Mac Pro 2009-2012 Case Replacement
  1. Mac Pro 2009-2012 Case Replacement, Open the Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Open the Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Open the Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Case Replacement, Remove the side panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the side panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the flap to put it in the unlocked position. The panel should separate from the case without force.
  3. Mac Pro 2009-2012 Case Replacement, Remove the hard drives: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the hard drives: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Simply pull the DVD drive bracket towards you, just like with the hard drives. Force it gently.
    • Unplug de power cable and the SATA cable of each DVD drive
  5. Mac Pro 2009-2012 Case Replacement, Remove the CPU board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press both latches to unlocket the bracket.
    • Then, pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Case Replacement, Remove the GPU ( Optional ): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the GPU ( Optional ): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the GPU ( Optional ): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the fan bracket, there is something like a button. Press it to move the support to the left (see picture)
    • Then pull the graphics card towards you to take it out of the case
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the PCI-e cables from the motherboard
  9. Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a screwdriver, unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you (to move it away from the case)
  10. Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Behind the fan bracket, there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As with the top, remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 2 x 4 pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step, or else you risk damaging the connectors on the motherboard and making your fans and speaker useless!
  15. Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the CPU support towards you
    • Do not use force during this step. If it does not come out easily, ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Warning, remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Case Replacement, Remove the expansion card: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 5 screws that hold the card in place.
    • Be careful to unplug the power button of the card!
  18. Mac Pro 2009-2012 Case Replacement, Remove the cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Case Replacement, Unplug the power supply: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push on both knobs to remove the power connector
    • Do not use force, if you are struggling ensure you are squeezing the clips adequately.
  20. Mac Pro 2009-2012 Case Replacement, Separate the power supply: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Separate the power supply: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Case Replacement, Remove the power supply: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the power supply: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the power supply: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Case Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro 2009-2012 Case Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Case Replacement, Change the case: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the steps in reverse for reassembly!
To reassemble your device, follow the instructions in reverse order.
crwdns2935229:023crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
remitouch
crwdns2935283:010/12/16crwdne2935283:0
1,039 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Bonjour, j’ai un mac pro 5,1 de 2010 dont les clapets (ou les trappes, j’ignore le terme exact) de la baie des lecteurs de disques restent ouverts à chaque fois qu’ils sont actionnés. Je n’ai pas réussi à les démonter, et les 2 gouttes de 3 en 1 sur les glissières latérales n’ont rien changé au problème. Je n’ai trouvé aucun tutoriel, ni même aucune occurrence de ce problème sur le web. Pourriez-vous me donner quelques conseils ? Merci.
Gabriel Fracque - crwdns2934203:0crwdne2934203:0
Amazing explanations and perfect picture track on each move made.
Thanks much - this was very helpful :)
Dennis.
Dennis OBrien - crwdns2934203:0crwdne2934203:0
Hello sir , I have a problem with my Mac Pro 5,1 mid 2010 Xeon 6core Cpu 64 GB Ram RX580
I erase SSD Hard Drive and I want to reinstall mojave OS and it does not work still appear ‘Missing Operating System’
I try to use all commends on startup like (Option) (Commend+R) (Option+Commend+R)(Option+Commend+R+P) and more commends
but nothing work with it … please I want help . I need your help please , please …
Hussain Khan - crwdns2934203:0crwdne2934203:0
You’d probably get an answer a lot quicker if you just posted that as a question.
[deleted] -
Thanks for posting this guide!
I used it to replace all the cooking fans in my macpro5,1. Worked great!!
Andrew Clark - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 269
crwdns2942667:0crwdne2942667:0 28,961
