If your Lenovo IdeaPad Flex 5-1570 does not recognize when devices are plugged into the USB port then your device may have a faulty USB port. The USB port allows the laptop to connect to other devices such as a wireless mouse or an external hard drive. This guide will show you how to successfully replace the USB port. Step 10 requires you to desolder the faulty USB port and resolder a new USB port on to the motherboard, so make sure to read the How to Solder and Desolder Connections guide. Be sure to completely turn off and unplug your device from any external power before you start.
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Use a spudger to pry open the back case at the two hinge cutouts.
Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
Once all the clips have been disengaged, lift off the back cover.
You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
Remove the two 5 mm Phillips #00 screws that secure the fan in place.
Using your hands, remove the wire that is wrapped around the base of the fan.
Disconnect the wire holding the fan and the motherboard together.
Remove the fan from the device.
Remove the two 5 mm Phillips #00 screws that secure the battery in place.
Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
Remove the battery from the device.
My battery completely discharged and even plugging it in won’t power up my computer. I tried removing and replacing the battery, didn’t work, so I completely removed the battery and plugged it in, thinking that would isolate the battery as the issue, but still it will not power up, so I’m thinking it might not be the battery. Shouldn’t it work plugged in without a battery?
Any advice?
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
Using your hands, gently pull the left speaker up and out of the device.
Repeat the previous step for the other speaker and remove the speakers from the device.
Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
Disconnect the auxiliary port cable from the motherboard.
Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
Lift up the connector locking tab and disconnect the cables from the motherboard.
Disconnect the display cable from the motherboard.
Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
Carefully lift and remove the motherboard from the device.
Once you've removed the motherboard, desolder the four contact points on the USB connector.
Remove the USB port from the device.
what is the replacement part number?
Was anyone able to find a part number for the specific USB ports?
