Use this guide to replace the battery in a Logitech MX Ergo.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, flip the mouse's power switch into the OFF position.
Remove the magnetic cover by pulling it away from the bottom mouse half.
Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
Insert a spudger into the hole on the bottom of the mouse, located under the trackball.
Use the spudger to push the trackball out of its recess.
Remove the trackball.
Insert an opening pick into the gap on the right side of the mouse.
Rotate the opening pick about 30 degrees to unhinge the plastic clip.
Slide the opening pick to the lower right side of the mouse.
Slide the opening pick to the bottom side of the mouse.
Rotate the opening pick about 30 degrees to unhinge the plastic clip on the bottom end of the mouse.
Slide the opening pick to the center of the left side next to the recess of the trackball.
Rotate the opening pick to unhinge the remaining plastic clip.
For better access, place the top half of the mouse to the left of the lower half of the mouse.
Use the pointed end of a spudger to gently lift the left side of the black sliding lock on the interconnect cable socket until it stops.
Use the pointed end of a spudger to gently lift the right side of the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
Remove the top half of the mouse.
Use the pointed end of a spudger to push the battery connector up and out of its socket.
Insert the long edge of an opening pick between the battery and its housing at the side opposite the battery cable.
Push the opening pick under the battery and lift up to pry the battery off of its housing.
Use you fingers to lift the battery out of its housing.
Use your fingers to carefully pull the cable out of the socket.
Remove the battery.
Follow this guide to install new precut adhesive.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:016crwdne2935229:0
crwdns2947412:07crwdne2947412:0
This guide is fantastic! It was super easy to fix! Thanks!
Thank you for this !! Visited this site before for other tutorials you guys are great. This was easy to follow worked good for me.
Its a very thorough explinations and guide except the most important point.
Where to buy the new replacement battery.
Those are very well-done instructions. The new battery installation went very well. Thanks for the help.
hi where did you buy the battery?
Yanna -
If you do a google search on Logitech 533-00121 battery you will find suppliers
An easier way to separate the two halves of the case: After removing the ball in Step 4 of the above Guide, (1) hold the case in your right hand, with the power switch forward and facing left, the concave ball recess facing up and to your right, and the edge of your right thumb firmly grasping the right edge of the rim around the ball recess (the rim is on the upper half of the case and protrudes a bit from the ball recess, so you can get a tight grip on it; the ball recess is on the lower half and is separate from the rim); (2) insert a sturdy rod into the hole that you used to remove the ball (e.g., the shaft of a Phillips-head screwdriver); (3) while holding the rim with your thumb as described in (1), gently but firmly twist the sturdy rod downward to pry the two halves of the case apart; (4) as described in Step 9 of the Guide, the two halves are connected by a cable, so as they separate be careful to keep them close to each other to prevent damage ; and (5) continue with Steps 9 through 16 of the Guide.
