Logitech UE Megaboom 4 Battery Replacement
  1. Logitech UE Megaboom 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Take a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
  2. Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom of the speaker and place it off to the side.
    • Once the glued seal is broken you will be able to pull it off with your hands.
  3. Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push with your thumbs on the two plastic pieces on the inside of your speaker.
    • The inside components will begin to slide out of the top from the mesh casing.
  4. Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The case and internal components of your speaker should now be separated.
  5. Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery out with your fingers.
    • When pulling the battery out, you may need to wiggle it a little bit or use a rubber grip on your fingers.
  6. Logitech UE Megaboom 4 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When installing the new battery, ensure that the battery connector aligns with the connector on the speaker so they don't get damaged.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Konner Buchal
crwdns2935283:002/03/25crwdne2935283:0
464 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-4, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-4, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G4
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 104
