MacBook Air 13" Late 2020 Lower Case Replacement
  1. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the screws securing the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    ESD safe mat, plugged into ground, with a wrist strap, also grounded, are the best best to protect the logic board.
    Robin Ray - crwdns2934203:0crwdne2934203:0
    Re-Assembly Tip: Before putting the screws back in, snap the lower case on and test to make sure the MacBook powers up. When I first re-assembled, I became very nervous I did something wrong because it would not power on. It turns out I just needed to plug the laptop into a power source for it to power up (despite having a good charge before disassembly). It was the perfect way to test the new USB-C ports!
    Austin - crwdns2934203:0crwdne2934203:0
    Big points to this one, especially for mentioning needing to plug the laptop in. The bottom case needs to be screwed in and laptop needs to be plugged in before it will boot.
    Bayden Yazalina -
    Wiha 4PL driver for these screws.
    Greg Worrel - crwdns2934203:0crwdne2934203:0
    Printing out all the images from this Ifixit guide prior to starting and using duct tape help me keep track of screws.
    raju midjdeya - crwdns2934203:0crwdne2934203:0
    This Guide has a high chance of not working if an aftermarket display is used as MAC serialization was introduced post ~2023. Likely you will need an original MAC screen replacement and to serialize the display for it to work.
    Tron Computers - crwdns2934203:0crwdne2934203:0
  2. MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Lower Case Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Los tornillos se ruedan fácilmente :(
    Mishelle Cerón - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Carsten Frauenheim
144,508 crwdns2915208:0crwdne2915208:0
crwdns2935297:0422crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,025crwdne2935297:0
Hi, I accidentally stripped one of the female thread in the chassis what can I do to fix this? as the screw won't stay in place/screw in
TheTechDisassembler24 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 106
crwdns2936753:030crwdne2936753:0 452
crwdns2942667:0crwdne2942667:0 25,034
