Logitech K800 Battery Replacement
Adam O'Camb
crwdns2944109:0crwdnd2944109:0Adam O'Cambcrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Ndz 20, 2024crwdne2944111:0
10 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the battery in a Logitech K800 wireless keyboard.
For your safety, discharge the battery below 25% before disassembling your keyboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
crwdns2944105:0crwdne2944105:0
  1. Logitech K800 Battery Replacement, Remove the rear compartment screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the 5.7 mm screw securing the rear compartment.
  2. Logitech K800 Battery Replacement, Remove the rear compartment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the rear compartment: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the rear compartment: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rear compartment toward the top of the keyboard and remove it.
  3. Logitech K800 Battery Replacement, Pry up the rear cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K800 Battery Replacement, Pry up the rear cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the edge of an opening tool underneath the bottom edge of the rear cover and pry the cover up to create a gap.
    • You will pry the rear cover away from the keyboard for the next two steps. There are adhesive and clips holding the cover down that will make prying difficult.
  4. Logitech K800 Battery Replacement, Continue prying the rear cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Continue prying the rear cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Continue prying the rear cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Keeping the opening tool under the rear cover, slide it around the right side of the cover to separate the adhesive and clips on that side.
    • It may help to push the tool farther under the cover, toward the middle of the keyboard.
  5. Logitech K800 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Keeping the opening tool under the rear cover, slide it around the left side of the cover to separate the adhesive and clips on that side.
  6. Logitech K800 Battery Replacement, Remove the rear cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the rear cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the rear cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hinge the bottom of the rear cover up until the clips along the top edge of the cover disengage, then lift the whole cover up to remove it.
  7. Logitech K800 Battery Replacement, Reassembly tip: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Reassembly tip: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Reassembly tip: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, start by sliding the clips along the top edge of the rear cover into place.
    • Place the top edge of the cover slightly above the top edge of the keyboard, then slide it down into place.
  8. Logitech K800 Battery Replacement, Remove the front cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the twelve 5.7 mm screws securing the front cover.
    • Use a Phillips driver to remove the three 4.7 mm screws securing the keyboard keys.
  9. Logitech K800 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening tool into the seam along one edge of the front cover. Pry the cover up to create a gap.
  10. Logitech K800 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening tool around the perimeter of the front case to release all the clips securing the front cover.
  11. Logitech K800 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With all the clips released, lift the front cover and remove it.
    Be carful when reassembling power switch on circuit must line up with power switch on plastic cover
    Patrick - crwdns2934203:0crwdne2934203:0
  12. Logitech K800 Battery Replacement, Unscrew the keyboard keys: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the six screws securing the keyboard keys.
    • Four 5.7 mm screws
    • Two 4.7 mm screws
  13. Logitech K800 Battery Replacement, Move the keyboard keys out of the way: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K800 Battery Replacement, Move the keyboard keys out of the way: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently flip the keyboard keys up and over the top of the keyboard to reveal the backlight.
    • Take care not to strain or crease the keyboard keys ribbon cable.
  14. Logitech K800 Battery Replacement, Move the backlight out of the way: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K800 Battery Replacement, Move the backlight out of the way: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently flip the backlight up and over the top of the keyboard to reveal the keyboard backplate.
    • Take care not to strain or crease the backlight ribbon cable.
  15. Logitech K800 Battery Replacement, Remove the backplate: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the backplate: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement, Remove the backplate: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp one end of the backplate and lift it off of the keyboard case.
    • Remove the backplate.
  16. Logitech K800 Battery Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K800 Battery Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top edge of the battery connector with your fingers or a tweezer.
    • Pull the connector straight out of its socket on the motherboard.
  17. Logitech K800 Battery Replacement, Free the battery cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the tape securing the battery cable to the case.
  18. Logitech K800 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery cable out of its slots in the keyboard case.
  19. Logitech K800 Battery Replacement, Remove the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the keyboard case underneath the battery for two minutes.
  20. Logitech K800 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K800 Battery Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the battery away from the keyboard case.
    • If you encounter significant resistance, stop and apply more heat.
  21. Logitech K800 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, you may use the old battery adhesive with your new battery. Alternatively, you may clean any old adhesive residue from the battery compartment using high-concentration isopropyl alcohol and install new adhesive from a follow pre-cut adhesive sheet.
    Thank you, I was looking for a guide like this for a long time.
    Dan Nguyen - crwdns2934203:0crwdne2934203:0
    Easy to follow but why is battery ID picture upside down, and why didn't you snap a decent pic of the connector? Other than that, Well done.
    Micah Day - crwdns2934203:0crwdne2934203:0
crwdns2935229:019crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
213,871 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:016crwdne2947412:0
the original took 2 lithium AA rechargeables. their update just creates ewaste
Kevin Weldon - crwdns2934203:0crwdne2934203:0
not lithium! Just standard Ni-MH AA's. I was pretty disappointed when I bought the second keyboard (the fist one was already pretty beaten up) only to discover that below the battery door there is just plastic and no battery! bastards... I used the keyboard from time to time as 2xAA charger (as most of the time it was connected to power) and I swapped those fully charged batteries with discharged ones from other devices that take 2xAAs aswell
Nellinka Fotky -
Do you have a part number for the replacement battery?
Ryker Bailey - crwdns2934203:0crwdne2934203:0
The part in the canadianbatteries.com link is not the correct part for this keyboard.
The correct PN is 533-000141, this has longer leads on the battery and the battery capacity is larger than the one linked. Aliexpress is the only place I have been able to locate a new one.
Ryker Bailey -
Kevin, exactly right. I have 2 of these, the original and this one. Whoever the brain trust was that came up with this cockamamy idea was a numbskull. The rechargeable batteries dont last forever, why make a product. you must basically throw away because of the imbecile design? Sheesh.
Daniel Roberts - crwdns2934203:0crwdne2934203:0
I was able to remove my battery and keep my K800 operating with USB power. I can wait for a battery from AliExpress.
Part No.---Logitech 802085P
https://www.aliexpress.com/item/10050047...
Scott Hayes - crwdns2934203:0crwdne2934203:0
How well does the Aliexpress battery work. I have been hesitant to purchase from them. thanks, John V.
John Vaillancourt -
What keyboard would have a similar feel to the K800? `
Nathan Cobb - crwdns2934203:0crwdne2934203:0
I wander if it's possible to replace some parts from old K800, the one powered by 2 AA batteries, and make a new one to run on AA batteries?
Any advice on how to deal with it? I have both old one, which is fatigued, but working, and a new one.
Mikołaj Koziak - crwdns2934203:0crwdne2934203:0
I've always chosen Logitech for quality and durability of their products. Here this company have clearly made a move to products that can't be repaired even for the most common cause of issue: change the battery. Wrong choice, really, completely in the reverse of where the world need to go.
As software engineer, I have always recommended Logitech products for my family, for office. Well, I'm done with Logitech.
This company is malfunctioning and now needs to be stopped.
Julien - crwdns2934203:0crwdne2934203:0
I didn't know there were two versions of this keyboard. Mine wasn't taking a charge and I found this website. I hopped over to Amazon, found the kit and battery, bought it. It was delivered this morning and I was all prepared to do an archaeological dig on this keyboard. I take the battery cover off and bam! 2 rechargeable batteries right there. Guess I could've done more research and read you guys' comments. 😅
billyintampa - crwdns2934203:0crwdne2934203:0
You need to warn people to check if there are 2 rechargeable AA's after doing step 2, in which case you don't need all the following steps and simply need to replace the 2 AA's. Otherwise, they may simply buy a new keyboard instead of all this hassle. Logitech should stay with the simple 2 AA design. My original AA's lasted more than 8 years.
Wtax1 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 34
crwdns2936753:07crwdne2936753:0 130
crwdns2936753:030crwdne2936753:0 537
crwdns2942667:0crwdne2942667:0 28,511
