crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Lenovo ThinkPad E15 Gen 3 does not connect to Wi-Fi or does not show available connections. Here are some ways to diagnose or solve the problem.
First Steps
Run Windows Network Troubleshooter
Sometimes Windows can detect and resolve connection issues automatically.
- Run Troubleshooter: Open the search bar
(⊞ win), type “Find and fix network problems” , then select it or hitenter. Follow the prompts on the new window that pops up. If a problem is found, Windows may automatically fix it.
Wi-Fi Settings are Incorrect
Sometimes the issues of your device may be found in the settings of your device.
- Check Wi-Fi Network Settings: Ensure your device is searching for available networks. This can be done by using the search bar of your device
(⊞ win)and typing "Wifi", and then hitting enter. Next, select "Show available networks". Select your desired Wi-Fi network.- If desired network is not showing up, see if other devices (like a phone) are connected. If not, the router may be off or restarting. Try unplugging the router for 30 seconds and plugging it back in.
- Check Wi-Fi Adapters Settings: Open the search bar
(⊞ win), type “View network connections” and then select it or hitenter. Right-click the “Wi-Fi” option. If the top option says “Enable,” click it. If it says “Disable,” the adapter is already enabled and this is not the issue.
Wi-fi Software is Outdated
Outdated software or missing drivers can stop the Wi-Fi card from working.
- Update Wi-Fi drivers: Visit Lenovo Support, select "Scan Now", and download the latest Wireless LAN drivers. Install the driver and restart the computer.
Faulty Wi-Fi Card
If no other steps help, the Wi-Fi card may be faulty.
- Replace the Wi-Fi card: If your card is damaged or not functioning after all previous steps, it may need replacement. Follow this guide to replace the Wi-Fi.
