Lenovo Yoga C930-13IKB Back Cover Replacement
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C930-13IKB Back Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
    The gap is so small that I wasn’t able to insert anything to pry the cover up. The suction cup tool lifted the cover off easily.
    Thomas Capobianco - crwdns2934203:0crwdne2934203:0
    There is a very convenient spot to begin the prying process. Up by the hinge, where the metal back turns in perpendicular to the edge to get around the hinge mechanism, there is a gap between the cover and the rest of the laptop where it can be pried up easily. From there it is easy to run a tool and widen the gap all the way around.
    Alex Yantis - crwdns2934203:0crwdne2934203:0
    I tried Thomas's suggestion first, and it worked like a charm: the suction cup took it right off.
    Instead of pushing the cup against the laptop I "pulled it flat" and placed it against the back, so it'd just suck onto it. (Didn't want to deform the laptop cover)
    Panopticon - crwdns2934203:0crwdne2934203:0
    Opening this up again to re-seat the SSD ...and find that Alex's suggestion is also very good. I would start with his suggestion and then move to Thomas's if the back doesn't just jump off.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C930-13IKB Back Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the cover off with your hands.
Hanna Lazkani
crwdns2935283:001/23/20crwdne2935283:0
824 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G5, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G5, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G5
On mine, not T5 but T4. Also screw holding the chip in is philips 000.
Jim Steele - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,361
