Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement
  1. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the right-side cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  3. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display.
  4. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect all wires from the main PCB assembly:
    • The photocell wire connector labeled CN3 on the board
    • The white wire connector labeled CN2 on the board
    • The orange wire labeled MOTOR1 on the board
    • The igniter wire connector labeled CN1 on the board
    • The yellow wire labeled ACIN1 Yellow on the board
    • The white wire labeled ACIN2 White on the board
    • The red wire labeled MOTOR2 Red on the board.
  5. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of pliers to depress the locking tabs on one of the corner retaining clips securing the PCB to the bracket.
    • With the locking tabs depressed, pull the PCB away from the bracket to remove the corner.
    • Repeat for the three remaining retaining clips.
  6. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the main PCB assembly.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
90.819 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 188
