MacBook Air 13" Late 2020 Audio Board Replacement
  1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the screws securing the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    ESD safe mat, plugged into ground, with a wrist strap, also grounded, are the best best to protect the logic board.
    Robin Ray - crwdns2934203:0crwdne2934203:0
    Re-Assembly Tip: Before putting the screws back in, snap the lower case on and test to make sure the MacBook powers up. When I first re-assembled, I became very nervous I did something wrong because it would not power on. It turns out I just needed to plug the laptop into a power source for it to power up (despite having a good charge before disassembly). It was the perfect way to test the new USB-C ports!
    Austin - crwdns2934203:0crwdne2934203:0
    Big points to this one, especially for mentioning needing to plug the laptop in. The bottom case needs to be screwed in and laptop needs to be plugged in before it will boot.
    Bayden Yazalina -
    Wiha 4PL driver for these screws.
    Greg Worrel - crwdns2934203:0crwdne2934203:0
    Printing out all the images from this Ifixit guide prior to starting and using duct tape help me keep track of screws.
    raju midjdeya - crwdns2934203:0crwdne2934203:0
    This Guide has a high chance of not working if an aftermarket display is used as MAC serialization was introduced post ~2023. Likely you will need an original MAC screen replacement and to serialize the display for it to work.
    Tron Computers - crwdns2934203:0crwdne2934203:0
  2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Los tornillos se ruedan fácilmente :(
    Mishelle Cerón - crwdns2934203:0crwdne2934203:0
  3. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
    Reassembly: I had difficulty going straight down. The connector has some angled edges that made it difficult. Instead, I slotted the wire side in first, then rocked it forward towards the hinge into position.
    Sean K - crwdns2934203:0crwdne2934203:0
    If having difficulty in flipping the bar up, place the machine vertical and not that there is a small “locking nib” that the bar has to clear. You may have to give the bar honest persuasion to clear the nib.
    Harry Dulcamara - crwdns2934203:0crwdne2934203:0
    The bar can lock backwards making it very hard to even see let alone move. Great care is needed to shift it. I had to use two thumbnails, one on each side, then once flipped forward it takes more push than I expected to clip it in place. Ensure the plug is fully seated first !
    Simon Anthony - crwdns2934203:0crwdne2934203:0
    As others commented, it can be hard to click the battery connector back into place. First make sure the bar is not underneath the connector. Then, turning the computer so the connector pins are facing you (LCD hinge end closer to you) can also make it easier to position the connector on top and then click it into place.
    madmaxmedia - crwdns2934203:0crwdne2934203:0
    Some replacement batteries have a retainer bar that differs from OEM batteries. I had to swap the retainer bar to properly secure it under the "locking nib" to ensure it didn't release on its own (before it could freely swing).
    Anthony Collier - crwdns2934203:0crwdne2934203:0
  4. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board connector cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Audio Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
    Man, that's toit! Couldn't give us a little play in that cable Apple?
    maccentric - crwdns2934203:0crwdne2934203:0
    Traduccion a Español: ¡Tío, eso es! ¿No podían darnos un poco de juego en ese cable Apple?
    Carlos López (España - Spain) -
    Traducción a Español: ¡Tío, eso es! ¿No podían darnos un poco de juego en ese cable Apple?
    Carlos López (España - Spain) - crwdns2934203:0crwdne2934203:0
  7. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  8. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
  10. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
Once you've completed your repair, your laptop may not power back on until connected to power.
crwdns2935229:011crwdne2935229:0
Carsten Frauenheim
144,847 crwdns2915208:0crwdne2915208:0
crwdns2935297:0423crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,124crwdne2935297:0
Ich hatte einen Wasserschaden und seit diesem funktionieren die Lautsprecher nicht mehr. Es kommt kein Ton raus aus beiden Seiten. Zunächst hörte ich noch das Neustartgeräusch. Nachdem ich aber den dann Laptop auseinandergebaut, getrocknet und wieder zusammengebaut hatte kein Ton mehr. Die Lautsprecher selbst wurde allerdings nicht wirklich nass. Kann die Audioplatine hier die Ursache sein und ein Austausch helfen? Die anderen Funktionen, wie Touch-ID, die über die Audioplatine laufen, funktionieren allerdings noch. Gibt es sonst noch ein einzelnes Bauteil oder Kabel, welches dafür verantwortlich sein könnte?
Ich gehe davon aus, dass die Lautsprecher an sich noch intakt sind.
Richard - crwdns2934203:0crwdne2934203:0
Richard,
Entschuldigen Sie zunächst mein schlechtes Deutsch. Es lohnt sich wahrscheinlich, die Audioplatine auszubauen und anschließend zu reinigen. Verwenden Sie zum Reinigen der Anschlüsse >90% Isopropylalkohol und eine weiche Bürste wie eine Zahnbürste. Auf sichtbare Korrosion prüfen. Konzentrierte sich der Wasserschaden auf die Nähe der Audioplatine? Ich glaube nicht, dass Wasser den Lautsprechern Schaden zufügen würde, es sei denn, sie würden in Wasser getaucht, oder dass das Wasser speziell ihren Stecker beschädigt hätte. Viel Glück bei deiner Reparatur. Ich bin gespannt, ob Sie das Problem lösen.
Carsten Frauenheim -
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 245
crwdns2942667:0crwdne2942667:0 12,413
