The motherboard of a laptop is the component that connects all of the other components together. It is the main PCB or primary printed circuit board that exists in many sizes and configurations depending on the laptop. It could also be considered the backbone of the laptop.
If the motherboard of your Lenovo ThinkPad T480 crashes you may need to replace it. Signs that it needs to be replaced include physical damage, freezing or glitching, the “blue screen of death”, overheating, slowing down, blank screen, and not recognizing hardware.
Prior to beginning this repair, be sure to disable the internal battery, power off the device, and unplug the laptop from any external power source.
Flip the laptop over so the bottom of the device is showing.
Using your fingers, slide the lock on each side of the battery to the unlocked position.
Remove the battery from the slot.
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Open the laptop so the keyboard is facing you.
Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
Hello Sarah,
Thanks for this great guide.
I mistakenly broke this ribbon connector on my T480 and wish you will help with any info where to source a good one and how to fit it back. It has prevent my keyboard from working.
Using the Phillips #1 screwdriver, loosen the six captive screws.
Insert the blue plastic opening tool into the space between the lower case and the chassis.
Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
Remove the back case.
I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
Hi Benjamin, thanks for the tip!
You also have to pry the near the battery. I experienced that you can't pry the front side.
I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
Lift the battery straight out of its recess and remove it.
DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
You lift the internal battery first from the top, and then the bottom.
This is because there are 2 "clips" on the bottom that the battery uses to slide into the chassis.
Pull the black plastic sheet back to reveal the RAM stick.
Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it .
Slide the RAM stick out from the memory module slot.
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
Slide the Wi-Fi card out from the slot to remove it from the board.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the black nylon spudger, pry the coin cell battery off of the motherboard.
Using the Phillips #1 screwdriver, remove two 4.8 mm screws from the right speaker.
Lift the right speaker out of the case.
Gently remove the speaker cable from the perimeter of the chassis, connecting the right speaker to the left speaker.
Remove two 4.8 mm screws from the left speaker using the Phillips #1 screwdriver.
Using the black nylon spudger, remove the slide connector which attaches the left speaker to the motherboard.
Remove the left speaker from the case.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Use the black nylon spudger to slide the fan connector parallel to the motherboard and out of its socket on the motherboard.
Lift the fan assembly off of the board.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Lift the hard drive up with a tab if it has one or with your spudger.
Lift the drive assembly from the system.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Lift the I/O bracket off the motherboard.
Using the Phillips #1 screwdriver, remove the three 4.1 mm screws from the RJ45 bracket.
Lift the bracket off of the motherboard.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Using the black nylon spudger, disconnect the LCD cable from the motherboard.
You got camera and display cable mixed up. The small one is for camera and the long one (50 pin) for screen.
Steps 3-8, 11, 13-16, 18-19, 21-29 can be skipped. Also, there is a step missing for unscrewing screen lid from body.
Use the tip of a spudger or an opening tool, to flip up the small, hinged locking flap on the camera cable connector to remove the cable from the motherboard.
Using the black nylon spudger, remove the NFC cable connector and trackpad connector from the motherboard.
Using the Phillips #1 screwdriver, remove seven 3.6 mm screws from the motherboard.
Lift the motherboard off of the case to remove it.
Super helpful! Thanks so much!
EN: NOTE: The built-in battery needs to be disabled first! This can be done in the BIOS.
DE: ANMERKUNG: Die eingebaute Batterie muss zuerst deaktiviert werden! Dies kann im BIOS getan werden.
Thomas - crwdns2934203:0crwdne2934203:0
