Lenovo ThinkPad T470 Bottom Cover Replacement
  1. Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
    To remove the trackpad/touchpad, you can skip a lot of steps here:
    4, 5, 6, 7, 8 are for removing the keyboard, which isn't required to swap the touchpad.
    14, 15, 16 are for removing the top RAM stick.
    22 to 41 are not required (so continue with step 42)
    44, 45, 46, 47 are not required either.
    So to replace the touchpad, do these steps:
    1, 2, 3, 9, 10, 11, 12, 13, 17, 18, 19, 20, 21, 42, 43, 48, 49, 50, 51
    tobi - crwdns2934203:0crwdne2934203:0
  2. Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
    There may be a SIM card holder inserted. If there is, it will prevent the bottom cover from coming off. In the photo, the SIM card holder would be center left edge of laptop. Use a straight pin or paperclip to eject the holder to release the laptop bottom cover.
    Frugal Guy - crwdns2934203:0crwdne2934203:0
    Also most SIM eject tools that come with smartphones will also work.
    If you need a dedicated "place" where you won't loose those small SIM ejectors, then you can also use the SIM eject bits that are included in the various iFixit toolkits, usually the extended versions.
    Tai Lam -
  5. Lenovo ThinkPad T470 Bottom Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
    Don't forget to unplug the battery from the motherboard before removing it.
    Mike Stalenberg - crwdns2934203:0crwdne2934203:0
    Yeah, what's in the photo seems to be the "space filler" unit.
    Not sure what's the reasoning for having this as a produced product, but this does seem to match my memory for items being sold via the Lenovo parts storefront at "pcsupport.lenovo[.]com" (which is not to be confused with the public consumer storefront at "lenovo[.]com/*").
    Internally, the T470 and the T480 use the same internal battery, so keep that in mind if you're shopping for an internal battery.
    Tai Lam -
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
95 879 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 677crwdne2935297:0
What kind of screws do they use for the bottom cover panel of thinkpad t470?
LEE XUAN YI - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 4,065
