Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the motor cover bolts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, ensure the power cord is unplugged and the power switch is in the OFF position.
    • Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
  2. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the motor cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor cover.
  3. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the electrical panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws securing the electrical panel.
  4. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the electrical panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the electrical panel.
  5. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the power cord fastener: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws securing the fastener behind the strain relief fitting.
  6. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fastener.
  7. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Disconnect the on/off switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Disconnect the on/off switch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Disconnect the on/off switch: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle-nose pliers to disconnect the two black and white wires from the on/off switch.
    • You don't need to remove the blue or red wires from the switch.
  8. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Disconnect the ground wire: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the green ground wire to the bottom of the electrical box.
  9. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Loosen the strain relief fitting: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to remove the power cord's strain relief fitting cap.
  10. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the cap off of the strain relief fitting.
  11. Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the power cord: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the power cord: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Cord Replacement, Remove the power cord: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the power cord and its black, white, and green wires out through the strain relief fitting.
    • Transfer the strain relief fitting cap onto the new power cord before feeding it through the fitting.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87.448 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 93
