Lenovo YOGA 730-15IKB Screen Replacement
crwdns2942287:0crwdne2942287:0Follow this guide to replace the screen on your Lenovo YOGA 730-15IKB.
Before you jump to replacing the screen, try detaching and reattaching the display connector. This seems to solve many display flickering issues. See the troubleshooting page for more information about this common issue.
If the computer is turning on but the display is black, you might need to replace the screen. You could also replace the screen if it is cracked or if it starts getting dead or stuck pixels (again, see the troubleshooting page for more information).
crwdns2944105:0crwdne2944105:0
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pry up the bottom cover with an opening tool.
Start at the front edge of the cover and make your way along the sides.
Pull the bottom cover up and away from the back hinges.
This is a perfect time to unplug the battery connector. This can save you from shorting something out. The battery terminal is easy to see and access.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
Remove the four 4mm Phillips #1 screws securing the battery.
Lift the battery up and out of the chassis.
You do not have to remove the fans and other items to replace a screen!
Remove the black and white antenna wires from the groove on the right side of the fan.
Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
You can also use the white tabs on the connector to push the cable free.
Pull the fan up and towards the front of the laptop.
Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
Remove the fingerprint reader ribbon cable located at the bottom left of the motherboard.
Pull up on the black tab on the connector.
The ribbon cable should easily pull out of the connector.
Remove the three other ribbon cables at the lower edge of the motherboard.
For each, lift up the black tab on the connector.
The ribbon cables should easily pull out of the connectors.
Disconnect the speaker cable by pulling the wire towards the front of the laptop.
Remove the sticky tape from the top of the wireless card.
Pull the black and white antenna wires off of the wireless card.
Pull up on the thick gray display cable near the back of the laptop to disconnect the display.
Disconnect the cable by pulling the bundle of wires firmly toward the back of the laptop.
Pull the motherboard up out of the laptop chassis.
Remove four 4mm (silver colored) Phillips #1 screws.
Pull the thick gray display cable out from under the hook that holds it in place.
Remove the white antenna wire from underneath the hooks near the back of the laptop.
On the back of the keyboard, slide the white antenna cable past the edge of the hinge.
Pull the keyboard upward and towards the front of the screen to make room for the cable.
Pull the thick display cable and the black antenna cable past the hinge.
Tilt the left side of the keyboard upward. This helps create some room around the hinge.
Pull the keyboard up away from the screen. After the display and antenna wires have been moved, the keyboard should easily come apart from the screen.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
Isn't this missing "How to disassemble the LCD Panel" ? I'll try to take some decent pictures while I'm putting mine back together. Does anyone know where I can buy some of that special adhesive tape that behind this screen?
