LED Disconnect
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. LED Disconnect, Remove the facerest cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the facerest cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the facerest cushion: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. LED Disconnect, Remove the facerest: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. LED Disconnect: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. LED Disconnect, Remove the facerest sensor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the facerest sensor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the facerest sensor: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. LED Disconnect: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. LED Disconnect: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the facerest.
  7. LED Disconnect, Unscrew the front cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Unscrew the front cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to slide the lenses towards each other so that they are positioned towards the center of the device.
  8. LED Disconnect: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four screws securing the front cover from inside the device:
    • Two 5.7 mm screws with fine threads
    • Two 5.5 mm screws with coarse threads
    • The coarse-thread screws can strip easily. During reassembly, tighten the coarse-thread screws until they're hand tight and then no more.
  9. LED Disconnect, Remove the front cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Remove the front cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the location of the plastic welds on both vertical edges of the front cover.
    • After reassembly, the gap between the front cover and the side panels may no longer be flush. This is a cosmetic defect only and will not affect operation. The front cover's clips and screws are sufficient to secure it to the rest of the device.
  10. LED Disconnect: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the top of the front cover near the upper left corner.
    • Slide the opening pick around the upper left corner of the front cover.
  11. LED Disconnect: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick to separate the weld securing the left side vertical edge of the front cover.
    • The weld may require significant force to separate.
  12. LED Disconnect: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the top of the front cover near the upper right corner.
    • Slide the opening pick around the upper right corner of the front cover.
  13. LED Disconnect: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick to separate the weld securing the right side vertical edge of the front cover.
  14. LED Disconnect: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device upside-down.
    • Use an opening pick to disconnect the plastic clips securing the bottom right edge of the front cover to the device.
  15. LED Disconnect: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the bottom edge of the front cover to separate it from the device.
  16. LED Disconnect: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick to disconnect the plastic clips securing the bottom-left edge of the front cover to the device.
  17. LED Disconnect: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device right-side up.
    • Use the opening pick to separate the last few plastic clips securing the top of the front cover.
  18. LED Disconnect: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the front cover.
  19. LED Disconnect, Remove the CPU fan: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the CPU fan: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the CPU fan: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Use a pair of angled tweezers to disconnect the CPU fan cable from the motherboard.
    • Lift the CPU fan connector straight up from the motherboard to disconnect it from its socket.
    • During reassembly, align the CPU fan connector with its socket and use your finger to press it straight down into the motherboard.
  20. LED Disconnect: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the three 5.5 mm screws securing the CPU fan.
    • Use a Phillips screwdriver to remove the two 2.3 mm screws securing the CPU heatsink.
  21. LED Disconnect: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the CPU fan.
    • During reassembly, do not sandwich the red antenna cable between the heatsink and contact plates.
  22. LED Disconnect, Disconnect the power button: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Disconnect the power button: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the black 5.5 mm screw from the power button cable bracket.
    • Use a Phillips screwdriver to remove the 2.3 mm screw from the power button cable bracket.
  23. LED Disconnect: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the power button cable bracket from the motherboard.
    • During reassembly, slot the power button cable bracket back onto the peg on the motherboard before reinstalling the screws.
  24. LED Disconnect: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the power button cable from the motherboard.
  25. LED Disconnect, Remove the proximity sensor array: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Remove the proximity sensor array: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up with the flat end of a spudger to disconnect the three ribbon cables connecting the proximity sensor array to the motherboard.
  26. LED Disconnect: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the 4.5 mm screw from the proximity sensor array.
  27. LED Disconnect: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the proximity sensor array from the motherboard.
  28. LED Disconnect, Remove the internal assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the internal assembly: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect, Remove the internal assembly: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Antenna connectors are fragile and can break off of the motherboard. Use this technique when disconnecting antenna cables.
    • Use a spudger or a pair of tweezers to disconnect the red antenna cable from the front of the device.
    • De-route the antenna cable from the front of the device and place it to the side.
    • During reassembly, be sure to re-route the cable through the brackets and clips securing it.
  29. LED Disconnect: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or a pair of tweezers to remove the black antenna cable from the motherboard.
    • During reassembly, re-route the black antenna cable through its channel and clip.
  30. LED Disconnect: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the ribbon cable connecting the volume buttons and headset jack to the motherboard.
  31. LED Disconnect: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully disconnect the speaker wire from the right side of the motherboard.
    • During reassembly, reinstall the speaker wire with the gold contacts facing towards you and the red wire on top.
  32. LED Disconnect: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully disconnect the speaker wire from the left side of the motherboard.
    • During reassembly, reinstall the speaker wire with the gold contacts facing towards you and the black wire on top.
  33. LED Disconnect: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four 5.6 mm screws securing the corners of the internal assembly to the frame.
    • Use a Phillips screwdriver to remove the two 7.2 mm silver screws from the bottom of the motherboard.
  34. LED Disconnect: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two 5.5 mm screws securing the internal assembly to inside of the frame.
    • During reassembly, make sure the internal assembly is fully seated on its centering pegs on each side and sits flush on the tabs on the frame before tightening these two screws.
    • Check for proper rack and pinion operation before continuing reassembly.
  35. LED Disconnect: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two 4.5 mm screws securing the bracket under the left lens.
  36. LED Disconnect: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bracket under the left lens.
    • To ensure correct operation, make sure this piece is properly seated on the adjuster mechanism by sliding the lenses as close together as possible before reinstalling it.
  37. LED Disconnect: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before removing the internal assembly, tilt the front out slightly to feed the microSD card slot cover through the frame.
  38. LED Disconnect: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the internal assembly through the front of the device.
    • The internal assembly may not come out easily. Gently bend the outer frame as necessary to create space for the edges to clear.
    • Do not force any part of the internal assembly out.
    • During reassembly, feed the microSD slot cover referenced in the previous step back through the frame as you slide the internal assembly back into place.
  39. LED Disconnect, Reassembly tips: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Reassembly tips: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly:
    • Make sure not to trap any of the five loose wires and cables when reinstalling the internal assembly.
    • Hold the lenses as close together as possible and align the rack and pinion with the gear and washer.
    • This will ensure the lenses are properly aligned.
  40. LED Disconnect, Disconnect the LED displays: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect, Disconnect the LED displays: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the left LED display ribbon cable from the motherboard.
  41. LED Disconnect: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LED Disconnect: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the right LED display ribbon cable from the motherboard.
  42. LED Disconnect, Open the midframe: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LED Disconnect, Open the midframe: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LED Disconnect, Open the midframe: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the midframe open to access the battery.
    • During reassembly, be careful not to crush the LED display ribbon cables when folding the midframe back into place.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
88,163 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 40
