Follow this guide to replace a worn-out or dead battery in your Logitech G715 wireless gaming keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Slide the power switch on the top edge of the keyboard to the OFF position.
Unplug all cables from your keyboard.
Lay your keyboard down with the feet facing up on a clean work surface.
If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
Heat an iOpener and lay it on the Logitech sticker for one minute.
Use an opening tool, spudger, or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
Peel up the sticker with your fingers and remove it.
Use a Phillips screwdriver to remove the two 8.4 mm‑long screws securing the battery cover.
Insert your finger in the USB receiver compartment on the battery cover.
Pull up the bottom edge of the cover to release the clips.
Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
Use a pair of angled tweezers to firmly grip the battery connector.
Gently rock the connector side‑to‑side and slide it straight out of the socket.
Remove the battery cover.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$2.99
Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
Remove the battery from its cover.
Remove any old adhesive from the battery cover.
Use thin, double‑sided tape to secure the battery to the cover.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
