MacBook Air 13" Mid 2012 Battery Replacement
  1. MacBook Air 13" Mid 2012 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - crwdns2934203:0crwdne2934203:0
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - crwdns2934203:0crwdne2934203:0
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - crwdns2934203:0crwdne2934203:0
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - crwdns2934203:0crwdne2934203:0
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - crwdns2934203:0crwdne2934203:0
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - crwdns2934203:0crwdne2934203:0
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - crwdns2934203:0crwdne2934203:0
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - crwdns2934203:0crwdne2934203:0
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - crwdns2934203:0crwdne2934203:0
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - crwdns2934203:0crwdne2934203:0
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - crwdns2934203:0crwdne2934203:0
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - crwdns2934203:0crwdne2934203:0
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - crwdns2934203:0crwdne2934203:0
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - crwdns2934203:0crwdne2934203:0
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - crwdns2934203:0crwdne2934203:0
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - crwdns2934203:0crwdne2934203:0
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - crwdns2934203:0crwdne2934203:0
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - crwdns2934203:0crwdne2934203:0
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - crwdns2934203:0crwdne2934203:0
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - crwdns2934203:0crwdne2934203:0
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - crwdns2934203:0crwdne2934203:0
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - crwdns2934203:0crwdne2934203:0
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - crwdns2934203:0crwdne2934203:0
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - crwdns2934203:0crwdne2934203:0
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - crwdns2934203:0crwdne2934203:0
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - crwdns2934203:0crwdne2934203:0
    Fot All People ha ing trouble finding their SSD
    DONT PRESS CMD +R + POWER
    instead press
    OPTION+CMD+R +POWER
    I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
    Albert - crwdns2934203:0crwdne2934203:0
    IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
    This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
    Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
    Good luck. - Eric J.
    ECJohansen - crwdns2934203:0crwdne2934203:0
    On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
    Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
    Rich Garella - crwdns2934203:0crwdne2934203:0
    shrhh - crwdns2934203:0crwdne2934203:0
    Is it possible to change an upper case with a german keyboard for an english one?
    Rogerio Pefi - crwdns2934203:0crwdne2934203:0
    if you are intending to change it to British layout you don't need to change the keyboard at all, just the keys, buy either a set of a1466 key caps ( I assume you have a 2017 MacBook Air?) or a cheap a1466 keyboard (can even be a broken one), remove the keys that are different and replace them with the other keycaps, and then set the macbook's language to British and you are set
    Kai Mcpherson -
  2. MacBook Air 13" Mid 2012 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - crwdns2934203:0crwdne2934203:0
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - crwdns2934203:0crwdne2934203:0
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - crwdns2934203:0crwdne2934203:0
    What about disconnecting the battery?
    Luke - crwdns2934203:0crwdne2934203:0
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - crwdns2934203:0crwdne2934203:0
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - crwdns2934203:0crwdne2934203:0
    Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
    Nexus - crwdns2934203:0crwdne2934203:0
    The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
    The driver for the screws inside the case are named, as "T5".
    Jim Henderson - crwdns2934203:0crwdne2934203:0
  3. MacBook Air 13" Mid 2012 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Mid 2012 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    • When reinstalling a new battery, it may be helpful to temporarily reconnect the battery before placing it in the frame. Make sure that the connector lays flat to the board.
    The guide says: "Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board", but the battery model that I was replacing did not have a clear plastic pull tab at all...
    The battery model shown in this guide is: A1405
    I was installing battery model: A1406
    A1406 has the following connector:
    Top:
    http://www.directupload.net/file/d/4122/...
    Bottom:
    By looking at the bottom of the new battery I saw how it could be removed. Simply by a gentle upward movement. I very, very carefully nudged it a bit upwards using a screwdriver on the left and right side, as shown here:
    It came out fairly easy, luckily!
    (And yes, I also cleaned up this MacBook before closing it again. It was a bit hairy in a literal way. Electronics and pets is not the best combination. ;-) )
    This was a great guide!
    wil - crwdns2934203:0crwdne2934203:0
    I think you may have been reading the wrong guide by mistake.
    Looking at the various MacBook Air battery replacement guides, all of the 13" models show the connector depicted in this guide. All of the 11" models (e.g. MacBook Air 11" Mid 2012 Battery Replacement) show a connector like the one in your photos.
    shamino -
    The 13 inch's tab is a bit more difficult to reinstall than uninstall. Delicate care is needed.
    Andrew Ruble - crwdns2934203:0crwdne2934203:0
    I agree with Andrew and Joes. I also found that the trickiest part was to pull the tap back when reinstalling the new battery. A special hint at this point in the guide would be nice.
    Alexander Kluge -
    This is the tricky part if there is one. Just pull back towards the battery and not up.
    Joe Wasser - crwdns2934203:0crwdne2934203:0
    hello there, My macbook air does not recognize a battery connected, anymore.
    It looks like I damaged the connectors while trying to connect the battery back, although it does not look damaged. I must say, I tried a little force to squeeze the connector in the middle instead of the edge. May have damaged the connector ?
    Once, after this, the MBA recognized my battery when pressed the connectors edge to the pins on the board. However, this did not last long and my MBA does not recognize the battery anymore. Any solutions on how I can fix this ? Please help.
    Samy Palaniappan - crwdns2934203:0crwdne2934203:0
    Had the same issue where my Macbook did not recognize the battery on the first try. I opened it back up and re-seated the connector and that fixed the problem. That particular connector does not seem to have a positive engagement. It does not appear to seat all the way down. It’s charging now and I hope it will remain stable and connected as I travel.
    Paul Tornatta - crwdns2934203:0crwdne2934203:0
    When we were putting the new battery in, it was easier to fit the tab back on and then fit the battery in place. I had someone helping me and they held the new battery up whilst I pushed the tab in. It was quite tight, and I ended up easing it in with the tip of a screwdriver on each edge in turn.
    Shimbo - crwdns2934203:0crwdne2934203:0
    The plastic pull tab broke off with the tiny tug I gave it (Mid-2011 Air). I just unscrewed the battery and carefully pulled out the connector when I had the extra room.
    Sam Kernot - crwdns2934203:0crwdne2934203:0
    for my 11inch mac air [mid 2011] the connecter is connected vertically and not horizontally - so you need to pull up, not back. thanks to Will for the links to the illustrations that made that clear. Getting the connecter to release was the hardest part of the job - otherwise, it was just removing screws.
    Jim Kemper - crwdns2934203:0crwdne2934203:0
    I had same as above you have to be very sure on your screen size as the battery disconnect looks a little different and I used the 11 inch steps on the link provided which worked perfectly! thanks
    Jim Lukens - crwdns2934203:0crwdne2934203:0
    Successful battery change on Macbook Air 13 mid-2012.
    After screwing in the new battery, I couldn't connect it to the motherboard. I was afraid of damaging the connection and the rest of the components.
    So it seemed easier to me to unscrew the new battery, then plug it in and finally screw it back in one last time. I think that this step lacks a point of precision in terms of reassembly.
    Otherwise, it's a good tutorial, thank you very much!
    Steve Baudron - crwdns2934203:0crwdne2934203:0
    **Note during this step how the cable flexes. With the new battery you will need to carefully bend your new connector to be able to flex in the same way, which is easier to do before you install the battery. in fact, i agree with other comments that for re-install it is easier carefully hold the battery up a bit (to keep it off the trackpad components), and install the plug as you are moving the battery up into place. This will limit the amount the cable needs to flex and take that pressure off the connector to the logic board.
    llcoreyll - crwdns2934203:0crwdne2934203:0
    In line with some other comments, I found it helpful to connect the cable before putting the new battery into place. That way I could aim the cable straight into the receptacle, and the wires folded appropriately into their small space when I put the battery in position and screwed it down.
    Katherine Williams - crwdns2934203:0crwdne2934203:0
  4. MacBook Air 13" Mid 2012 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
    Les couleurs ne me semblent pas justes.
    drixe - crwdns2934203:0crwdne2934203:0
    The screw heads are made of a soft butter like chinese metal and will easily get f*cked up. take care when reinstalling to not mess them up.
    John Hamilton - crwdns2934203:0crwdne2934203:0
    les couleur sont justes; die rot markierten Schrauben oben und mitte sind länger als die unteren.
    I had used the P5 driver there, too (just gently put the bit into the screws and see that’ll fit.
    jmhoraze - crwdns2934203:0crwdne2934203:0
    The battery doesn’t actually need to come out for this repair if you’re confident working in tight spaces.
    J Kemp - crwdns2934203:0crwdne2934203:0
    Ich habe ein Problem die Schrauben von dem Akku mit dem gelieferten Schraubenzieher-Set rauszudrehen. Nur die Schraube in der Mitte konnte ich rausdrehen. Brauche ich einen anderen Schraubenzieher? Sollen die beiden Schraubenzieher aus dem mitgelieferten Set zu den Akku-Schrauben passen? Danke für eure Hilfe im Voraus! Alex
    Alex - crwdns2934203:0crwdne2934203:0
    Ich habe das Problem gelöst! Akku ist eingebaut. Mein Mac Air läuft wieder!
    Danke!
    Alex
    My Air is
    6.3 mm T5 x 1
    2.4 mm T5 x 4
    Tatsuo Mizukoshi - crwdns2934203:0crwdne2934203:0
  5. MacBook Air 13" Mid 2012 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Quick note about the replacement battery, if you bought from iFixit and the battery sections have a thin film over them, peel them off. They're to protect the battery during transit, and if you leave them on they might cause heating issues.
    Here is a link to my question about it: Replacement battery has thin film on each section do I need to remove? plus, I just got an email from iFixit customer support that it needs to be removed.
    dpchoung - crwdns2934203:0crwdne2934203:0
    thank you for the help! I installed the proper batt properly following the advice from here;-) Mahalo from Hawaii-
    zzzikaikazzz - crwdns2934203:0crwdne2934203:0
    Does replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
    Benny Forsberg - crwdns2934203:0crwdne2934203:0
    I installed the battery (OEM Apple) for the Mac Air 2013 throygh 2015:
    1. the battery for the Mac Air 2012 throygh 2015 was stated to may have compatibility problems;
    2. lesser price;
    no problems with macOS Sierra.
    Replaced it in no time! Thank you and cheers from Slovenia (that’s the one who beat you in hockey few days ago
    Mark Ogner - crwdns2934203:0crwdne2934203:0
    iFixit should really clarify whether the film covering each of the battery packs should or should not be removed. Based on dpchoung’s comment I removed this film. It was not obvious or easy to remove and as I was doing it I realized that maybe this was not a good idea as I was concerned the packs might be damaged in the removal process. I suspect most people don’t bother with this film. Later, clicking on the forum exchange I see conflicting advice. My guess is that the film provides added protection and has minimal impact on thermal issues. I am sorry I went through the bother of removing the film and hope no damage was done.
    Mark Young - crwdns2934203:0crwdne2934203:0
    Ich hab’ gelesen, dass neu eingebaute Batterien kalibriert werden müssen: https://www.newertech.com/batteries/powe...
    hjsalchow - crwdns2934203:0crwdne2934203:0
    Step 1 has an error, at least for me. I believe the 10 pentalobe screws are size P4, not P5. My Wiha P5 pentalobe screwdriver was too big for the screws, but my smaller P4 pentalobe screwdriver worked fine.
    BrianM - crwdns2934203:0crwdne2934203:0
    Great here. Replacement was a breeze. Thanks guys.
    DanielFerrer - crwdns2934203:0crwdne2934203:0
    Why should I wait 5 hours after draining the battery before charging it again?
    thomas.ss - crwdns2934203:0crwdne2934203:0
    It’s part of the calibration process—leaving it dead for awhile ensures that the battery drains low enough to reset the full discharge flag in the battery management system. If you skip that part, your battery may not calibrate properly. (It’ll still work fine, but the battery’s % charge status in macOS may be unreliable and/or behave in odd ways.) If you had to skip it for some reason, you can recalibrate at any time.
    Jeff Suovanen -
    After I replaced the battery, I plugged the charger in to start calibration and the computer started by itself. As soon as this happened I turned it off. Can this be an issue?
    How do I know the battery is 100% charged?
    Thank you
    tobias.a94 - crwdns2934203:0crwdne2934203:0
    It might be obvious to most people, but no mention of plugging in the battery connector when installing the new battery. I missed that part at first. Overall great instructions and finished quickly.
    Staci Thompson - crwdns2934203:0crwdne2934203:0
    It went well, thank you. One comment though, I prefer to put the connector back before installing the new battery since the cable is not flexible enough.
    ricochapuis - crwdns2934203:0crwdne2934203:0
    Replaced my new battery for a mid 2011 MacBook Air but now the battery icon says it’s not charging
    Mike Bridgewater - crwdns2934203:0crwdne2934203:0
    how do i dispose of the old battery responsibly?
    Jonathan Peters - crwdns2934203:0crwdne2934203:0
    +1 curious about this. Should be added to the guide
    Travis Todd -
    Why shouldn’t I touch the lithium polymer cells? Is that on removal, too? Is it dangerous for me or just the battery (like getting finger oils on a halogen bulb)? Would it be beneficial to wear thin latex gloves?
    Andrew Greenseid - crwdns2934203:0crwdne2934203:0
    After Installation my MacBook does not start, but there are peep tones 3x in a row and this repeats until I press power for few seconds. Any clue what this could be?
    b.winkler343 - crwdns2934203:0crwdne2934203:0
    Installation was very easy. Works perfect for me and battery is now fully charged and running.
    Andreas Otte - crwdns2934203:0crwdne2934203:0
    Installation was a breeze thanks to your tips.
    KAT VELASQUEZ - crwdns2934203:0crwdne2934203:0
    Easy. Now onward with the rest of the calibration.
    Thx
    G J L - crwdns2934203:0crwdne2934203:0
    When placing the new battery in, reconnect it first before screwing into place.
    Owen Moseley - crwdns2934203:0crwdne2934203:0
    The battery film issue. The film pictured in the guide covers each individual battery. The guide also states it is glued on. My iFixit replacement battery had a different kind of film that covered the whole battery module. It was not precise fit and was loosely stuck on rather than permanently glued. It was obviously the kind that is used to protect from scratches in packaging/shipping. It peeled off easily with no residue. My conclusion is the warning is meant for film on individual batteries. For the iFixit one I received, the film was meant to be peeled.
    Kasey Speakman - crwdns2934203:0crwdne2934203:0
    I have installed the battery replacement for a MBA Mid 2012 and it’s working, but the battery temperature is somehow stuck at around 26 degree Celsius. Even if you do a stresstest with 27 Watt the temperature is falling from 26.25 to 26,15. So it ssems to me that the temperature measurement isn’t correct. In other MBA Mid 2012 with original Battery the temperature range is from ambient to 41 degree.
    Don’t know if the wrong temperature has an impact on the lifetime of the battery, as the battery controller should limit currents according to temperature.
    Robert Schmidt - crwdns2934203:0crwdne2934203:0
    Does the battery simply come straight out?
    It isn't stuck down?
    Cary B - crwdns2934203:0crwdne2934203:0
    very easy - was gifted MBA but battery life was 'r/s' - vacuumed out fluff etc from machine & fan while back was off (was a technician in a previous life) .. now performing calibration. I'll write down the settings, then set energy saver to 'never' for both battery & power adaptor when it comes time to discharge the battery, then reset to original values after final charge. Fingers crossed (it's a helluva lot easier than 'Blackberry trackballs')
    Garth Lancaster - crwdns2934203:0crwdne2934203:0
    Replacement was a breeze. Left the plastic film on the battery as described. Calibration performed. Now I only charge when battery is low. It's nice to have an old Intel based Macbook Air for legacy applications.
    Rob - crwdns2934203:0crwdne2934203:0
crwdns2935229:0606crwdne2935229:0
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
509,805 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,756crwdne2935297:0
crwdns2947412:096crwdne2947412:0
My Mid 2012 doesn't have any plastic on the battery connector. Near to impossible to remove it.
marcus - crwdns2934203:0crwdne2934203:0
Mine did. ¯\_(ツ)_/¯
Arlen Abraham -
Worked flawlessly on my MBA. Installed in 5 minutes. Coconut Battery now reports 6801 mAh on a design capacity of 6700 mah. That's an improvement as my old battery was clocking a meager 61% of design capacity (i.e., 4087) after 371 cycles.
Easy. Perfect replacement.
ldm - crwdns2934203:0crwdne2934203:0
I tried to opened it and I failed. The screw doesn't work well. Worst idea ever!
etiennelafrance7 - crwdns2934203:0crwdne2934203:0
Be sure to use the required special pentalobe screwdriver. Using the incorrect screwdriver, such as a Philips head, can easily damage the screw head, making it very difficult to remove.
Les Ferch -
Very easy. I bought the "A-Stock" battery. It came at a max charge of 6300mAh (max of 6700) -- decent. But within 2 weeks dropped down to a max of around 4,000 mAh. I'm thinking that I should have spent the extra $10 and bought the new battery. (I am using the Coconut Battery App.)
gvr4 - crwdns2934203:0crwdne2934203:0
Update -- after about a month with the A-Stock battery, I got the "Service Battery" warning, but it did not stay -- disappeared after a while. Strange behavior. I would not recommend buying anything but a new battery based on this experience.
I'm wondering if you may be seeing a calibration issue. Batteries in Apple products can (generally) be recalibrated by draining them as much as possible (e.g. start playing a video or doing something else that will draw a lot of power and prevent it from going to sleep, letting it run until the OS does a battery-empty shutdown) then charge it to 100% without using the computer (e.g. leave the lid closed and the charger attached until the charger's light changes from orange to green.) Maybe repeat the cycle one or two times if you think it will help (although it should only be necessary to do this once.)
It wouldn't surprise me if a new battery needs recalibration after installation.
shamino -
Guide was perfect. Saw several other guides mention T5 screws for back cover. This guide was correct with the 5-point Pentalobes. Got the iFixIt 54-bit driver set. Worked perfectly. Bit disappointed that CoconutBattery reports the battery is capable of 98% charge (6583/6700mAh) but I can live with that vs. the 48% on old battery. Thanks for the guide and parts.
lostvincy - crwdns2934203:0crwdne2934203:0
The guide was great, the supplied screwdrivers worked, everything was where it was supposed to be (e.g. the plastic handle on the battery connector) - I was done in 10 minutes. Everything as advertised.
My batter was new, 6812 mAh.
Jan van Rendek - crwdns2934203:0crwdne2934203:0
Straightforward guide, completed in about 20 mins. The new battery reports 6746 mAh. Many thanks.
Matt - crwdns2934203:0crwdne2934203:0
Thanks for the guide! Worked perfectly and easily.
mathiasklang - crwdns2934203:0crwdne2934203:0
Great guide.
If you have the correct screwdriver you'll have no problems.
Completed in 8 minutes.
This is one of the easy replacements on a 13" MacBook Air (Mid 2012)
Be gentle when screwing in the replacement battery!!
I used little force but the corner plastic snapped and cracked...
Dennis - crwdns2934203:0crwdne2934203:0
The screws have been treated with thread-locking compound. The exterior, case screws have been treated with particularly tenacious compound, which means it will take markedly more torque to unscrew them than the proper torque for screwing them in. When loosening and tightening the case screws be sure to have the driver well seated and aligned perpendicular to the head in both planes or you may bung up the heads.
For both interior (battery) screws and exterior (case) screws, don't assume that how hard you needed to twist to loosen them is how hard you should tighten them.
Jeff Morrow - crwdns2934203:0crwdne2934203:0
Installation was a breeze but now my battery % is on 87% for 4+ hours (where it was on the old battery) and when I unplug MagSafe power shuts off immediately. Any help appreciated.
jeffmorris - crwdns2934203:0crwdne2934203:0
Jeffmorris, try getting coconut battery and looking at the health of the battery, if its not the battery could be a larger issue. Sorry!
Ben -
I replaced my wife's battery with this guide and it was a breeze, it's taking forever to charge though, maybe it's balance charging?
Matt beausoleil - crwdns2934203:0crwdne2934203:0
Thank you so much for the guide, super easy diy. getting the right screwdriver was quite an adventure but the repair took less than 10 minutes. If the battery works as advertised I will have an almost new macbook to work with.
thanks again.
epi - crwdns2934203:0crwdne2934203:0
Hello! I did this for my MacBook Air 13" mid 2012 and everything's fine. I'm charging it right know to the fullest. It's my first time that I open a MacBook and this guide worked perfect for it. I hope it keeps this way. Greetings from Mexico and keep the awesome work!
Oscar - crwdns2934203:0crwdne2934203:0
I have successfully replaced my MBA Mid2012 battery.
The instructions worked like charm... Kudos.....
Keep up the good work and much appreciated.
I ordered the battery from Amazon :-http://www.amazon.com/gp/product/B012BZM...
Gaurav Sood - crwdns2934203:0crwdne2934203:0
I had dropped my Mac Air on a tile floor and it would only boot up when plugged in. If the magnetic connector was jiggled the computer would shut down. Not fun! I taped the connector to the computer but even so, it would easily shut down unless handled like a case of eggs. Bought the pentalobe screwdriver from Ifixit. Had the back off in a flash. Gave the plastic tab on the battery connector a little push. Felt it click back into place. Replaced the back. Battery now working again. Thanks! Saved a trip to the Apple Store and probably a lot of cash.
michael - crwdns2934203:0crwdne2934203:0
Worked flawlessly on a Mid-2012 MBA -- my old battery was almost completely bailed out, followed this guide with a new battery and the P5 + T5 screwdrivers (both ordered from here) and had everything up and running in under 15 minutes. Much obliged!
Rabi Alam - crwdns2934203:0crwdne2934203:0
As easy as pie, now my wife Macbook Air have new battery with cycle = 0 :).
Sang Le - crwdns2934203:0crwdne2934203:0
Cheers to those who put this tutorial up. Followed the steps, worked perfectly!
Point to note:
The very end of these pentalobe screwdrivers can be very thin and sometimes a weak/cheap metal is used to make them.
IF you're pentalobe screwdriver "strips" at the head (NOT the screw itself) as you're taking out the screws, don't worry, give the very tip (straight-on mind-you) a quick pass in front of a grinder or hasp to in order to remove the rounded off edges and make it flat again!
Worked like a charm for me.
Again thanks for the advice!
M
matschraeder - crwdns2934203:0crwdne2934203:0
Fast delivery of tools and replacement battery, easy installation, perfect guide! Thanks a lot, MacBook Air is alive again, yippiieeeh!
Benjamin Becker - crwdns2934203:0crwdne2934203:0
Super easy, 5 min and done. Cheers.
Relte - crwdns2934203:0crwdne2934203:0
Great Guide very easy to follow. Quick 10 Minute job. Thanks.
JNoles - crwdns2934203:0crwdne2934203:0
Guide worked great! I bought an Anker battery off Amazon. I've had good luck with Anker external batteries. It cost more than some of the other brands but still 2/3 of what Apple would charge. The battery came with two sets of tools: the Torx and Pentalobe drivers. Was surprised at how tiny the screws were but the tools are magnetic and the screws stuck well to them.
James Deibele - crwdns2934203:0crwdne2934203:0
https://youtu.be/9Z8Cs8StHPw
I created a video for how to do this if you need more help!
petergharib - crwdns2934203:0crwdne2934203:0
Spot on guide. Quick, accurate, and took 5 mins
Martin Hampton - crwdns2934203:0crwdne2934203:0
Super clear and spot on! Did it in 5-10 minutes, and added a suggested time of 10 minutes to the guide.
Nhan Nguyen - crwdns2934203:0crwdne2934203:0
As advertised, completed this is 5 minutes. Great result now sitting up at 7369mAh, up from 3742mAh. Great fix!
Ben - crwdns2934203:0crwdne2934203:0
The guide worked perfectly for me. The plastic tab broke off of the new battery but I'll cross that bridge when I come to it. The entire operation took about 15 - 20 minutes. Thanks!!
Jeri Jones - crwdns2934203:0crwdne2934203:0
Perfect guide. Bought the part from iFixit and installed in under 5 minutes. Well worth the effort.
After any hardware installation, even minor ones like this, its worth running the Apple Hardware Test to ensure you didn't forget anything or nothing is misbehaving. While booting, hold down the D key and follow the prompts. Good 5 minutes to check everything is ok.
Easy-peasy. If you have the 2 tools/drivers and the battery you should be able to complete the replacement in less than 30 minutes (without any prior experience).
You may have to reset the date and time on your laptop afterwards, you'll know when you cannot access Google and other servers because your clock time/date is way different from the server time.
Great job.
bernie - crwdns2934203:0crwdne2934203:0
Thank you, super easy. No problems occurred. Job was done in 10 minutes.
arnoldhoogenkamp - crwdns2934203:0crwdne2934203:0
Awesome, guide. Took me less than 15 min. Extremely easy and now I have the proper tools for future repairs.
Stephen Rouse - crwdns2934203:0crwdne2934203:0
The instructions was super easy to follow. I was able to replace the battery myself saving me hundreds of dollars.
nawaazish.n - crwdns2934203:0crwdne2934203:0
Excellent guide that was easy to follow and left no unwanted surprises. Never opened a MacBook air (A1466) before so all new to me and had no trouble at all. I bought a new Hasess A1405 battery (https://www.amazon.co.uk/gp/product/B016...) which came with the necessary screwdrivers that worked fine. They were magnetised, as mentioned by another commenter, which was really handy as the screws are very small. The battery was sold as a 6800mAh/50Wh but the system information (Power) was showing it as 7188mAh which was a very pleasant surprise. Mine is a mid 2012 MBA and has the plastic tab on the old battery (and new battery) so pulling out horizontally, not vertically, worked like a treat. Interestingly, in response to comments about battery holes not lining up or breaking, my apple battery had broken 2 clips which left bits of plastic in the case that I needed to pick out before fitting the new battery. It didn't cause a problem to the operation of my MBA. Thanks!
Dave Denton - crwdns2934203:0crwdne2934203:0
5 minutes. Very easy. Thanks!
Szymon B - crwdns2934203:0crwdne2934203:0
Excellent guide. Product arrived quickly. Installed in 15min at a slow careful pace. Back up an running. Thank You !
David Parsons - crwdns2934203:0crwdne2934203:0
While reversing the guide and installing the battery the plastic connector was frustratingly hard to connect to the logic board, but the guide is good in itself. It took me about 25-30 minutes, but I am finicky and overly careful. If your laptop is especially old, I would suggest having a can of air on hand.
My battery gave a failed signal for a while, and then it began working again. This happened after the first cycle. MagSafe2 stayed completely green--rather than going to amber; a reboot and replug caused it to fix itself -- it will probably happen again, unfortunately...
Great guide. Should be rated "easy". With only 15 screws and a connector, no adhesives, no flex cables or flimsy clips, this battery is basically user-replaceable.
idmadj - crwdns2934203:0crwdne2934203:0
Great, replaced within 25 minutes, including a thorough blowing off dust while having it open. Might do a complete empty-full cycle for calibration to be sure.
Lutz Zimmmermann - crwdns2934203:0crwdne2934203:0
Thanks! Just changed my battery out. Thought it was going to be complicated. You gave me the confidence to do it myself, instead of paying apple 129 bucks and waiting 3-4 days, plus the hassle of setting up a geek squad appt.
jakebrub - crwdns2934203:0crwdne2934203:0
Good guide, thank you. What should I do with the old battery? Where can I dispose of it?
Henry Fitzgerald - crwdns2934203:0crwdne2934203:0
Good question. I'm going to give it to a electronic shop if possible.
Daniel -
For any future Fixers out there wondering what to do with their old battery: iFixit always recommends recycling. You can find a battery recycling facility near you by using this nifty site here: https://www.call2recycle.org/locator/. Just enter your zip code and it will show you available drop-off locations.
Kadan Sharpe -
I understand this is an old comment now, but this website only works in the US. It would be great if there were some international options available too.
Henry Fitzgerald -
Hey, I just finished changing my MacBook Air 13" mid 2012 battery myself and it was a piece of vegan cake. This helped a lot. I had no problems with the manual/guide. I just had some screws issues like the screws were worned out. Overall, these steps were easy to follow. I hear that batteries that are not original would kill the mother board or another part in about 2 months so I hope not. I will try to check back on this thread later to keep y'all posted. Today is 07/25/17, I would like to post another note on 09/26/17 and say it still works. I saved money and would recommend doing things yourself if possible. Again, thank you.
Daniel - crwdns2934203:0crwdne2934203:0
Worked as advertised. Thanks a bunch!
GuyfromRI - crwdns2934203:0crwdne2934203:0
Does this replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
I follow your tutorial.
But i have a problem.
The mac won’t boot. I try, connect/reconnect battery (also old battery), check the cable, reset SMC.
But nothing. What’s appen?
Lo Stanzio - crwdns2934203:0crwdne2934203:0
easy procedure. unfortunately the battery i received from ifixit did not sit flush with the case causing the track pad to bulge out at the bottom of the diving board. i found another battery on amazon (CMP brand) which addressed this fitment issue.
pao lor - crwdns2934203:0crwdne2934203:0
Had same issue however I was able to tighten the trackpad screw as a fix.
mumahag -
Fantastic guide, the different colored circles for different sized screws was super helpful! Thanks!
Sam Holtman - crwdns2934203:0crwdne2934203:0
Super easy after 4 pints of beer.
Chad - crwdns2934203:0crwdne2934203:0
Great guide!
the process is really easy. Just do not forget to buy the TWO SCREWDRIVERS! T5 and P5. The screws on the cover need the P and on the battery itself the T.
luis
Luis nunes - crwdns2934203:0crwdne2934203:0
Excellent guide.
Some things to watch out for. When removing the original battery the power cable may not flex enough to clear the connection housing on the logic board. No worries, just release it with a slight pull then remove the 5 screws holding the battery assembly and gently pull out while guiding the cable from the housing in the logic board.
When installing , guide the connector into the housing and press gently to engage the pins. You don’t have the fully seat the power connector yet. There is enough flex in the cable to align and seat the battery and insert the securing screws. As detailed before, don’t overtighten theses screws or you’ll break the ears on the battery (like was done at the factory on my MBA!)
once the battery was secure I used a plastic spudger to fully seat the power cable connector.. be patient and keep pushing gently until FULLY seated this way you won’t have to reopen the Mac to seat the connector!
I pressed the power button and , booom! The Air booted right up!
sweet
Lynn Cox - crwdns2934203:0crwdne2934203:0
Excellent guide. I installed the replacement battery bought on iFixit EU store (had got already the P5 and T5 screwdrivers). System Report says full charge capacity 7200 mAh, Fully charged now at 7134 mAh and still slowly increasing. Let’s see after a full discharge and SMC reset what this figures will be.
Claudio Dalla Vecchia - crwdns2934203:0crwdne2934203:0
Replacement was easy, thanks to this guide.
Has anyone experienced a loose and rattling trackpad? I’ve read that some old batteries expand and push on the trackpad. With a newer and thus slimmer battery, there’s left some room?
Gerrit - crwdns2934203:0crwdne2934203:0
Battery arrived quickly and the repair was straightforward and fast. One screwdriver worked for all screws. MBA 2012 working great!
Jaime Hovey - crwdns2934203:0crwdne2934203:0
These directions were fantastically clear and made replacing my dud of a battery far less intimidating. I did have a moment of fleeting panic when I my do-do brain didn’t read explicit INSTALLATION instructions, just REMOVAL instructions, but of course common sense correctly dictated to reverse the steps. (Swoo!) Made all the easier by ordering the repair kit; saved hundreds of dollars and the hassle of going to an Apple store (in itself worth the 90 or so bucks!).
Mary McCarthy - crwdns2934203:0crwdne2934203:0
Thank you for this tutorial, no problem to change the battery. But clear plastic covers are stuck on the elements of the battery, must we keep them?
Merci pour ce tutoriel, aucun problème pour changer la batterie. Mais des caches en plastique transparent sont collés sur les éléments de la batterie, faut-il les garder ?
Jean-Pierre Philippe - crwdns2934203:0crwdne2934203:0
Hi Jean-Pierre Philippe,
Please do not remove the plastic covers. They are heavily glued onto the battery and protect the battery from punctures. Removing them may strip off the battery pack’s covering.
Arthur Shi -
Greetings! The IFixit replacement battery arrived 2 days after I ordered it. The instructions were very clear and the replacement took less than 20 minutes. Thanks for a good product and customer support!
paul naecker - crwdns2934203:0crwdne2934203:0
Excellent instructions as usual - my MacBook Air was back online in less than 30 minutes. Perfect! Thanks a lot!
Michael Hengherr - crwdns2934203:0crwdne2934203:0
Bonjour, nous venons de faire la manipulation mais une alarme surgis dès que l’on souhaite rallumer l’ordinateur… savez vous à quoi ca correspond ?
ma_benke - crwdns2934203:0crwdne2934203:0
The easiest process ever! Great simple instructions. Now how do I dispose of the old one?
Leticia Acosta - crwdns2934203:0crwdne2934203:0
I’v easily replaced battery following the instructions, but then the trackpad click was loose and noisy.
Tightening a screw solved the issue, now everything is fine: Why is my trackpad making a rattling noise after replacing battery?
guido_brasletti - crwdns2934203:0crwdne2934203:0
Good guide. Only thing I would add is insert the little battery connector tab first before pressing and screwing everything down. Might make connecting it a little easier.
Howarthjt - crwdns2934203:0crwdne2934203:0
Can’t believe how straightforward this was. I read this guide carefully, along with all comments… then checked YouTube for a video guide, just so there was a step-by-step on the battery install. I used this: https://www.youtube.com/watch?v=uOJKy7xV...
— But all told, it took me 10-15 minutes max? I’ve cried doing Comcast cable modem self-installs… so would genuinely rank this as easy.
Some tips:
1. Do as a commenter above indicates, and put the plastic tab of your new battery in before screwing in the whole battery. On the tab, you press it in with your fingernails; the click is tangible. You will feel it fit in.
2. Don’t neglect to properly calibrate your battery once the install is complete.
3. Consider installing the Coconut Battery app to monitor the calibration.. and as your go to battery monitor.
Grateful customer - crwdns2934203:0crwdne2934203:0
Hi there I replaced my battery but my mac is too slow however i use the same battery model please help!!!!
Farazmordi22@icloud.com
Faraz - crwdns2934203:0crwdne2934203:0
15 minutes was enough :)
Air 13” Mid 2012
Ihor Chumak - crwdns2934203:0crwdne2934203:0
Good battery! Mine came from the Euroshop with 7834mAh during to coconutBattery :)
andreas992011 - crwdns2934203:0crwdne2934203:0
Extremely easy to follow. Easy and fast installation. Thank you very much for the tutorial. The 5 steps to replace the battery of my MacBook Air mid-2012 were OK.
Mireia Leon - crwdns2934203:0crwdne2934203:0
Thank you for these instructions. 61yo female here and I did it in 15 min. from start to finish.
Biggest challenge is holding onto the little screws. I had 4 separate little bowls to put them in as they came out and that helped.
Only thing I would change is more guidance about inserting the battery tab to the laptop connector. It didn’t “snap” in so felt a bit unsure about the connection. Just pushed it in as far as it would go and it seems to have worked.
I also magnetized my screwdriver to help hold onto the little screws. That helped too.
Anne Walch - crwdns2934203:0crwdne2934203:0
Wenn man das Werkzeug hat, dann ist das brutalst einfach! 10 Minuten Arbeit.
fkluss - crwdns2934203:0crwdne2934203:0
This is an incredibly easy repair. It definitely took less than 15 minutes. The main thing is to have the proper tools. If you don’t have a pentalobe screwdriver for the bottom case screws, or if you don’t have the right size torx screwdriver for the battery then the repair will be impossible. Be sure to order the correct pentalobe and torx screwdrivers, if you don’t already have them, before you begin.
feinberj - crwdns2934203:0crwdne2934203:0
Replacement was flawless. The instructions were great. Still wondering about the plastic on the cells, though. All in all, though, a great job teaching me how to do this.
Russ Milam - crwdns2934203:0crwdne2934203:0
Replacement was very easy - still:
Better put the connector back before installing the new battery - the cable is not very flexible.
U. Hahn - crwdns2934203:0crwdne2934203:0
Used this to replace a client’s battery before teaching myself to factory reset it and get it setup again for their partner. Appreciate the well-written guide with solid graphics. Thank you.
SparkWorx - crwdns2934203:0crwdne2934203:0
How many hours takes for first 100% charge?
samg76 - crwdns2934203:0crwdne2934203:0
Just replaced the battery and the instructions were flawless. I spent more time with a can of air blowing out the dust that had accumulated than the battery replacement procedure. The replacement was very quick and easy. Connecting the new battery plug took a tiny bit of finessing as I wanted to make sure I plugged in directly at the angle of the receptacle. I used the flat edge of the ‘spudger’ tool to help align and guide the plug properly.
Atticus Rotoli - crwdns2934203:0crwdne2934203:0
The screws on the inside of the computer were super flimsy so I ordered new ones to install with the new battery. iFixit’s toolkit and explanation above was great though!
Abel DeAndreis Colina - crwdns2934203:0crwdne2934203:0
MId 2012 mac air. Instructions were seamless! Thank you! Apple store rejected the replacement saying that after 8 years a product is deemed unusable. What type of environmental BS is that? So far so good, will have 7,004 mha with this new battery which is an improvement over the original one of 6,500
Simon Dang - crwdns2934203:0crwdne2934203:0
I purchased a “new” battery for my mid-2012 MacBook Air from iFixIt a few weeks ago and installed it a soon after it arrived. I followed all of the steps in the guide above, calibrated the battery (2 times), and reset the SMC and PRAM/NVRAM as instructed. However, the battery monitor is still reporting “Service Recommended” and the battery discharges really quickly (2-3 hours, at most, on a fully charged battery). CoconutBattery reports that the battery has only 7 cycles but states that the MacOS Battery Status as “Fair”. Not quite sure what else to do, but could it be a bad unit from iFixIt? Any hep or advice would be greatly appreciated!
markfredriksen - crwdns2934203:0crwdne2934203:0
I have installed the battery replacement for a MBA Mid 2012 and it’s working, but the battery temperature is somehow stuck at around 26 degree Celsius. Even if you do a stresstest with 27 Watt the temperature is falling from 26.25 to 26,15. So it seems to me that the temperature measurement isn’t correct. In other MBA Mid 2012 with original Battery the temperature range is from ambient to 41 degree.
Great guide with awesome pictures and easy to follow instructions. Thanks for pulling this together!
Mike Hiteshew - crwdns2934203:0crwdne2934203:0
I was really cross with the Apple Store because they wouldn’t replace the battery on my 10 year old MacBookAir, even though the MacBook Air works perfectly in every other sense. However the Mac expert in the Apple Store suggested I tried IFIXIT. The battery is cheaper than Apple would have charged me (and that included me ordering the full fixing kit with all necessary tools). The installation instructions on the IFIXIT website were very straightforward, and the pack of Haribos IFIXIT included with the battery kit stopped me getting too stressed while installing the new battery. I do agree that the comments about not removing the plastic film in the instructions are very misleading, but this has been already covered in other comments and responses, I removed my plastic film assuming it to be transit protection. Thank you, hopefully years more life now in my old faithful MacBook Air.
Graham in Basingstoke - crwdns2934203:0crwdne2934203:0
everything went very smooth. hardest part was to get the drivers out of the handle ;) although disconnecting the battery is a little bit scary, but without problems. I left the thin one piece plastic cover on the new battery. lets see if there will be any heating issues
Roland Auferbauer - crwdns2934203:0crwdne2934203:0
I bought the iFixit battery for this model, after 237 cycles in 2 years it's already in service mode. I will shop elsewhere for a battery for this model, this sucks..
Egbert Kappert - crwdns2934203:0crwdne2934203:0
My laptop screws won’t secure near the trackpad with the new battery. Is the new battery already bloated? I didn’t have this problem before I replaced it.
Chrissy - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 151
crwdns2936753:030crwdne2936753:0 604
crwdns2942667:0crwdne2942667:0 393,512
