Use this guide to remove or replace the left speaker in a Late 2020 MacBook Air (M1).
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
Reassembly: I had difficulty going straight down. The connector has some angled edges that made it difficult. Instead, I slotted the wire side in first, then rocked it forward towards the hinge into position.
If having difficulty in flipping the bar up, place the machine vertical and not that there is a small “locking nib” that the bar has to clear. You may have to give the bar honest persuasion to clear the nib.
The bar can lock backwards making it very hard to even see let alone move. Great care is needed to shift it. I had to use two thumbnails, one on each side, then once flipped forward it takes more push than I expected to clip it in place. Ensure the plug is fully seated first !
As others commented, it can be hard to click the battery connector back into place. First make sure the bar is not underneath the connector. Then, turning the computer so the connector pins are facing you (LCD hinge end closer to you) can also make it easier to position the connector on top and then click it into place.
Some replacement batteries have a retainer bar that differs from OEM batteries. I had to swap the retainer bar to properly secure it under the "locking nib" to ensure it didn't release on its own (before it could freely swing).
Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
Pull the adhesive strip until it's freed from under the speaker.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Remove the left speaker.
Once you've completed your repair, your laptop may not power back on until connected to power.
If you hope to fix a rattling noise between ~300–500Hz by exchanging the speakers, be warned: As a few other folks here and on reddit already reported, the problem also in your case might quite likely not be the speakers, but a resonance far deeper inside the laptop, potentially between mainboard and keyboard. At least in my case as in theirs, exchanging the speakers didn't improve anything.
What did help me a bit was to squeeze the speakers with a bit of rubber (actually the adhesive strips from underneath) at a specific position, so that they received pressure from the bottom cover once it's closed again. There's still enough rattle to be annoying (particularly with quiet piano music), but less.
ESD safe mat, plugged into ground, with a wrist strap, also grounded, are the best best to protect the logic board.
Robin Ray - crwdns2934203:0crwdne2934203:0
Re-Assembly Tip: Before putting the screws back in, snap the lower case on and test to make sure the MacBook powers up. When I first re-assembled, I became very nervous I did something wrong because it would not power on. It turns out I just needed to plug the laptop into a power source for it to power up (despite having a good charge before disassembly). It was the perfect way to test the new USB-C ports!
Austin - crwdns2934203:0crwdne2934203:0
Big points to this one, especially for mentioning needing to plug the laptop in. The bottom case needs to be screwed in and laptop needs to be plugged in before it will boot.
Bayden Yazalina -
Wiha 4PL driver for these screws.
Greg Worrel - crwdns2934203:0crwdne2934203:0
Printing out all the images from this Ifixit guide prior to starting and using duct tape help me keep track of screws.
raju midjdeya - crwdns2934203:0crwdne2934203:0
This Guide has a high chance of not working if an aftermarket display is used as MAC serialization was introduced post ~2023. Likely you will need an original MAC screen replacement and to serialize the display for it to work.
Tron Computers - crwdns2934203:0crwdne2934203:0
