If your laptop will not start up or stay charged you may need to replace the battery. It is not a difficult project and the hardest part will be prying the back piece off.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Shut down and unplug your device before beginning.
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
Lift the bottom panel off of the chassis.
Remove the four 4 mm Phillips #00 screws securing the battery.
there is no upper screw, right side has 2
Thanks for the catch! I’ve corrected the step.
Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
Lift the battery up and out of the chassis.
crwdns2935229:013crwdne2935229:0
Thank you, very helpful.
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
Has anyone had issues with Legion Y520 laptop saying that the "battery isn't recognized" (with the x through it via the icon in the taskbar) after swapping the battery? I have tried three different ones that all do the same thing (one is even an OEM Lenovo Legion Y520 battery). I am thinking that either, the machine wants it to be an OEM one (not a third party one) and has some sort of check done after POST to verify if it is an official battery or not (and the one I have is just DOA?) or that there is an issue with the connector on the board itself?
I did change the battery and he was charging ton100%. I ttok out de ac psu an d directly dead. When i put the ac psu one the system it works fin, how come?\
Really nice and detailed guide.
I did all these steps (even before finding your guide) but after installing the new battery the laptop does not want to start. I ordered this replacement battery
https://a.aliexpress.com/_ExfQnr8 because my original one lasted only half an hour. The problem now is that the laptop with both old and new battery does not start. Only on AC it works, but AC + any battery nothing.. i tried static discharge (unplug AC and battery) then tried all combos after that but as soon as a battery is connected nothing. I tried BIOS battery disconnect to reset it and again nothing. The closest i came to something on AC + new battery is that it started once but it was showing that the battery is not charging. After that i disconnected it but again laptop does not start. My BIOS is on latest sw, i tried to remove windows battery driver and boot.. not sure what i havent tried yet. When i measure the batteries with a multimeter i get 12,04V for old original one and 11,56V for the new one. Any ideas?
