LG G3 Earpiece Replacement
    1. LG G3 Earpiece Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
      • Pry the back cover up to separate its plastic clips.
    2. LG G3 Earpiece Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
      • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    1. LG G3 Earpiece Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    2. LG G3 Earpiece Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery out of its recess and remove it.
    1. LG G3 Earpiece Replacement, Loudspeaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four Phillips #00 screws (4 mm length).
    2. LG G3 Earpiece Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
      • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    3. LG G3 Earpiece Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    1. LG G3 Earpiece Replacement, Motherboard Cover Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the eight Phillips #00 screws (4 mm length).
    2. LG G3 Earpiece Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
      • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
      • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
      • Work your way along the right edge.
    3. LG G3 Earpiece Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully lift the right edge of the motherboard cover.
      • The remaining plastic clips should open during this process or can be unhinged easily by hand.
      • Remove the motherboard assembly.
    1. LG G3 Earpiece Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up and disconnect the display flex cable.
    2. LG G3 Earpiece Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up and disconnect the digitizer flex cable.
    3. LG G3 Earpiece Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up and disconnect the rear camera flex cable.
    4. LG G3 Earpiece Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up and disconnect the front camera flex cable.
    5. LG G3 Earpiece Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
      • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    6. LG G3 Earpiece Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    7. LG G3 Earpiece Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the top section of the motherboard and carefully lift it out of the phone.
    1. LG G3 Earpiece Replacement, Earpiece speaker: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G3 Earpiece Replacement, Earpiece speaker: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • During removal of the earpiece speaker, remove it together with the foam gasket underneath.
      • Use a pair of tweezers to remove the earpiece speaker.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
crwdns2935229:08crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
265.485 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Can't just remove the earpiece without removing the motherboard?
bassamxp - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
unless you broke the phone, NO
Tarik Kaya - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
To reassemble the earpiece what kind of adhesive do I need?
DukeCrom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 9,519
