MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement
  1. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Prepare your MacBook for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Prepare your MacBook for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Prepare your MacBook for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug all cables and fully shut down your MacBook.
    • Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
    • Opening the lid will power on your MacBook. If you're using macOS Big Sur v11.1 or earlier, disable this function using this guide.
    "Allowing battery...10%...catch fire" is scare mongering. If someone is so brutal they are puncturing holes in anything on the laptop, they have no business opening the case in the first place. Computer repair is a delicate process. The batteries are not gunpowder. If they were prone to explode into flames that easily they would not be in the laptops in the first place. Due caution is warranted--but it is impractical and unnecessary to wait for a battery to discharge. Unhook it immediately, and be done with it.
    B. A. Computer Services - crwdns2934203:0crwdne2934203:0
  2. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.8 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
  3. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Separate the lower case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Separate the lower case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
  4. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the left clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick between the lower case and the frame.
    • Slide the pick around the left corner to release the first set of clips.
    • You'll hear and feel a pop when each clip releases.
  5. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the right clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the right clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the right clips: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick around the right corner to release the second set of clips securing the lower case.
  6. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Pry the lower case up: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Pry the lower case up: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Pry the lower case up: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your opening pick between the lower case and the frame near the middle left screw hole.
    • Firmly twist the pick until the clip releases.
    • Repeat this procedure for the clip near the middle right screw hole.
  7. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the remaining clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the remaining clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Release the remaining clips: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
    • This motion requires significant force. Don't pull the lower case up, as you may bend the clips.
    • If it feels stuck, pull one corner at a time.
  8. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the lower case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the lower case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
    • Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
    • You'll hear and feel a pop when each clip engages.
  9. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the battery board cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the battery board cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt nose tweezers or your fingers to peel and remove the cover from the battery board, just above the middle battery cell.
  10. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the battery data cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the battery data cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt nose tweezers to gently peel back the pull tab covering the battery data connector.
    • Don't remove or tear the pull tab, as it's attached to the head of the connector.
  11. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to flip up the small locking tab securing the battery data connector.
    • Locking tabs on ZIF connectors are fragile—be gentle with your spudger.
  12. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt nose tweezers or your fingers to grab the battery data cable pull tab and slide it straight out of its socket.
    • Move the cable to the left, out of the way of the battery board.
    • Don't strain the cable, as it's still attached to the battery board.
  13. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the battery connector: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.7 mm screw securing the battery connector.
  14. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your spudger to slightly lift the battery connector away from the battery board.
    • Lifting the connector too high will break it. Angle it enough so it won't accidentally contact the battery board during repair.
    • Optionally, you may insert a barrier, such as a piece of a playing card, between the connector and the board during the repair.
  15. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the left cable bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the left cable bracket: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the left cable bracket: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your T5 Torx driver to remove the two screws securing the left cable bracket to the logic board:
    • One 3.6 mm screw
    • One 2.6 mm screw
    • Remove the bracket.
  16. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the interconnect cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the interconnect cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of your spudger to pry up and disconnect the left interconnect cable.
  17. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the antenna cable cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the antenna cable cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel and remove the plastic cover from the antenna cables.
  18. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the antenna bar: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the antenna bar: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the antenna bar: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the antenna cables from the logic board.
    • Pry on the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • To reconnect the cables, align the connectors directly over their sockets and press down with the flat end of a spudger until they snap into place.
  19. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the antenna cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your T5 Torx driver to remove the 3.4 mm screw securing the antenna cables to the logic board.
  20. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the logic board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the logic board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the logic board: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip up the small locking tab securing the right speaker connector.
    • Grab the pull tab on the head of the cable and slide it straight out of its socket.
  21. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the trackpad cable bracket: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the trackpad cable bracket: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable bracket.
  22. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the trackpad: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the trackpad: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of your spudger to pry up and disconnect the trackpad cable from the logic board.
  23. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the seven remaining ZIF connectors from the logic board by lifting their locking tabs and pulling them straight out of their sockets.
  24. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the right cable bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the right cable bracket: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the right cable bracket: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your T3 Torx driver to remove the three 1.4 mm screws securing the cable bracket to the top right of the logic board.
  25. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the top right press connectors: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the top right press connectors: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Disconnect the top right press connectors: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the Touch Bar press connector from the top right of the logic board.
    • Repeat this step for the lid angle sensor and the Thunderbolt ports press connectors.
  26. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the top left cable cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the top left cable cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the top left cable cover: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your T3 Torx driver to remove the two screws securing the cable cover near the headphone jack:
    • One 1.4 mm screw
    • One 4.9 mm screw
    • Remove the cover.
  27. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the logic board: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the logic board: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws securing the logic board:
    • One 3.0 mm hex head screw
    • One 3.7 mm T5 Torx screw
    • Three 3.3 mm T5 Torx screws
    Okay, missing step: you need to remove the two screws holding down the trackpad.
    Jadon Lyon - crwdns2934203:0crwdne2934203:0
    Hi Jadon! Thank you for the feedback. I'd like to better understand your suggestion. Are you referring to the screws securing the trackpad cable to the logic board?
    Clay Eickemeyer -
    Can confirm. Missed the trackpad bracket and cable by the battery and the display (I think it's the display cable?) brackets and cable, up top. I had to remove those extras in order to fully extract the logic board.
    River7567 - crwdns2934203:0crwdne2934203:0
    I've added the missing step, thank you Jadon and Stephanie for bringing this up!
    Clay Eickemeyer - crwdns2934203:0crwdne2934203:0
  28. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Reassembly information: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Reassembly information: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Reassembly information: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Your 3.0 mm nut driver may be too long to thread the hex head screw in. Use one of the following techniques to begin threading the screw in:
    • Thread the screw in using your fingertips.
    • Thread the screw in using blunt nose tweezers.
    • Use your T3 Torx driver to install the 1.4 mm screw into the hex head screw. Then, install the hex head screw using the T3 Torx driver. Finally, hold the hex head screw while you remove the 1.4 mm screw.
    • Once the hex head screw is threaded in a few turns, tighten it using your nut driver.
  29. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Pry up the logic board: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Pry up the logic board: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of your spudger between the bottom left of the logic board and the left speaker assembly.
    • Pry up on the logic board until you can grab it with your fingers.
  30. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the logic board: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the logic board: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the logic board: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom left edge of the logic board.
    • Pull the logic board down and left to free it from the press connectors and antenna cables in the upper right corner.
    • Lift the logic board out of its recess, making sure not to catch on any loose cables.
    • During reassembly, make sure all 15 connectors are above the logic board before reinstalling it.
  31. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the spring contacts: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a P2 Pentalobe driver to remove the two 1.2 mm screws securing the spring contacts to the Thunderbolt ports.
  32. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the spring contacts: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the spring contacts: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the spring contacts: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to carefully grab and remove the spring contacts from the Thunderbolt ports.
  33. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Unfasten the Thunderbolt ports: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your T5 Torx driver to remove the two 2.9 mm screws securing the Thunderbolt ports to the frame.
  34. MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the Thunderbolt ports: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the Thunderbolt ports: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 13" 2022 (M2) Thunderbolt Ports Replacement, Remove the Thunderbolt ports: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and slide the Thunderbolt ports out from their recess in the frame.
    • Remove the ports.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
85,757 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,160crwdne2935297:0
A minor but important missing part of this guide is removing the display cable near the top center of the logic board, if you attempt to remove the logic board without disconnecting the 4 screws and detaching the video cable you may damage your logic board or display cable, I'm sure the guide writer had this in rough drafts and just forgot to insert it
John Ellmaker - crwdns2934203:0crwdne2934203:0
Seconded, this is very very important and should be fixed!
Lukeshields -
I just damaged mine! ☹️ This article really should be updated!
Mark -
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 304
crwdns2942667:0crwdne2942667:0 5,364
