Lenovo Yoga 910-13IKB Bottom Panel Replacement
  1. Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four M2 x 1.7 mm screws securing the battery to the laptop.
    • Remove the battery.
  3. Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Phillips screws that attach the trackpad to the device.
    • Use a spudger to disconnect the ribbon cable connector from the trackpad.
    • Remove the trackpad using a spudger.
  4. Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove six screws attached to the USB ports on both sides of the device.
    • Detach both ribbon cables attached to each USB port with a spudger, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small Phillips screwdriver to remove all single screw securing the SSD stick to the motherboard.
    • Slide the SSD stick from the port on the motherboard.
  6. Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Bottom Panel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small Phillips screwdriver to remove four screws from the fans.
    • Remove the back connector strip using a spudger to pry it off of the device.
    • Remove the fans.
    • Now, only the bottom panel should remain.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
98.556 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2935297:023.190crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,900
