Use this guide to replace the motherboard in your Lenovo ThinkPad T460 laptop.
The motherboard, also known as a system board or mainboard, is the primary printed circuit board (PCB) in a computer that enables communication between the internal components.
Diagnosing a faulty motherboard is tricky since the symptoms are similar to other failing components. Signs of a faulty motherboard may include overheating, error codes, the blue screen of death, or failure of other ports and components.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
Use your other hand to slide the battery towards the back of the laptop.
Lift the battery up and away from the laptop.
Use the pointed end of a spudger to pry the two rubber stoppers out of the battery compartment.
Place the laptop so that the top is facing upwards.
Open the lid of the laptop.
Use the pointed end of a spudger to push the keyboard towards the screen using the two notches on the bottom of the keyboard.
Loosen the six captive screws in the keyboard frame using a Phillips #0 screwdriver.
Use your hands to pull the keyboard up and towards you by a few millimeters to remove it from its tray.
Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of blunt-nosed tweezers to lift the black flap away from the cable connectors.
Use the flat end of a spudger to flip up the locking flap securing the ribbon cable.
Use a pair of blunt-nosed tweezers to pull the ribbon cable out of its connector.
Use the flat end of a spudger to flip up the locking flap securing the bottom ribbon cable.
Pull the ribbon cables through the slot in the black flap.
Remove the black flap from the keyboard.
Use your hands to lift the keyboard up and away from the laptop.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Slide the spudger along the right and top sides of the bottom cover to release the clips.
Use the spudger to pry the upper left corner up by a few millimeters.
Pry up the sections of the bottom cover with printed logos of the ports.
Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
Use both hands to lift the bottom cover up and away from the laptop.
Use a pair of blunt nose tweezers to pull the black connector out of its socket.
Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
Use your hands to lift the battery up and away from the laptop.
Remove the single 3.7 mm screw from the left side of the hard drive using a Phillips #1 screwdriver.
Use your hand to lift up the hard drive by a few millimeters.
Pull the hard drive to the left to detach it from its connector and remove it from the laptop.
Use your fingers to lift up the black flap covering the RAM.
Use your fingers to push the metal clips on either end of the first RAM stick outwards.
Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
Use your fingers to push the metal clips on either end of the second RAM stick outwards.
Use your fingers to lift up the black flap covering the Wi-Fi card.
Use the flat end of a spudger to disconnect the gray and black coaxial wires from the Wi-Fi card.
Remove the single 3.7 mm screw from the right side of the Wi-Fi card using a Phillips #1 screwdriver.
Use your fingers to lift the Wi-Fi card up and out of its slot.
This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 32-35 to remove it.
Use a pair of blunt nose tweezers to pull the white CMOS battery connector out of its socket.
Use your fingers to pull the red and black bundled wire from its slot.
Pry the CMOS battery up using the flat end of a spudger.
Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan assembly in a crosswise pattern.
Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan assembly in a crosswise pattern.
Use your hands to lift the fan assembly up and away from the laptop.
Use the flat end of a spudger to detach the USB cable from the motherboard.
Use your fingers to move the detached part of the USB cable away from the motherboard.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use a pair of tweezers to lift the LCD cable bracket away from the motherboard.
Use the flat end of a spudger to disconnect the flat-topped LCD cable connector.
Use the pointed end of a spudger to lift up the metal bracket on the camera/microphone cable.
Use the flat end of a spudger to detach the camera/microphone cable connector from its socket.
Use your fingers to remove the gray and red coaxial cables from their slots along the motherboard.
Use your fingers to remove the blue and black coaxial cables from their slots along the top of the motherboard.
Use the flat end of a spudger to flip up the locking flap securing the power button cable.
Use a pair of blunt nose tweezers to slide the power button cable out of its connector on the motherboard.
Use a pair of blunt nose tweezers to pull the white speaker cable out of its socket on the motherboard.
If your laptop has a fingerprint reader, use the flat end of a spudger to lift up the black tab and slide the cable out of its socket on the motherboard.
Use the flat end of a spudger to flip up the locking flap securing the trackpad ribbon cable.
Use the flat end of a spudger to disconnect the smart card cable from the motherboard.
Use a pair of blunt nose tweezers to pull the white DC-in cable out of its socket on the motherboard.
Remove the six 3.7 mm screws from the motherboard using a Phillips #1 screwdriver.
Remove the single 5.6 mm screw from the Ethernet/USB port bracket using a Phillips #1 screwdriver.
Use your fingers to slide the bracket to the left and away from the motherboard.
Use both hands to pull the motherboard straight up and away from the laptop.
I used this guide to complete my first "iFixit" project - replacing the trackpad on my T460.
Wow, I was amazed at the quality of the instructions! The instructions and photos were very clear. In particular, I like the before and after photos for most steps. These make it so much clearer what direction you need to move something or make it simple to know where the screws are.
Thanks @kristen !
