Lenovo Flex 2-15 Motherboard Replacement
  1. Lenovo Flex 2-15 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by taking the back plate off of your device. Using a Phillips head screw driver, take out the highlighted screws for your device.
  2. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery from the motherboard by unplugging the cord and removing the screws.
  3. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have the battery removed, locate the cable for your new battery and connect it on the same port from your old battery. Secure it onto the laptop by using the screws. After this step is complete, complete step 1 in reverse order to secure the plate cover over your motherboard.
  4. Lenovo Flex 2-15 Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply gentle pressure with the Philips #00 screwdriver through the hole to pop out the keyboard.
    • The hole in the red circle is a through hole to the back of keyboard. If pressure is applied the keyboard will pop off.
  5. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the keyboard with your fingers.
  6. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the black ZIF locking flap that secures the keyboard ribbon cable.
    • Disconnect the ribbon cable.
    • Remove the keyboard.
  7. Lenovo Flex 2-15 Motherboard Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the one 4 mm screw on the left speaker.
  8. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to disconnect the one 4 mm screw on the right speaker.
  9. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker the connector on the right speaker from the motherboard by pulling the connector out with your fingernail.
  10. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the two speakers out with your hands.
  11. Lenovo Flex 2-15 Motherboard Replacement, Daughterboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement, Daughterboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the black ZIF locking flap. Disconnect the ribbon cable.
  12. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm Phillips #00 screws that secure the daughterboard.
  13. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the daughterboard with your fingers and lift it straight up and out of the chassis.
  14. Lenovo Flex 2-15 Motherboard Replacement, SSD: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips head screw driver, take out the highlighted screws for your device.
  15. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the SSD bay for your device via the highlighted portion.
  16. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pull tab shown here, gently take the SSD out of its highlighted slot.
  17. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We will need to use a Phillips screwdriver to take the SSD out of its bay.
  18. Lenovo Flex 2-15 Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the fan connector from the motherboard.
    • Remove the three 4 mm screws that secure the heatsink with a Phillips #00 screwdriver.
    • Remove the heatsink carefully and set aside.
    • Do not strip the screws.
    • Do not bend the pins in the fan connector port.
    • You will need to reapply thermal paste before replacing the heatsink.
  19. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, pinch the release levers on the side of the ribbon cable.
    • Remove the ribbon cable near the optical drive with your fingers.
    • Do not break the connector on the end of the cable.
  20. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 mm standoff screws in the motherboard with a Phillips #00 screwdriver.
  21. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the black ZIF locking flap that secures the keyboard ribbon cable, then remove the cable.
    • Detach the keybribbon cable from the motherboard by prying with a spudger.
  22. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm Phillips screw under the keyboard with the Phillips #00 screwdriver.
  23. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two connector cables at the back of the motherboard with your fingers.
  24. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 4 mm screws at the top of the motherboard using a Phillips #00 screwdriver.
  25. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last standoff screw near the SSD drive with the Phillips #00 screwdriver.
  26. Lenovo Flex 2-15 Motherboard Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and remove the motherboard from the laptop; there should be little resistance when removing it.
    • If you have difficulty removing the board, check that you have removed all connectors and ribbon cables connecting the board. You may also remove the SSD for additional ease.
    • Lay the motherboard on a nonconducting surface, this will prevent short circuiting.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lavonte Wright
crwdns2935283:009/23/24crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-6, Coppersmith Fall 2024 crwdns2935289:0University of North Texas, Team 3-6, Coppersmith Fall 2024crwdne2935289:0
UNT-COPPERSMITH-F24S3G6
crwdns2942667:0crwdne2942667:0 89
