Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement
  1. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Phillips #1 Screwdriver
    $5.49
    • Loosen the eight PH1 screws on the back panel using the Phillips #1 screwdriver.
    • These screws stay seated within the back panel so do not try to remove them.
  2. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Tool
    $1.99
    • Remove back panel using a plastic opening tool or a spudger.
    • Ensure that all sides of the panel are separated (audible clicks will be heard when separating) from the device frame.
  3. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect the battery from the motherboard by pulling on the fabric tab attached to the connector.
  4. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws holding the battery.
  5. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by gently lifting the top of the battery out from the frame and then pull towards the motherboard.
  6. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • When putting the cables back onto the Wi-Fi Card, make sure that the cables are attached to the correct places on the Card.
  7. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 2.8 mm screw from the Wi-Fi card.
    • The Wi-Fi Card will pop up from the motherboard once the screw is removed.
  8. Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad E15 Gen 3 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the Wi-Fi card from the connector to remove it from the motherboard.
    • When reinstalling the Wi-Fi Card, make sure that the flat side of the card is facing towards the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
B Howton
crwdns2935283:004/09/25crwdne2935283:0
510 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-3, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-3, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G3
crwdns2942667:0crwdne2942667:0 181
