Here's a chip identification summary for the Meta Quest 3 headset and controller.
Check out our Meta Quest 3 teardown for more details.
Special thanks to community member CChin for his contribution!
crwdns2936621:0crwdne2936621:0
Qualcomm SXR2230P-100-AB Snapdragon XR2 gen 2 applications processor
Likely SK hynix H58G66BK8BX105 8 GB LPDDR5 SDRAM memory
AKM Semiconductor AK4333ECB 32-bit stereo audio D/A converter
Probably Triad Semiconductor TS5231 IR analog front end
Qualcomm WCN6856-102 Wi-Fi 6E SoC
Qorvo QM42391 2.4 GHz Wi-Fi 6E front-end module
Qorvo QM45392 5 GHz Wi-Fi 6E front end module
Nordic Semiconductor nRF52833 Bluetooth Low-Energy 5.4 SoC
SK hynix HN8T05DEHKX073 128 GB NAND flash memory
Qualcomm PMXR2230B-001 power management
Qualcomm PMXR2230-001 power management
Qualcomm PMXR2230VE-001 power management
Qualcomm PMXR2230VS-001 power management
Likely Qualcomm clock generator
STMicroelectronics STM32G071EB 32-bit ARM Cortex-M0+ microcontroller
Silicon Labs EFM8BB51F8G 8-bit microcontroller
Infineon CYPD3177-24LQXQ USB Type-C port controller
Analog Devices MAX98388 mono class-D audio amplifier
Texas Instruments TPS65132L dual output power supply
SG Micro SGM62110 2.5 A buck-boost converter
STMicroelectronics LM324QT quad operational amplifier
Microchip ATSAMD21G17D 32-bit ARM Cortex-M0+ microcontroller
Analog Devices MAX98361AEWL+ 3.2 W audio amplifier
SG Micro SGM6601 DC-DC boost converter
Monolithic Power Systems MP3414 1.8 A synchronous step-up converter
Nordic Semiconductor nRF52820 Bluetooth Low-Energy 5.4 SoC
TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope
Allegro MicroSystems A1392 hall effect sensor
Allegro MicroSystems A1393 hall effect sensor
Do you have any information on Quest 3's depth sensor?
I have a guess: it could be the new VD55H1 from STMicroelectronics. For my own project I want to use the VL53L5CX, a much simpler sensor.
I've tried to find more information about the TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope..
But I have only found information and a place to order replacement model ICM-42688-P. Do any of you know of these are the same?
Are you saying there is no IMU on the main board?!?!
