LG G5 Front Panel Assembly
Joshua Zalmanowitz
crwdns2944107:0crwdnd2944107:0Joshua Zalmanowitzcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Huk 4, 2017crwdne2944111:0
15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to remove your LG G5's front panel assembly. This involves separating the screen from the body of the phone. If you are trying to replace any components within the LG G5, you'll need to follow this guide first!
crwdns2944105:0crwdne2944105:0
  1. LG G5 Front Panel Assembly, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G5 Front Panel Assembly, Front Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Front Panel Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G5 Front Panel Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G5 Front Panel Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Front Panel Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G5 Front Panel Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Front Panel Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
    ayeeeee -
  5. LG G5 Front Panel Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G5 Front Panel Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    My LCD started to let loose using this way to saparate the top and bottom of the phone.
    I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
    Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
    Ray Bas - crwdns2934203:0crwdne2934203:0
    Yep! I did it also with this method. Wayy better and easier ;)
    ronlad.garud -
    My screen cracked taking it out following ifixit method . Right when I got to the part where it starts to curve at the top. Just shattered.
    Randy - crwdns2934203:0crwdne2934203:0
    I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
    Arthur Heller - crwdns2934203:0crwdne2934203:0
  6. LG G5 Front Panel Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G5 Front Panel Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the screen away from the body. The two parts should be completely separated.
Now you can access all the inner components of the phone!
crwdns2935229:032crwdne2935229:0
Joshua Zalmanowitz
crwdns2935283:009/27/16crwdne2935283:0
1.817 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-2, Forte Fall 2016 crwdns2935289:0Cal Poly, Team 18-2, Forte Fall 2016crwdne2935289:0
CPSU-FORTE-F16S18G2
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - crwdns2934203:0crwdne2934203:0
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - crwdns2934203:0crwdne2934203:0
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - crwdns2934203:0crwdne2934203:0
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
crwdns2942667:0crwdne2942667:0 9,921
