Mi 11 Battery Replacement
  1. Mi 11 Battery Replacement, Heat the rear glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Mi 11 Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Mi 11 Battery Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
  4. Mi 11 Battery Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Slice the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your Xiaomi Mi 11 to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Mi 11 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Mi 11 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  7. Mi 11 Battery Replacement, Remove the rear glass: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Remove the rear glass: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Mi 11 Battery Replacement, Unfasten the metal bracket screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screws securing the connector metal bracket and the camera cover:
    • Two 4.4 mm-long screws
    • One 4.9 mm-long screw
    • Two 3.9 mm-long screws
  9. Mi 11 Battery Replacement, Remove the metal bracket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Remove the metal bracket: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Remove the metal bracket: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the connector bracket by pulling it in the direction of the battery.
  10. Mi 11 Battery Replacement, Disconnect the flash assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Disconnect the flash assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
  11. Mi 11 Battery Replacement, Disconnect the right battery cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Disconnect the right battery cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery of the Xiaomi Mi 11 has two separate flex cables. You need to disconnect both in order to disconnect the battery completely.
    • Use a spudger to disconnect the right battery cable by prying the connector straight up from its socket.
  12. Mi 11 Battery Replacement, Remove the camera cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Remove the camera cover: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or a pair of tweezers to carefully lift the camera cover including the flash assembly off the camera lenses and remove it.
  13. Mi 11 Battery Replacement, Unfasten the motherboard cover screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the motherboard cover.
  14. Mi 11 Battery Replacement, Pry up the motherboard cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Pry up the motherboard cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick underneath the bottom left edge of the motherboard cover.
    • Slide the opening pick along the left edge of the motherboard cover and pry it up.
  15. Mi 11 Battery Replacement, Remove the motherboard cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Remove the motherboard cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard cover.
  16. Mi 11 Battery Replacement, Disconnect the left battery cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Disconnect the left battery cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the left battery cable by prying the connector straight up from its socket.
  17. Mi 11 Battery Replacement, Disconnect the left interconnect cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Disconnect the left interconnect cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the left interconnect cable by prying the connector straight up from its socket.
  18. Mi 11 Battery Replacement, Disconnect the right interconnect cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mi 11 Battery Replacement, Disconnect the right interconnect cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the right interconnect cable by prying the connector straight up from its socket.
  19. Mi 11 Battery Replacement, Free the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Free the battery: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Free the battery: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During the following step do not fold the cables sharply and only bend them to avoid cable damage.
    • Fold the interconnect flex cables towards the charging port in order to get access to the battery pull tabs.
    • You might want to use a small piece of tape to temporarily stick the cables onto your working surface to avoid accidentally damaging them during the battery removal.
  20. Mi 11 Battery Replacement, Peel off the battery pull-tabs: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Peel off the battery pull-tabs: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Peel off the battery pull-tabs: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with an A off the battery.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with a B off the battery.
  21. Mi 11 Battery Replacement, Remove the battery: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Remove the battery: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mi 11 Battery Replacement, Remove the battery: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab both pull–tab ends labelled with an A and pull up on the orange adhesive strip to lift the battery out of its recess and swing it up to an upright position.
    • Although these adhesive tabs are supposed to make the battery removal easier, they may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display to loosen the adhesive underneath.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
    • In case you're replacing the adhesive sticker with a new one, peel the battery's adhesive sticker off the midframe and clean the relevant areas with isopropyl alcohol (>90%). Let the alcohol dry before installing new adhesive.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2935229:014crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237 957 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022 008crwdne2935297:0
I come from china. I follow this step and successfully replace battery. Thanks a lot!
zhuo lin - crwdns2934203:0crwdne2934203:0
Wozu ist denn das weiße Kabel am rechten Rand des Handys? Habe das versehentlich beim öffnen gekillt. Aber ich konnte noch nicht heraus finden was jetzt nicht mehr funktioniert. 😅
Kati - crwdns2934203:0crwdne2934203:0
Das ist das so genannte Killerkabel.
Ist nur dazu da, dass man sieht, dass schon mal jemand an dem Gerät rumgepfuscht hat.
Hansi -
Succesfully replaced battery with help of the great guide. Thank You !
quantum - - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 146
crwdns2936753:030crwdne2936753:0 635
crwdns2942667:0crwdne2942667:0 30,234
