MacBook Pro 15" Logic Board's Power Input Circuit Repai
lemmirocketmotor
crwdns2944107:0crwdnd2944107:0lemmirocketmotorcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 22, 2019crwdne2944111:0
crwdns2931287:045crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937595:0crwdne2937595:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
If you use a power adapter which is to weak for your Mac Book (e.g. 60W for a MBP 15" which is specified for a 80W power adapter) the following should happen from a theoretical point of view: The power adapter is overloaded and heats up until the internal thermal protection switches it off savely. -- And this happened in real live: The adapter blew up in a way, that it delivered one last powerful current pulse which also destroyed parts of the logic board. The Mac Book is still fully operational with battery, but can not be charged nor powered any more, even with a new power adapter.
The disassembling steps are referenced to MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement. For this particular guide it is not necessary to unmount the fans, heatpipes and speaker-microphone-block. Just skip the related steps.
Since the topology of the circuit between power connector and battery is common technique, this guide might fit to other logic boards too.
crwdns2944105:0crwdne2944105:0
  1. MacBook Pro 15" Logic Board's Power Input Circuit Repai, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
    Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
    Bizarre much?
    Will - crwdns2934203:0crwdne2934203:0
    It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
    Andrew Janke -
    I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
    xtophr -
    I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
    leonie - crwdns2934203:0crwdne2934203:0
    Great advise! Love it! :)
    Ririds -
    I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
    Now I use these:
    http://www.sciplus.com/p/50-114-CLEAR-PL...
    The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
    Richard Sato -
    I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
    Roscoe -
    I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
    jelimoore -
    Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
    maccentric -
    I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
    Nils -
    @Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
    Roger - crwdns2934203:0crwdne2934203:0
    Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
    So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
    wresnick - crwdns2934203:0crwdne2934203:0
    Hi,
    Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
    H Stahl -
    MacBookPro8,2
    Intel Core i7, 2,2 GHz, RAM 16 GB
    Mountain Lion
    May someone help me?
    I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
    Piero - crwdns2934203:0crwdne2934203:0
    To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
    1982sketcher -
    Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
    - zerø K
    zeroK - crwdns2934203:0crwdne2934203:0
    These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
    Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
    Thanks!
    Marcos - crwdns2934203:0crwdne2934203:0
    During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
    kusi - crwdns2934203:0crwdne2934203:0
    There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
    Print the repair guide.
    Yes, the actual photo of the bottom of the laptop with the circles around the screws.
    When you remove the screw, tape it to the photograph.
    You will tape the screw to the exact location that you just removed it from.
    Same thing with any part you remove.
    splashzoneent - crwdns2934203:0crwdne2934203:0
    Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
    Tommy Kedar -
    Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
    nclarke36 -
    Worked like a charm! Took less than 20 minutes.
    It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
    SUNON MG62090V1-Q020-S99 .
    SOME TRICKS -
    1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
    2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
    3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
    cheers- Durango CO!
    Dgodrummer - crwdns2934203:0crwdne2934203:0
    Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
    kevicoll409 - crwdns2934203:0crwdne2934203:0
    The link above is no longer available.
    Kristina Graham -
    I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
    Pete Banks - crwdns2934203:0crwdne2934203:0
    The instructions say that I am removing PH00 screws. I found that my MBP, mid ‘12, Retina has pentalobe screws instead!
    jsandersonq - crwdns2934203:0crwdne2934203:0
    This laptop definitely originally shipped with Phillips screws—but, Apple has been known to replace Phillips screws with pentalobes when one of their devices is brought in for service. Sorry for the rude surprise! Fortunately the correct driver is easy to find nowadays. [Blatant self-promotion alert!] If you support free repair manuals, consider picking one up from iFixit. Good luck!
    Jeff Suovanen -
    Me, too, and it’s plausible that this machine has been serviced by Apple in the past, replacing the screws as Jeff Suovanen suggests.
    iFixit shipped a pentalobe bit with the kit, but it’s too large for the actual screws, so it looks like I now need to get another bit. But what size?
    Jeff’s link is to a driver with a P5 bit, and that page links to a P2 screwdriver, but since I don’t know what size I actually need (and I don’t have a micrometer to hand) I’m reluctant to buy two on spec.
    Norman Gray -
    (The bit in the kit appears to be a P6, so I’m inclined to order a P5 and see what happens)
    Norman Gray -
    You’re using the wrong repair guide. This guide is for the 2012 NON-Retina MBP. You have a Retina MBP. The stock case screws in the 2012 NON-Retina are all Phillips, just as the guide says.
    Steven Wymor -
    To keep track of screws, I used the suggestions above by taping a photo of the lower case to a piece of corrugated cardboard and inserting/taping the screws in place. Also, as some have noted, the screws go back in at a slight angle; they are angled toward the center of the unit.
    Kristina Graham - crwdns2934203:0crwdne2934203:0
    If your vision, like mine, is getting too fuzzy to be able to distinguish between a tiny Phillips screwdriver and a tiny Tri screwdriver, there’s an easy way. With a Phillips (or a Pozidrive) you can get two opposite wings to reflect the light from a lamp or window straight towards your eye at the same time. With a Tri (or Penta) you can only get one wing to reflect at a time, however much you twiddle it.
    Alan Waller - crwdns2934203:0crwdne2934203:0
    There’s a very easy way to avoid cross-threading a screw thread, any size.
    Put the screw into its hole and start by turning it gently, slowly BACKWARDS. When you hear a little “Click!” sound, the male thread has just passed the opening in the female thread and is in exactly the right position to enter into it correctly when you start to turn in the correct forward direction.
    Remember, all drivers except hex (Allen key) and TorX need pressure to avoid slipping out and damaging the head. So even when you want to turn it in with LOW moment/torque, keep the CONTACT PRESSURE high.
    The keep the pressure on is on point. In my case once I loosened my first screw I thought I could relief my initial pressure. It was a mistake. I was doing the whole thing very slowly as a precaution. That helped me notice that the Phillips screw driver was sliding up out of the screw head. Not being sure why, I put pressure back on the screw driver until almost all the screw was out of the hole. Once out, I examined closely to find out that the threads have some sort of coating. It looks to me like some kind of locktite. Then I understood the importance of keeping the pressure on all the way through. It made me uneasy having to keep so much pressure on such tiny screws, but I found it was the only way to prevent damage to the “slots” on the heads. Anyway, all of them suffered some degree of damage, but I was able to successfully remove them and reinstall all of them back in their original holes.
    Martin Mejia -
    After reading this page on iFixit several times, I just could not face all the work of replacing the Logic Boards on two MacBookPro 2011s even if I was prepared to pay approx 400 USD (which I wasn’t). Then I read the reviews of a couple of folks who’d stripped down their machines and put their logic boards in the oven and, it worked! I wondered, if I just used my new Steinel Hot Air Tool (heat gun in my language) recently delivered from iFixit, on the logic board in-situ, without removing it? So I removed the battery, hard drive, and RAM and unplugged all the leads I could see WITHOUT removing anything else physically. Then using the 500 degrees set on the gun (setting 2) I ‘played’ the gun over the logic board for about 60 seconds on machine one with the restart problem (plus latterly, not completing start-up). Long story short… it worked! I spent a long time getting the s/w to load, but the commentary is too short to let me relate that part… ping me if I can help you do the same! blackaye@gmail.com
    Ian Black - crwdns2934203:0crwdne2934203:0
    FTR (Thanks to @swymor for the clue, albeit 3+ years ago).
    FYI, the MBP 15" RETINA guide is here: MacBook Pro 15" Retina Display Mid 2012 Battery Replacement
    Chris Weekly - crwdns2934203:0crwdne2934203:0
  2. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    What is the maximum amount of RAM that can be installed in this MacBook?
    michael - crwdns2934203:0crwdne2934203:0
    16 GB is the max
    Bradon Kelley -
    I can’t get the back panel off !! Removed all 10 screws but the panel is still on. Not a quick easy lift like in the picture of videos on youtube what going on…are the hidden screws locking tabs?
    Tachyon - crwdns2934203:0crwdne2934203:0
    Solved the tabs were hard to get off to the point I thought I was going to bend the back case off before it would let go.
  3. MacBook Pro 15" Logic Board's Power Input Circuit Repai, Logic Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three T6 Torx screws securing the right fan to the upper case.
    on my screwdriver set, the T6 screw driver felt wobbly. It felt like I would strip the screw if not careful. So I used a T7 screw driver, and it was much more snug.
    Bryan Chun - crwdns2934203:0crwdne2934203:0
    Same here. T6 did not fit at all. Too small.
    Bummer. Will have to screw my MBP back together and get a T7 on Monday…
    Oliver Nielsen - crwdns2934203:0crwdne2934203:0
  4. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the right fan connector up out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • Remove the right fan from the upper case.
    There is no way to reconnect the fan cable. It looks like it was soldered onto the logic board. I disconnected it and can't reconnect it.
    Has this happened to anyone else.
    Vicki - crwdns2934203:0crwdne2934203:0
    Vicki, you tore the connector off the board. They can be re-soldered if you are very careful/skilled with a soldering iron, but that is not something that you should try to do if you haven't soldered SMD components before.
    rcoleskelton - crwdns2934203:0crwdne2934203:0
  5. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the AirPort / Bluetooth ribbon cable up off its socket on the logic board.
    • Fold the AirPort / Bluetooth ribbon cable back to keep it out of the way of the logic board.
  6. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the iSight cable by pulling its connector toward the optical drive opening.
    I was afraid to pull too hard, but wiggling it worked! :)
    Mark - crwdns2934203:0crwdne2934203:0
    This is NOT good advice, ifixit! You should never pull a cable but rather pull or push its connector. In this case, it went well for me the first time, but the second time I pulled the cable out of its connector and now my iSight camera is not working anymore. Thanks, ifixit. Not!
    Rather, use plastic (so you don’t short-circuit anything) tweezers or two tooth-picks or so and push the connector out of its socket.
    That’s actually who it’s described in Apples repair manual for this device that — I think — I also found on this webpage somewhere.
    So: PUSH, don’t pull!
    Colonel Task - crwdns2934203:0crwdne2934203:0
  7. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the optical drive cable connector up from the logic board.
    • Fold the optical drive cable back to keep it out of the way of the logic board.
    hello i just installed a brand new logic board in my mac, in my mac i have replaced the cd drive with an second ssd - but when i turn the mac on, the OS cant find the second ssd, the cable is in (it clicks in) - does anybody know how to fix this or ?
    Best regards Mathias
    mathiastondering - crwdns2934203:0crwdne2934203:0
  8. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the subwoofer/right speaker cable up to lift its connector out of its socket on the logic board.
    Same problem as with step 11. I pried up the connector as shown and can't reconnect it. It looks like it may have been soldered to the logic board. How can this be fixed?
    The only problem that I face on substituting the top case was when I tried to connect the subwoofer connector to the socket on the logic board. I did some tentatives but on the last the socket on the logic board I suppose unsoldered. Some suggestions?
    Thanks
    Paolo Sperati
    paolosperati63 - crwdns2934203:0crwdne2934203:0
    I did step 16 (disconnecting the hard drive cable) first and then came back to this step - worked for me
    Colin White - crwdns2934203:0crwdne2934203:0
    This connector is just like the ones used for the fans (but has a cushion-like protection over it). Just take it apart just like in steps 8 and 11.
    Andres Lartitegui - crwdns2934203:0crwdne2934203:0
  9. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the hard drive cable connector up out of its socket on the logic board.
  10. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two short Phillips screws securing the small EMI shield to the logic board.
    • Remove the EMI shield from the logic board.
    Mine was stuck to the Keyboard Ribbon Cable; needed an extra pull, but it's safe and should come off - it's not attached to anything. :)
  11. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the trackpad cable connector up out of its socket on the logic board.
  12. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to carefully flip up the keyboard ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable straight out of its socket.
    How will I know I have inserted the keyboard ribbon successfully? After installing a new upper case I can't seem to get the keyboard ribbon to stay in its socket. Or does the EMI sheild hold it in place?
    Cem Catikkas - crwdns2934203:0crwdne2934203:0
    Ditto. It seems very tricky to reinsert the keyboard ribbon.
    GrooveStomp - crwdns2934203:0crwdne2934203:0
    I just did this - it is kinda tricky. The ribbon cable has a flap on top that is designed solely to help you coax the cable back into the socket....don't make the mistake I did and spend an hour trying to feed this flap through the socket. What worked for me was a combination of using the flap with my fingers and tweezers on the actual cable to reinsert it into the socket. Took a few tries, but I got the cable re-inserted, pressed down on the tiny locking thing, and the keyboard cable was in and secured.
    dave - crwdns2934203:0crwdne2934203:0
    Indeed, it is difficult to insert the keyboard ribbon cable. It will stop after about 1mm of insertion. It needs to go in quite a bit further. Angling it slightly, you may be able to get a corner to go in, then straighten the ribbon while applying forward pressure. I reassembled it a few times with that sinking feeling on startup before I realized that it wasn't really making contact!
    dennishodge - crwdns2934203:0crwdne2934203:0
    I've replaced the keyboard, so reinserting the ribbon was particularly tricky. After several failed attempts, here's what finally dawned on me... I took a piece of scotch tape, maybe an inch long. I folded on end on itself, maybe a quarter inch from the top. That left a sticky zone and a non-sticky zone on the tape. I taped it to the ribbon, and was able to use the tape and a "handle" to pull the ribbon into the socket. Afterwards, I carefully removed the tape without pulling the ribbon out of the socket.
    This was the hardest part for me. Be sure you flip the release flap up before removing or re-inserting.
    Jonathan Daiello - crwdns2934203:0crwdne2934203:0
    This might be obvious to some, but for those for whom it is not, this info is very important. First: only the ribbon is what needs to be pulled out (and inserted later on) not any of the black plastic casing. Second: before you try to pull the ribbon out, you need to flip up the release flap so its vertical (this is the thin black part that is located on the top edge of the black casing). If you don’t do this you will damage the casing or the ribbon or both.
    Greg - crwdns2934203:0crwdne2934203:0
    Vraiment dommage que ce point de blocage très sensible ne soit pas plus développer, il peut compromettre tout le travail et l’état de la machine, c’est la grosse erreur de ce tuto.
    Pour l’instant, je ne suis pas parvenu à retirer ce connecteur et je crains que l’impatience me fasse commettre une erreur irréparable.
    pc-design - crwdns2934203:0crwdne2934203:0
    the flap mentionned is the plastic part the most far to the ribbon, not the part where the finger seem to be pulling. The flap comes off easily.
    Paraita Wohler - crwdns2934203:0crwdne2934203:0
  13. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the battery indicator cable connector up out of its socket on the logic board.
    Can anyone tell me what the little gold-colored button or switch is on the left side of the cab let connector?
    michael crawford - crwdns2934203:0crwdne2934203:0
    On mine, the plastic tab was almost completely hidden under some fabric-like tape on top of connector.
    Make sure to grab only the glossy plastic tab and pull it up, which rotates upward a metal hinge on the removable part of the connector. That metal hinge is then used as a handle to pull the connector straight out (flat) toward MagSafe.
    I didn’t see the plastic tab, and first pulled up the tape. That caused the metal hinge to pop off. Upon close inspection, it was easy to see where the hinge attached at each end to the top assembly. whew!
    prreitz - crwdns2934203:0crwdne2934203:0
  14. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket.
    • Do not pull the cable upward, as the socket is very fragile. Pull the cable parallel to the face of the logic board toward the corner of the upper case.
    One of the chips in this image was covered in glue. when I flipped the data cable clip, the glue plus encased chip popped right off the board. Does anyone know what chip this is? Without it, my Mac plays the startup chime, but the screen is black. The backlight is on, but it just displays black.
    https://www.dropbox.com/s/befonnaz125fn9...
    Jon - crwdns2934203:0crwdne2934203:0
    I did the exact same thing. I still have the tiny chip. Is there a way to glue it back on or will I need a new logic board now?
    Louis Adams - crwdns2934203:0crwdne2934203:0
    There's a bracket / handle clip attached to the display port. I didn't know it was there and accidentally bent it off. Can't get it back on, but it seems to work OK without it.
    The pull tab has a small rectangular frame. I used this to gently pull out the plug with both hands, rather than pulling on the cable like in the photo. This worked well.
    Bryan Kring - crwdns2934203:0crwdne2934203:0
  15. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket.
    I couldn’t see the flap as mine was already popped up. Try looking at it from the side to get a better view of the state of yours.
    Cyrille - crwdns2934203:0crwdne2934203:0
    I did too. The whole connector actually popped off the board. Were you able to fix yours?
    Dylan -
    I posted a question on this as well. I have an Early 2013 Macbook Retina, and I accidentally popped off the flex cable connectors to the fans. From doing some research, it seems like you can solder it back on but I have no experience in that. Would anyone know where to start, and where to get the tools?
    Tif - crwdns2934203:0crwdne2934203:0
  16. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws:
    • Seven 3.3 mm T6 Torx screws securing the logic board to the upper case.
    • Two 8 mm T6 Torx screws securing the DC-In board to the upper case.
    • Do not remove the logic board yet! There are components on the underside of the logic board attached to the the upper case that must first be disconnected.
  17. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
    • Do not entirely remove the logic board yet!
    I just took one apart that had some pretty strong adhesive holding the speaker onto the upper case. I had to slip a spudger underneath and pry it up, else it was going to overly bend the mobo before it would release.
    jkamis - crwdns2934203:0crwdne2934203:0
    My board was stuck to the bottom plastic. I had to gently release it by pushing the black plastic beneath the board down, while carefully moving the board upward.
  18. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
    On this step, the microphone was attached to the board so the whole unit lifted off easily.
    seandodd - crwdns2934203:0crwdne2934203:0
    Mine was too; it was part of the speaker assembly, a much better arrangement.
    maccentric -
    me too on model number A1286
    mid 2009
    15 inch
    Balloon Wrangler - crwdns2934203:0crwdne2934203:0
    I have a Mid 2010 15 inch and had one more connection in the corner that needed to be removed, so be careful!!
    Scott Hopper - crwdns2934203:0crwdne2934203:0
  19. MacBook Pro 15" Logic Board's Power Input Circuit Repai: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the logic board away from the port openings and lift the assembly out of the upper case.
    • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
    • To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
    After prying off the mic from the top case and carefully lifting the logic board, I realized there was still a wire connected near the display connector, under the board. I was able to disconnect it but I'm wondering if I missed something or if this cable is missing from the instructions. The wire was connected under the board so it could not be disconnected before removing the board.
    Laurent Daudelin - crwdns2934203:0crwdne2934203:0
    This is the magsafe cable. Step 23 details removing the torx screws holding the magsafe board in place. If you remove the screws, you don't need to remove the cable.
    supersuade - crwdns2934203:0crwdne2934203:0
  20. MacBook Pro 15" Logic Board's Power Input Circuit Repai, The schematic: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The picture shows a schematic which is similar to Mac Book Pro's power input circuit. The series components L1, F1, T1, T2 have to draw the full power, so those are of interest for us. With an ohmmeter you can check these parts.
    • L1: Since I could not figure out the manufacturer of this common mode choke I recommend to use a new MagSafe PCB.
    • F1: According to the printing on this part it is very likely that this is a Littelfuse 0469006 6A fuse.
    • T1, T2: Both MOSFETs are HAT1128R type. Since this part is obsolete I took IRF9317PbF
  21. MacBook Pro 15" Logic Board's Power Input Circuit Repai, Where are the parts?: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The picture shows where the relevant parts are placed on the logic board. F1, T1 and T2 are marked green. L1 is mounted on the MagSafe PCB and so not seen on the picture.
    • After you have figured out which of these parts (L1, F1, T2, T2) are defective you can change them. I recommend to replace both MOSFETs if there is at least one damaged.
    • After replacing the defective parts you can check the functionality by connecting the battery and the power adapter to the logic board. If everything is fine the LED of the MagSafe connector will light up green and switch to orange if battery will be charged. Be very careful.
To reassemble your device, follow the prerequisited guide in reverse order.
crwdns2935229:017crwdne2935229:0
lemmirocketmotor
crwdns2935283:003/21/15crwdne2935283:0
543 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
I don't know if any 80w MagSafe. It should be 85w for 15" and 60w for 13"...
mamashannon4u - crwdns2934203:0crwdne2934203:0
Is there any chance you would be able to show the location of these parts if the same thing happened on a 2012 MacBook Pro Retina? I've been trying to find the information for a couple days now. Thank you
Nick - crwdns2934203:0crwdne2934203:0
I can’t find T1 and T2. My board is little different from the picture . Mine’s 2011 or 12 i7 processor. Please help!
chonghak Kim - crwdns2934203:0crwdne2934203:0
Admirable ! and the pics can be enlarged a lot ! thank you!
Isaac OLEG - crwdns2934203:0crwdne2934203:0
How do you measure the mosfets
shk3ul !0An - crwdns2934203:0crwdne2934203:0
hello i have a problem in my power suply of macbook is 20v . when i opened it and i made a test i found just 3volt . can some help me if someone has a electronic diagram
enjoy life - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 140
crwdns2942667:0crwdne2942667:0 47,088
