Logitech G915 Wireless (Clicky) Battery Replacement
  1. Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the power switch on the top edge of your keyboard into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your keyboard.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Logitech sticker hides two battery cover screws.
    • Heat an iOpener and lay it on the Logitech sticker for one minute.
  3. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to peel up a corner of the sticker.
    • Use your fingers to peel up and remove the sticker.
  4. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
  5. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
  6. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plastic clips secure the perimeter of the battery cover.
    • Insert your finger in the USB receiver compartment on the battery cover.
    • Pull up the bottom edge of the cover to release the clips.
    • Don't try to fully remove the cover yet, as it's still connected by the battery cable.
    • Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
  7. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of angled tweezers to firmly grip the battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm hold.
    • Slide the connector straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
  8. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Logitech G915 Wireless (Clicky) Battery Replacement, Install your new battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement, Install your new battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement, Install your new battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the next three steps to remove the old battery from the cover and install your new one.
    • Light adhesive secures the battery to its cover.
    • Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
    • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
    • Remove the battery from its cover.
  10. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay your new battery into its recess in the keyboard so the cable is on the left edge, near the battery connector.
  11. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Cut a piece of double-sided tape so it fits on the line of squares on the bottom of the battery cover.
    • Press the tape firmly into place on the squares and remove the plastic backing.
  12. Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G915 Wireless (Clicky) Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
    • Use a spudger to push the battery connector fully into its socket.
  13. Logitech G915 Wireless (Clicky) Battery Replacement, Reassembly information: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the battery cover into place and firmly press down around its edges to engage all the clips.
    • You should feel and hear "clicks" as the clips engage.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
117,396 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,024crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 868
