completely separated from the keyboard.
Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
Orient your keyboard with the internals facing up and the USB Port on the right.
Use a plastic opening tool and remove the tab from the USB board
Lift up the black and gold wires and find the screw hidden there.
Use the T3 Torx Screwdriver and remove the four mm screw.
Use the T3 Torx Screwdriver to remove the remaining three 4 mm screws.
Wiggle the USB Port board away from the keyboard.
crwdns2947412:05crwdne2947412:0
But how do you remove and re-attach the ribbon cables without damaging them? Seems like an important detail that is left out.
How do you re-glue the bottom cover back on?
Where do you get the replacement USB board? Is there’s a part number for it that I can look up?
Can the same be done for the type c port
There are quite a few questions raised Tunnel Rush. Maybe I missed a few details in the manual.
