Use this guide to replace the pump assembly in your LG front load washing machine.
The pump assembly drains the tub and expels wastewater out of the washer. It includes the drain pump and drain filter housing.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Tilt the top panel upward to completely disconnect it from the chassis.
Remove the top panel.
Pull the detergent drawer away from the chassis as far as it will go.
Press down on the "Push" button to disengage the clips securing the detergent drawer.
Pull the drawer out of its slot on the chassis and remove it.
Disconnect the connectors attached to the control panel.
Remove the screw(s) securing the control panel to the top edge of the chassis.
Remove the screw(s) securing the detergent dispenser.
Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
Remove the control panel, making sure to thread any cables through the chassis.
Open the front door completely.
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Use your fingers to pull the boot off its lip on the front panel.
Slide your fingers around the lip of the boot until it's completely separated from the panel.
Open the filter panel at the bottom of the front panel.
Unclip the filter panel.
Place a bowl next to the machine.
Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
Remove the plug at the end of the drain filter hose to release excess water into the bowl.
Remove the screw(s) securing the filter trim.
Pull the filter trim straight off the front panel to remove it.
Remove the screw(s) securing the lower front panel.
Remove the screw(s) securing the door latch.
Pull the door latch through its slot in the chassis and let it hang on its wire.
Remove the screw(s) securing the front panel.
Lift the front panel upward to separate it from its clips on the bottom of the chassis.
Pull the front panel away from the chassis to completely separate the front panel.
Twist and remove the pump filter.
Push the drain hose through its hole in the chassis until it's completely inside the device.
Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
Fold the plastic wrap away from the cables, enough to expose the connector(s).
Disconnect the connector(s) attached to the pump cable.
Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
Pull the drain hose straight off its connection on the assembly.
Repeat the last two steps for the pump hose.
Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
My LG WM4270HVA required a 10mm socket to remove these bolts.
Thank you! Because this is a generic LG guide, it doesn't include fastener sizes. I suspect that 10 mm will apply to several similar models. The WM3050, on which this guide is based, required a 3/8 inch socket, so here's a case where omitting the fastener size minimizes confusion. Good info.
Lift the pump assembly out of its location in the frame to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
DO NOT USE THESE Instructions 🤦♂️. It will take you for ever. Go from the back, lie down on the ground take it I’ll put the new one in done. Or do it with someone you leave it a tad side ways and even easier
Mechanicbob - crwdns2934203:0crwdne2934203:0
