Lenovo IdeaPad 3-15IML05 Battery Replacement
  1. Lenovo IdeaPad 3-15IML05 Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screw driver to remove:
    • Six 5.0 mm screws
    • Four 3.0 mm screws
  2. Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry the bottom cover from the device.
    • Use the opening tool to go around the entire perimeter, releasing the tabs that secure the cover to the frame.
    • Insert opening picks between the bottom cover and the frame to prevent the case from reconnecting.
    • Carefully remove the cover.
  3. Lenovo IdeaPad 3-15IML05 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three screws securing the battery to the frame.
    • Be sure not to lose the screws, as you'll need them for the new battery as well.
  4. Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the sliding connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  5. Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ronan
crwdns2935283:010/24/24crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S2G2
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 266
