Logitech K830 Battery Replacement
  1. Logitech K830 Battery Replacement, Turn off the keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the keyboard's power switch into the OFF position.
    • A red indicator is visible beneath the switch when it's in the OFF position.
  2. Logitech K830 Battery Replacement, Remove the foot pads: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement, Remove the foot pads: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement, Remove the foot pads: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger under the edge of one of the feet.
    • Push the spudger underneath the foot and pry up to release its adhesive.
    • The foot should come away from the keyboard without much force. Pry slowly to avoid tearing the foot.
    • Once you can grip the foot with your fingers, peel it up and away from the keyboard to remove it.
    • Repeat this step for the remaining three feet.
  3. Logitech K830 Battery Replacement, Remove the eight screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eight 6.8 mm-long screws securing the upper case to the lower case.
  4. Logitech K830 Battery Replacement, Release the clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement, Release the clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The upper case is secured to the lower case by clips on every side of the keyboard. In the next steps, you'll release the clips on each side.
    • Insert an opening pick about 2 mm into the gap between the upper case and lower case at the bottom-right corner of the keyboard.
    • This creates a gap large enough to insert the flat end of a spudger.
  5. Logitech K830 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert the spudger more than 2 mm into the keyboard or you may damage internal components.
    • The internal battery is located near the right edge of the keyboard. Take care not to puncture or bend the battery with your spudger—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert the flat end of a spudger about 2 mm into the gap between the upper case and lower case in the bottom right corner of the keyboard.
    • Rotate the spudger clockwise to release the first clip.
  6. Logitech K830 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the spudger about 3 cm along the keyboard's edge toward the volume buttons.
    • Rotate the spudger clockwise to release the next clip.
  7. Logitech K830 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The spudger should now be about in the middle of the right edge of the keyboard.
  8. Logitech K830 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the spudger another 3 cm toward the volume buttons and repeat the previous step.
  9. Logitech K830 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The spudger should now be at the top-right of the keyboard.
  10. Logitech K830 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the clip release procedure for the left edge of the keyboard.
  11. Logitech K830 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't insert the opening pick more than 2 mm into the case or you may damage internal components.
    • Insert an opening pick about 2 mm into the gap between the upper case and the gray support bar closest to the volume buttons.
  12. Logitech K830 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick across the entire length of the keyboard to release the clips on the top edge.
  13. Logitech K830 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the last step for the bottom of the keyboard.
  14. Logitech K830 Battery Replacement, Open the upper case: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement, Open the upper case: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement, Open the upper case: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to remove the upper case completely—it's still attached to the lower case by a delicate interconnect cable.
    • Lift the upper case up by about 2 cm.
    • If the upper case doesn't lift completely off of the lower case, repeat the clip release procedure for the stuck area.
    • Tilt the upper case about 45 degrees so that the keycap letters are upside-down.
    • Keep the upper case as close to the lower case as possible to avoid straining the interconnect cable.
  15. Logitech K830 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the top edge of the upper case on your work surface as close to the lower case as possible.
    • Hold the upper case at about 45 degrees to avoid straining the interconnect cable.
  16. Logitech K830 Battery Replacement, Gray support bar information: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement, Gray support bar information: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the gray support bars fall out during this repair, place them back into their slots with their notches facing upward.
  17. Logitech K830 Battery Replacement, Disconnect the interconnect cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement, Disconnect the interconnect cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black tape covering the interconnect cable connector.
    • Set this tape aside. During reassembly, place the tape back into its original position on the motherboard. Be careful not to damage any of the surface-mounted components.
  18. Logitech K830 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to push the interconnect cable connector's locking tab toward the cable.
    • The connector is unlocked when the locking tab lines up with the white rectangle on the motherboard.
  19. Logitech K830 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt tweezers to grip the interconnect cable by the blue section close to the connector.
    • Pull the interconnect cable out of its connector in the direction of the cable.
    • During reassembly, follow these steps to reconnect the interconnect cable:
    • Make sure the locking tab is in the unlocked position.
    • Insert the ribbon cable so that the black line on the cable lines up with the white rectangle's edge closest to the cable.
    • Use your fingernail to move the locking tab into the locked position.
  20. Logitech K830 Battery Replacement, Remove the upper case: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper case from the lower case.
  21. Logitech K830 Battery Replacement, Disconnect the battery: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement, Disconnect the battery: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the yellow tape covering the battery cables.
    • Set this tape aside. During reassembly, place the tape back into its original position covering the cables on the battery.
  22. Logitech K830 Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take care not to puncture or bend the battery—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the battery edge opposite the battery connector.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the battery.
  23. Logitech K830 Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly insert the tip of an opening pick under the top edge of the battery.
    • Make sure the opening pick is sliding under the battery and not pushing into the battery's side.
    • If the opening pick isn't sliding under the battery, apply more isopropyl alcohol and try again.
    • Push about half of the opening pick under the battery while slowly lifting up.
  24. Logitech K830 Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the battery about 1 cm above the battery recess.
    • Take care not to strain the battery cables while handling the battery or you may damage the battery connector socket.
  25. Logitech K830 Battery Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the battery 45 degrees so that the edge closest to the battery connector rests in the battery recess about 1 cm from the connector.
    • Place two fingers under the bottom side of the battery to support it.
  26. Logitech K830 Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K830 Battery Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While supporting the battery, disconnect the battery by pulling on the three cables as close to the connector as possible.
    • If the battery connector doesn't easily come out of the socket, gently rock it back and forth to "walk" it out of the socket.
    • During reassembly, make sure the battery connector is oriented correctly. The black cable should be on the side closest to the ten solder points on the motherboard.
  27. Logitech K830 Battery Replacement, Remove the battery: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the keyboard.
    • If there's any alcohol solution remaining in the keyboard, carefully wipe it off with a coffee filter or allow it to air dry before installing your battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech K830 Answers community for help.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46,779 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Thanks Kyle - absolutely superb instructions - couldn't be clearer.
Chris Ellis - crwdns2934203:0crwdne2934203:0
Hey Kyle, do you have any leads on where to source quality batteries for the K830?
Alex Martin - crwdns2934203:0crwdne2934203:0
Did you ever find a place to get replacement batteries from? My K830 Micro-USB port came lose from the PCB board and was lost so while tring to find out if I can order a replacement I figured I should change the battery.
Anthony Barnes -
I have yet to buy one myself and test / try the quality, but I did find these:
https://newpower99.com/products/logitech...
I am not sure of the difference, they look like the same product with different packaging / labelling. The NewPower99 batteries can also be found on newpower99.ca, and amazon.ca.
They are about double the price of other brands that I can find on Amazon.ca or Amazon.com, but I have a feeling those no name Chinese brands on Amazon are offering products with questionable quality. For example, on Amazon you may come across brands like "STARTONG", and many different brands selling the exact same battery that has a black sticker with "X-Longer" on it. I would recommend staying away from those batteries.
Hopefully that helps a bit, do me a favour and reply back if you find something that works!
Alex Martin -
I have this keyboard and the T and V keys stopped responding, I used alcohol to key the contacts at first but ultimatly I used a rubber eraser to "polish' the T contact points. The trick brings that particular key back to life
WingPui Yip - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 4,454
